Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 22, 2010 at 5:52 PM
    #5761
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Thats actually a good idea!
  2. Dec 22, 2010 at 5:53 PM
    #5762
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Correct. The post was meant to be addressed to Ryan. I was trying to explain it to him.
  3. Dec 22, 2010 at 5:54 PM
    #5763
    Jason'sLawnCare
    I thought so to. Now that I look at it more I could move it behind where the tire touches it so it doesn't rub any more and so it clears the bumper bracket.
  4. Dec 22, 2010 at 5:54 PM
    #5764
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    Jason, did you do that to yours?
  5. Dec 22, 2010 at 5:55 PM
    #5765
    Jason'sLawnCare
  6. Dec 22, 2010 at 5:55 PM
    #5766
    rmb_crew
    By the looks of it he welded that right where your rubbing so you would rub even more. Or to solve it all just get wheel spacers!!!
  7. Dec 22, 2010 at 5:56 PM
    #5767
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    endlinks with cotter pin style setups seems more safe to me. cutting and rewelding a sway bar is a bit of a stretch for the mod.
  8. Dec 22, 2010 at 5:57 PM
    #5768
    Jason'sLawnCare
    I'm not opposed to the spacers if it lets me run the disco but I would think I could just move it back and not have clearance issues with the tire nor the brackets.
  9. Dec 22, 2010 at 5:57 PM
    #5769
    jaxchrisfla
    flooriduh
    lots
  10. Dec 22, 2010 at 5:58 PM
    #5770
    Jason'sLawnCare
    If you only disconect the end links then the sway bar itself will go into the cv's. I know it's a bit of an undertaking and that's why I need to build my skill and why I bought Ryan's sway bar so if I screw it up I still have mine.
  11. Dec 22, 2010 at 5:58 PM
    #5771
    jjw1
    Jesse
  12. Dec 22, 2010 at 6:00 PM
    #5772
    jaxchrisfla
    flooriduh
    lots
    you cant just secure it up after you detach it?
  13. Dec 22, 2010 at 6:01 PM
    #5773
    Jason'sLawnCare
    Not enough room to secure it out of the way
    Here's what happens with only one side disconnected
  14. Dec 22, 2010 at 6:01 PM
    #5774
    jaxchrisfla
    flooriduh
    lots
    if you ran the endlink disconnects, pull the two pins, whats it to take out the 4 bolts real quick to completely remove the bar while wheeling, and throw it back on when you get home?
  15. Dec 22, 2010 at 6:02 PM
    #5775
    jaxchrisfla
    flooriduh
    lots
    why are they only pulling one side? of course the other side is going to force it down into the cv if its still hooked up
  16. Dec 22, 2010 at 6:03 PM
    #5776
    Jason'sLawnCare
    It's the snaking it out that's the pain in the ass. I don't think it can be done with out removing the skid plate to. I would like to be able to detach at the trail.
  17. Dec 22, 2010 at 6:04 PM
    #5777
    jaxchrisfla
    flooriduh
    lots
    need one of these , solves the problem.
  18. Dec 22, 2010 at 6:04 PM
    #5778
    Jason'sLawnCare
    That was me and I was screwing around in the driveway to see the difference.
  19. Dec 22, 2010 at 6:04 PM
    #5779
    jaxchrisfla
    flooriduh
    lots
    thought about the skid plate afterward i posted.
  20. Dec 22, 2010 at 6:52 PM
    #5780
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    you know if you take it off and leave it off....it would be much easier....and as long as you drive your truck like its a truck, you wont have a problem....just my $.02
