Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Jul 4, 2016 at 7:29 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Be safe Mike! Enjoy.
  2. Jul 4, 2016 at 7:40 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    You too bud! :thumbsup:
  3. Jul 4, 2016 at 10:15 AM
    TacoHell
    TacoHell Well-Known Member
    Colson
    Central FL (Orlando)
    98 Tacoma 2.7L
    Headers, K&N intake, Lifted, 4.56 gears via ECGS. Locked in front, LSD in the rear
    Hello all, long time since I have been on the site. For the last three weeks I have been working on the Taco. Had a blown head gasket, First cylinder had a bad misfire and truck began blowing white smoke out the exhaust like seafoam would lol. Went ahead and did a compression test and cylinder 1 was 60psi while the other three were all right around 170 psi. So tore the engine down and got the head off, took it to the machine shop to get a valve job, turns out an exhaust valve(cylinder 1) was also bent/warpped could have been an result of blown head gasket or vice versa. Anyways, went ahead and got everything put back together and replace a couple other parts along the way, threw a new Doug Thorley header on, new water pump, replaced front crank seal. Been about three weeks but got it all back together and truck cranked up no problem and seems to be running well. Havent done much driving on it yet as I still need to get some exhaust hangers welded up. I have attached a couple pictures of the job, nothing really in order and no pics of the exhaust installed but, just pics I snapped along the way.
  4. Jul 4, 2016 at 11:16 AM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    man I cant wait to throw a 3rz into my 80 lol, not too much longer and Ill be able to :D
  5. Jul 4, 2016 at 11:22 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Does anyone know if the fj case will bolt to an A340F?
  6. Jul 4, 2016 at 11:26 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    I thought it did, since people do the FJ tcase swap
  7. Jul 4, 2016 at 11:34 AM
    Alfuh
    2006 Prerunner
    I have a few mods
  8. Jul 4, 2016 at 11:38 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I already have one, I'm just trying to see if it will fit behind the 4 speed.
  9. Jul 4, 2016 at 3:58 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    What year A340F is it? If I recall correctly, I needed a Tacoma 23 spline case to bolt to my old tundra A340F
  10. Jul 4, 2016 at 4:25 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    For the 4runner, it's an 04.
  11. Jul 5, 2016 at 12:23 AM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    pretty sure the stock case on the 4runner is longer since it has a bigger actuator and a torsen ls inside it.
  12. Jul 5, 2016 at 4:25 PM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    So I've stumbled on the 37s thread. It's making me want to go straight to 37s and skip 35s.
    surfer311, 5 Lug Fury and allenfab like this.
  13. Jul 5, 2016 at 5:00 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Your poor front ring gear, tie rods, and steering rack.
    xweslingx likes this.
  14. Jul 5, 2016 at 5:32 PM
    FlyinRyan893
    Orlando, FL
    Don't think it would be much worse than 35s.
  15. Jul 6, 2016 at 8:13 AM
    xweslingx
    Wes
    Durham, NC
    Ive wanted to but I already break shit on 35s
    ckeene9 likes this.
  16. Jul 6, 2016 at 9:48 AM
    Jystr
    Jystr IG: TW_Jystr
    Leesville, LA
    2016 Barcelona Red Tacoma TRDOR
    See build thread
    Actually just found out ill be down there from 13-17th of this month. So if you have time, let me know!
    @Timbo89
  17. Jul 6, 2016 at 9:52 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Ok I'll see what I can do
    Jystr[QUOTED] likes this.
  18. Jul 6, 2016 at 3:13 PM
    TAZ2014Taco
    TAZ2014Taco Well-Known Member
    Florida
    2019 Tacoma 3.5 SR5
    Quick Update: All parts have been in and they're finishing up this week. Shop said Friday or Saturday should have her back.
  19. Jul 6, 2016 at 3:18 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Awesome man
  20. Jul 6, 2016 at 3:50 PM
    Soul Surfer
    Jimi
    ‘25 TRD OR
    :yes:
