Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. May 16, 2017 at 5:57 PM
    TAZ2014Taco
    TAZ2014Taco Well-Known Member
    Florida
    2019 Tacoma 3.5 SR5
    I know I know I have to order 8 lug rears and 6 lug fronts:angrygirl:
  2. May 16, 2017 at 5:58 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Must be the impact at the shop or something
    TAZ2014Taco likes this.
  3. May 16, 2017 at 6:06 PM
    Broverlanding
    Broverlanding Well-Known Member
    Grant
    St. Augustine, Fl
    2016 TRD OR
    CBI all the things BP51 Shadow Awn - Custom bed rack
    Just go to ocala and play
    anywhere oyu can can camp almost unless it says dont. We camp by sellers lake normally. Freeeeeeee
    TacoTRD78 likes this.
  4. May 16, 2017 at 6:20 PM
    Stormtrooper_08
    Stormtrooper_08 If two wrongs dont make a right, try three
    Orlando, FL
    White '08 TRD Sport Prerunner SR5
    4" Maxtrac spindle lift, adjustable bilsteins up front set at 1.75", 2" blocks and pro comp aals in the rear. 33" Cooper STT Pros.
    :facepalm:
  5. May 16, 2017 at 6:28 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Are you tightening the lugs with impact wrench or are you torque them to correct pressure
  6. May 16, 2017 at 6:31 PM
    Broverlanding
    Grant
    St. Augustine, Fl
    2016 TRD OR
    three giggida giggida is the correct tightness
  7. May 16, 2017 at 6:32 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    You a hater, you're not clever like me :jerkoff:
  8. May 16, 2017 at 6:57 PM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    Impact, but also have tried with a wrench. The threads are what's killing it. Keeps cross threading like it's so soft that anything can just mess it up it seems
  9. May 16, 2017 at 7:00 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Get some new lug nuts. All around
  10. May 16, 2017 at 7:03 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Weird. I thought you had spidertrax. G2s are known to be the shittier type. Spidertrax uses lugs higher than grade 8 I read somewhere. Never take an impact to a lugnut unless it's to loosen it though.
  11. May 16, 2017 at 7:15 PM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    ill check out spider trax then as well and have new lugs on the way
  12. May 16, 2017 at 7:21 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    on the new ones, try spinning all of them by hand, and then just torqueing them down
    TAZ2014Taco[QUOTED] likes this.
  13. May 16, 2017 at 7:29 PM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    I think my stock lugs screwed up the threading so when I put on the wheelers lugs it didn't help much but I definitely will
  14. May 16, 2017 at 7:37 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    The only issue I've had with using spacers is the red loctite I put on the factory studs. You have to clean that shit off and reapply every time you take the spacer off the hub, or cross threading may occur. lol
  15. May 16, 2017 at 7:37 PM
    Stormtrooper_08
    Orlando, FL
    That's what you call clever? :smack:
  16. May 16, 2017 at 7:40 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    If I wanted lip from you I would unzip
    TAZ2014Taco and Daria like this.
  17. May 16, 2017 at 7:46 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
  18. May 16, 2017 at 8:32 PM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    You need to torque them to spec then re torque after about 50-100 miles. Put red locktite on it. The impact gun is what's fucking your threads. It's over torqueing the lugs.
  19. May 16, 2017 at 9:04 PM
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    typically ride around the bombing range / pipeline trail area i would stay away from hogvalley for the most part there are some crazy sob's out there. that pit off of 13 is pretty neat kind of like the clay pits in citrus but its got a gate to the entrance which is closed ocassionally also you can camp anywheres you want as long as its not hunting season
    SpruceTaco and TacoTRD78[QUOTED] like this.
  20. May 17, 2017 at 2:37 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Thanks Mike for the info. There is some crazy people in hog valley I hunted and partied with them.Looks like
    Ill do some research and than plan and create a camp N ride thread. I appreciate everybody that has given me some info.
