Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Oct 14, 2014 at 3:16 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Open to critiques, all flux.
  2. Oct 14, 2014 at 3:53 PM
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    Looks good to me
  3. Oct 14, 2014 at 4:03 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    You have mig with gas or just using flux
  4. Oct 14, 2014 at 4:09 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Flux, I'll upgrade when I can find a tank that's not a million dollars.
  5. Oct 14, 2014 at 4:10 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I have a mig welder, just no gas.
  6. Oct 14, 2014 at 4:11 PM
    michaelrussell
    Michael
    belleview,FL
    That's why it looks like it was done with an arc minus the slag
  7. Oct 14, 2014 at 5:08 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    There's slag all over, just not that paticular spot, lol.
  8. Oct 14, 2014 at 5:19 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Looks OK to me . I would say not alot of heavy grinding on it . Use a old wood chisel & a wire brush to clean up some of the slag:rolleyes:
  9. Oct 14, 2014 at 5:23 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Thanks guys, I appreciate it.
  10. Oct 14, 2014 at 5:28 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    as the picture is oriented, it looks great on the vertical tube. horizontal tube has adequate penetration, but could use some more. since this weld is at the very end of the vertical tube, and the corner of the horizontal one, the horizontal one will require more heat. try angling the gun more directly at the horizontal piece, or in other orientations, towards the one that has the un-cut corner being welded to.
  11. Oct 14, 2014 at 5:31 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    10-4, thats makes since Colin, I want to say that i had it at a 45° pointed downwards.
    Thanks brother.
  12. Oct 14, 2014 at 5:35 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Sure thing!
    45 degrees downwards puts the majority of heat into the vertical tube. because the horizontal one has a larger cross sectional area, try to split them 50/50, and aim the gun perpendicular to the face of the weld. if the two tubes are the same wall thickness, you'll want to spend a little more time over the horizontal tube when making your weld.
  13. Oct 14, 2014 at 6:30 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Is that not that more for stick, Flux is more even heat anyway:notsure:
  14. Oct 14, 2014 at 6:54 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Hey tim if you want i have a 3/4 full big bottle or you can come use mine. I have a Lincoln 175hd on 75/25
  15. Oct 14, 2014 at 7:17 PM
    mromeo
    mromeo Well-Known Member
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    Any of you guys mounted an LED Bar in the lower grill or behind a grill?? Ive got a 20 inch and 2 duallys and I want to ditch my nfab bar.
  16. Oct 14, 2014 at 7:22 PM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    seen plenty on here do it. Ditch that bad boy.
  17. Oct 14, 2014 at 7:23 PM
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    thats my thoughts, figured it can be more than just some home made brackets
  18. Oct 14, 2014 at 7:24 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Mine's a first gen but:
  19. Oct 14, 2014 at 7:25 PM
    mromeo
    Atlanta GA
    2016 DCSB TRD OR
    None yet
    what did you use to get it there?
  20. Oct 14, 2014 at 7:29 PM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
