Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. May 17, 2017 at 4:23 AM
    TAZ2014Taco
    TAZ2014Taco Well-Known Member
    Florida
    2019 Tacoma 3.5 SR5
    Plenty of studs to break
  2. May 17, 2017 at 4:34 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    Impact wrenches can be used, but with one big BUT--you have to use a torque limiting device like--a torque wrench with a calibrated torque clutch that can be preset as needed ($$$$); or torque sticks, a much lower cost solution. :
    The set includes 10 sticks calibrated to 65, 75, 80, 90, 100, 110, 120, 130, 140, and 150 lb·ft. I have had this set for over 5 years and use them frequently on otherwise difficult things to torque (like the variator and clutch bell on my scooters), or when consistent repeatable torque is required (like lug nuts).
    torquing the clutch assembly on my Burgman 400 (here using the 65 lb·ft stick:
    Used properly and not abused (i.e. not used as your everyday general purpose "go to" 8" extension) they are very accurate to within ±5% of their rating, same as most "clicker" type torque wrenches, but just as importantly the torque they transmit is very consistent (repeatable)--great for lug nuts.
    How they work:
    A torque stick is a resonant torsional spring; when the design torque level is reached they get "in sync" with the impact hammer blows, bouncing/twisting back before the next hammer blow hits.
    The best analogy, one that I'm sure many have experienced, is trying to hammer a good sized nail into an unsupported end of a long board. You reach a point where it doesn't matter how hard you hit the nail, or how big a hammer you use, that little suck'a just isn't going in any further. The board is behaving as a resonant cantilever mounted spring, absorbing the hammer blows as fast as you supply them.
    How to use properly:
    • Use an impact wrench capable of 150% to 300% of the stick's rating;
    • Do not use an impact wrench with some crazy high multiple of the stick's rating
      (i.e. some ThunderBolt, low-yield atomic powered Grabthar's Hammer 50,000 lb·ft rated 2-1/2" drive with reduction couplings}
    • Use a solid 6-point socket, impact rated if you got 'em (impact rated a must for higher torques (100+ lb·ft);
    • Do not use any added extensions (extensions are all "torque sticks", they are just not calibrated);
    • Support the weight of the impact wrench so that the socket and fastener are not "cocked",
      and to keep the tools weight off any bearings¹.
    • Watch the fastener when tightening, stop impacting when the fastener (socket) stops turning,
      do not continue to hammer away--while the stick will absorb excess torque repetitive blows
      will result in the applied torque creeping upward;
    Use them wisely and they are a quick and easy alternative to torque wrenches.
    ¹ - Never use an impact wrench on any shaft supported by anti-friction bearings, especially ball-bearings, without fully supporting the tool so that it's weight is not passed to the bearings, not doing this can create small detents in the bearing's races that will eventually cause the bearing to fail.
    TAZ2014Taco and TacoTRD78 like this.
  3. May 17, 2017 at 4:48 AM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    Brother limo tinted the 4Runner and tinted the windshield :eek:
    SpruceTaco and Rattletrap66 like this.
  4. May 17, 2017 at 4:58 AM
    Stormtrooper_08
    Stormtrooper_08 If two wrongs dont make a right, try three
    Orlando, FL
    White '08 TRD Sport Prerunner SR5
    4" Maxtrac spindle lift, adjustable bilsteins up front set at 1.75", 2" blocks and pro comp aals in the rear. 33" Cooper STT Pros.
    Ooohhh. I'm gonna tell your wife
  5. May 17, 2017 at 5:17 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Nice looking runner brother:thumbsup:
    TAZ2014Taco[QUOTED] likes this.
  6. May 17, 2017 at 5:19 AM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    Thanks! I installed OME everything and Light Racing UCAs, got it back from my ex wife and he is going to buy armor and all that for it
  7. May 17, 2017 at 5:43 AM
    TacoTRD78
    Stuart,fl
    Sounds pretty bad ass is it a trail edition?
  8. May 17, 2017 at 6:32 AM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    I wish, just an SR5, he's going to get a locker and winch though, for the Florida camping and trails I figure that'll be plenty
  9. May 17, 2017 at 6:37 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    it's 2wd? iirc
  10. May 17, 2017 at 6:45 AM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    Yeah idk he was talking about doing a swap or leaving it, hasn't decided yet. But slot of FL Tacomas are 2wd and run through trails fine it seems. But a 2wd with a locker I haven't seen how they perform
    Rattletrap66[QUOTED] likes this.
  11. May 17, 2017 at 7:04 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Had a 2wd with elocker with us on the georgia trails and he did great. Only had to winch himself up a big clay/mud hill washout. Here he is on one of the trails (speedway blue)
    https://www.youtube.com/watch?v=WxyVm3RrmI0
  12. May 17, 2017 at 7:08 AM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    That's awesome! I'll show him I'm sure he's wondering too
  13. May 17, 2017 at 7:51 AM
    TacoTRD78
    Stuart,fl
  14. May 17, 2017 at 7:52 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    NABeast and TAZ2014Taco like this.
  15. May 17, 2017 at 2:17 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Are you guys all running the 4x4 3 leaf (4 minus overload) 63's? I found some in ok condition, going tomorrow to pick them up. I hope they clean up alright.
    TacoTRD78 likes this.
  16. May 17, 2017 at 2:40 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    For the second gen, yes. 3 leaf plus overload
    NABeast[QUOTED] and TAZ2014Taco like this.
  17. May 17, 2017 at 2:41 PM
    TAZ2014Taco
    Florida
    2019 Tacoma 3.5 SR5
    I run 3 leaf, I'll run 4 once I have more weight in the back, but yeah those are right
    NABeast[QUOTED] likes this.
  18. May 17, 2017 at 2:42 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Y'all can have my 63s i might cut em off one of these days. I kinda hate them a little.
    allenfab likes this.
  19. May 17, 2017 at 3:12 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Why do you hate them?
    @Timbo89 these shock tabs aren't going to work are they?
  20. May 17, 2017 at 3:45 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Need to be for a axle tube.
