Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Apr 29, 2017 at 5:51 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Finished with a little bit of daylight left. Just got done putting all the tools and whatnot up. Rub at full passenger still which is because of the alignment being messed up from when we did the ball joints, so Hardrock is a no go unless I drive up there super early and get an alignment done at a tire kingdom near there. :boom:
    The rubbing spot
    Cleaned up cmc and pinch weld
  2. Apr 29, 2017 at 6:20 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Tires and Wheels look Great Frank! Nice Combo!!
  3. Apr 29, 2017 at 7:19 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Looks great, that sucks if you can't go.
    Rattletrap66[QUOTED] likes this.
  4. May 1, 2017 at 4:09 AM
    Broverlanding
    Broverlanding Well-Known Member
    Grant
    St. Augustine, Fl
    2016 TRD OR
    CBI all the things BP51 Shadow Awn - Custom bed rack
  5. May 1, 2017 at 4:53 AM
    WendyTaco
    WendyTaco Well-Known Member
    Kyler
    2017 TRD Off-Road
  6. May 1, 2017 at 5:12 AM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    Yes, well close. I called on this one. It's a running good motor, just a distributer model not the coil pack version that I would like to use. These are a little more difficult to swap.
    thanks for posting it, keep em coming...
  7. May 1, 2017 at 6:43 AM
    sfcacique
    sfcacique Well-Known Member
    Florida
    4WD TRD Access Cab
    Thule Racks with Hullavator, Pioneer Stereo/Nav
    Just finishing up the OME suspension upgrade. Does anyone have a recommendation for 4 wheel alignment in the Lakeland area? Lakeland Toyota has a coupon for $59.95, which sounds pretty good. I like to support the local independents though.
    Also time for a front brake job. I have a 2006 TRD OR, and it looks like the rotors are 133mm or almost 13". Hard to measure as the rotors are still on the truck. 132mm does match the TRD rotor spec ( https://trdparts4u.toyotaofdallas.c...ma&modelyear=2006&catalogid=2&catalogname=TRD Performance&idCategory=2162 )
    Does anyone have a recommendation for a place around Lakeland that does rotor turning? Further recommendations on pads/rotor upgrades welcomed.
    @Rattletrap66 , @timbo3875 @allenfab @Timbo89
    Rattletrap66 likes this.
  8. May 1, 2017 at 6:46 AM
    sfcacique
    Florida
    4WD TRD Access Cab
    That's supposed to be 332mm... stupid metrics and lack of coffee
  9. May 1, 2017 at 6:47 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I do not since I am out here in Tampa but from what I remember when Wes got his done at Tim's he went to Tire Kingdom. Good stuff on getting the OME upgrade! Have you looked at getting new rotors?
    https://www.amazon.com/Power-Stop-E...9059--8-1---1-0&sr=1-1&ymm=2014:toyota:tacoma
  10. May 1, 2017 at 6:49 AM
    WendyTaco
    Kyler
    2017 TRD Off-Road
    https://orlando.craigslist.org/pts/6089334133.html
    I think the guy messed up calling it a 2.4L but I think this is a 3rz
  11. May 1, 2017 at 7:08 AM
    GuyHuey
    Guy
    Holiday, Florida
  12. May 1, 2017 at 7:09 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I have yet to find a place in Lakeland that knows how to align a vehicle. I've been to b&l, tire kingdom, and Firestone, and none of them did anything but adjust the toe.
    I have had good luck with havendale frame and axle in auburndale. It's been years since I've been there though.
    TacoTRD78 and Rattletrap66 like this.
  13. May 1, 2017 at 7:16 AM
    WendyTaco
    Kyler
    2017 TRD Off-Road
    I forgot the 2.4 liter was even a thing :facepalm: lol. For some reason I thought they went straight from the 22RE to the 2.7
  14. May 1, 2017 at 7:25 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Toyota to turn rotors, I have duralast gold pads and gold rotors. For alignments I go to tirekingdom.
  15. May 1, 2017 at 7:27 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Tested her out yesterday and stretched those legs out
  16. May 1, 2017 at 7:28 AM
    slwburn
    slwburn Well-Known Member
    Winter haven Fl
    12 tacoma dclb 4x4
    Havendale frame and axle in Auburndale. They are by far the best I've found
    allenfab and Timbo's Customs like this.
  17. May 1, 2017 at 11:12 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Soul Surfer, CC7242 and TAZ2014Taco like this.
  18. May 1, 2017 at 11:15 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Hey good luck Mike:fingerscrossed:
    :thumbsup:
    slwburn and SpruceTaco like this.
  19. May 1, 2017 at 11:25 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Thanks man!
  20. May 1, 2017 at 11:27 AM
    slwburn
    Winter haven Fl
    12 tacoma dclb 4x4
    SpruceTaco[QUOTED] likes this.
