Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 28, 2016 at 3:14 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    My baby is naked @SpruceTaco these are them headlights I was showing you I have in the box
  2. Dec 28, 2016 at 3:20 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    What are you having done at the dealer? And why swap bumpers?
  3. Dec 28, 2016 at 3:20 PM
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Someone pick these up need gone :/. South Florida set of (4) 265/75r16 BFG KO2 A/T with maybe 6,000 miles on them. $550
  4. Dec 28, 2016 at 3:46 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Even though they're not retros they still look pretty nice. Where's your bumper? What you doing?
  5. Dec 28, 2016 at 4:03 PM
    hmasonb34
    hmasonb34 Well-Known Member
    Heath
    Jax, Fl.
    98, ext cab and 2015 LB dbl cab 4x4 sport
    My 98 has 4 in.beefed blocks, QA1 up front, turbo. My 15 4x4 stock looking for lift and tires.
    I've already purchased wheels. The Procomp specs are 17x9, 4.25 back space, with a offset of -6.
    Then I mounted the stock tires 265/65/17.
    Now I'm ready to put on some new tires and I'm wanting to go as wide as possible. I'm fine with the height of the stock tires (30.5" or maybe a bit taller) I just want to go wider.
  6. Dec 28, 2016 at 4:46 PM
    hmasonb34
    Heath
    Jax, Fl.
    Mine are 4.25
  7. Dec 28, 2016 at 5:02 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Toyota threw a fit about warranty work because of my bumper so I had to pull it off but they agreed that they would do the rear main seal but they were complaining about the front seal and access to the front crank seal which is they were trying to weasel out of doing the work
    NABeast[QUOTED] likes this.
  8. Dec 28, 2016 at 5:05 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    NABeast likes this.
  9. Dec 28, 2016 at 5:32 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    They try to weasel out of anything warranty related. I went in the get mine reflashed because of the spark knock (which there's a TSB for) & they tried to blame the lift & 35's. They need up doing it after I raised hell.
  10. Dec 28, 2016 at 6:39 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2023 TACOMA LIMITED DCLB LIFTED
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 5% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, LOCK WHEELS 17 X 9 -12 W 275/70R17 TOYO OPEN COUNTRY TIRES
    If your wheels are 9" wide with a -6 offset your backspace is 4.76 not 4.25.
    hmasonb34[QUOTED] likes this.
  11. Dec 29, 2016 at 9:17 AM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    The only thing I found similar back in the day was 285/60/ 17 wich were technically just under 31's but alot wider. Only decent tire I found them in was Yokohama geolander
    Edit: correction. 285/65/17 which is just under 32's
  12. Dec 29, 2016 at 2:50 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    TacoTimmy7414 likes this.
  13. Dec 29, 2016 at 3:01 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Well at I'm glad your getting it done,even though you had to take the bumper off. Does ScooterWTC still work there? I haven't seen him post in a while. I'm sure he knows who the good techs are.
    It's like my '14 has a noise in the front diff, it's still under warranty. But with the lift, I don't even want to argue with them. Plus me being a technician for over 20 years...it kills me to let someone work on my vehicles. I'm too damn anal, I've seen some hacks in my days.
  14. Dec 29, 2016 at 3:43 PM
    Old School
    Old School You are ignoring covfefe by this member.
  15. Dec 29, 2016 at 4:21 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Yeah it sucks but got it done. Scott does still work at wct. We went back and tried to get his guy to work on it but he was in the middle of a tear down on a motor.
  16. Dec 29, 2016 at 4:22 PM
    hmasonb34
    Heath
    Jax, Fl.
    Well a 285 is 11.22 wide and im really trying to get to 12.00 wide so 305 is the trick just gotta see if I can squeeze those in my fenders.
  17. Dec 29, 2016 at 4:29 PM
    hmasonb34
    Heath
    Jax, Fl.
    Well thats what I was told by 4wp anyways sorry if im passing miss information.
  18. Dec 29, 2016 at 4:43 PM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    this is why i said 4.75, which store did you buy the wheels from?
  19. Dec 29, 2016 at 4:50 PM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    Whelp, looks like saturday is the day as long as my wheels come in tomorrow.
  20. Dec 29, 2016 at 4:58 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
    I'll be running all over Volusia and Lake county this weekend.
    :burnrubber:
