Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 27, 2010 at 5:04 PM
    #6141
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Toyo A/T's.
  2. Dec 27, 2010 at 5:05 PM
    #6142
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i tried every bolt i had and nothing fit. i didnt have one of those rear skids though. i only had the front one. if you have the rear section just reuse the hardware.
  3. Dec 27, 2010 at 5:05 PM
    #6143
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    are you refering to the axel?
    edit: no rear section. i ordered the ifs skid because of all of the bends. i'm going to try to make the rest of my skids since they require fewer bends
  4. Dec 27, 2010 at 5:06 PM
    #6144
    rmb_crew
    yeah after i did the leaf pack i noticed that the whole axle is shifted to the right and i can see my right tire sticks out of the wheel well about a 1/4 more than the left.
  5. Dec 27, 2010 at 5:07 PM
    #6145
    rmb_crew
    nice. good choice.
  6. Dec 27, 2010 at 5:09 PM
    #6146
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    check the centering pins. sheck for tightness, wheter or not they are both in the hole on the spring perch, and also for if you have a bent/broken one. when i put on my u-bolt flip kit i found one of my centering pins bent at a 90* angle at the head. don't know when it happened, but i'm sure it was throwing off my axel angle or centering from side to side
  7. Dec 27, 2010 at 5:36 PM
    #6147
    rmb_crew
    yeah i am going to check it all out tomorrow. Is there a difference between the left and the right or does it matter?
  8. Dec 27, 2010 at 5:53 PM
    #6148
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    if you're using an AAL, no. there is a front and back though. but for leaf packs, i think it depends on the manufacturer as to whether or not there is a left and right.
  9. Dec 27, 2010 at 5:57 PM
    #6149
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    i am fairly certain there is still a front/back difference on the leafpacks. didn't you install them before the alignment?
  10. Dec 27, 2010 at 6:01 PM
    #6150
    rmb_crew
    i know the front/back is correct but i dont know if its a L/R?? Its an All Pro 3" pack
  11. Dec 27, 2010 at 6:05 PM
    #6151
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    If there were a difference it would be in arch to compensate for the extra weight blah blah blah. It wouldn't push the axle to one side.
  12. Dec 27, 2010 at 6:07 PM
    #6152
    rhodehard09
    tampa, fl
    yeah left and right shouldn't matter
  13. Dec 27, 2010 at 6:08 PM
    #6153
    Jason'sLawnCare
    make a plumb bob(sp?) and see if it's the axle or the bed like Chris said.
  14. Dec 27, 2010 at 6:09 PM
    #6154
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    have i missed anything
  15. Dec 27, 2010 at 6:14 PM
    #6155
    rhodehard09
    tampa, fl
    we are trying to figure out why ryans rear axle is sticking out further on one side
  16. Dec 27, 2010 at 6:15 PM
    #6156
    Jason'sLawnCare
    or if his bed shifted
  17. Dec 27, 2010 at 6:16 PM
    #6157
    johnw
    john
    orlando florida
    well it would be the axle if it wasnt like that before correct? or just maybe in my case i had bought 4 rims one had a different backspacing than the rest that will do it
  18. Dec 27, 2010 at 6:17 PM
    #6158
    rhodehard09
    tampa, fl
    does his bed look like it shifted? this should be easy to see from the rear of the truck(if you line it up with the cab on each side)
  19. Dec 27, 2010 at 6:19 PM
    #6159
    Jason'sLawnCare
    I'm thinking he didn't notice before he changed out the rear suspension and upon admiring his ass end he discovered something isn't centered.
    I never looked when I saw it. He didn't mention it when he dropped off the sway bar.
  20. Dec 27, 2010 at 6:21 PM
    #6160
    johnw
    john
    orlando florida
    check the rims because i got one that was mispackaged in the right box.
