Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Sep 25, 2017 at 10:30 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    K, got some sleep and I started analyzing my fuel mileage data for Natty. Here it is, if anyone is interested.
    2001 3rd Gen T4R--3.4L/Auto/4WD on 265/75R16 Toyo Open Country ATIIs.
    Total trip distance: 1858.7 miles
    Total Fuel Used: 92.1 gal
    Overall MPG: 20.2
    We did the trip in basically 4 legs each direction.
    On the way up:
    Leg 1: Tampa, up I75 to Ocala, US 301 to Baldwin.
    Distance: 164.7 miles
    Fuel: 8 gal
    MPG: 20.6
    (This was as expected)
    Leg 2: Baldwin, I10 to I95/I95 to I26 to Orangeburg, SC
    Distance: 255.7 miles
    Fuel: 12.9 gal
    MPG: 19.8
    (Okay, we had to be going generally uphill, but it was still fairly flat)
    Leg 3: Orangeburg, SC, I26 to I77/I77 to I81, Fancy Gap, VA
    Distance: 237.6 miles
    Fuel: 11.9 gal
    MPG: 20
    (WTF? We were in the mountains by this point and Natty was frequently dropping out of OD to maintain speed on the hills)
    Leg 4: Fancy Gap, VA, I81 to New Market, VA/New Market, US 211(?) to Luray, VA, US 340 to Front Royal, VA
    Distance: 297.6 miles (includes a few trips off the mountain into town)
    Fuel: 14.5 gal
    MPG: 20.5
    (Okay, seriously, WTF? We were traveling on windy mountain roads with switch backs and steep inclines. Natty was frequently dropping as low as 2nd gear to maintain speed.)
    Average MPG heading up: 20.2 MPG
    Now it gets really mind boggling for me...
    Return Trip:
    Leg 1: The reverse of outbound Leg 4, stopped at the same fuel station (completely by accident)
    Distance: 245 miles (I assume the difference is how many miles I drove running into town a few times)
    Fuel: 13.2 gal
    MPG: 18.6 o_O
    (Okay, I can see maybe climbing up out of the Valley, over the mountain to New Market might have been more uphill than downhill, so that isn't terribly odd, but I still felt like I had to manually shift out of OD and several times down into 2nd gear to engine brake going down the hills more frequently this direction)
    Leg 2: The reverse of outbound Leg 3, stopped at the same fuel station (deliberately this time)
    Distance: 236.9 miles (Probably the difference of the exit ramps to the fuel stations and variations in the paths of the road)
    Fuel: 11 gal
    MPG: 21.5
    Leg 3: Orangeburg, SC, I26 to I95, Jacksonville
    Distance: 222.1 miles
    Fuel: 11.7 gal
    MPG: 19 :confused:
    (Really? If we were going uphill on the way up, wouldn't we have gotten significantly better mileage on the return leg? o_O)
    Leg 4: Jacksonville, I95/I10/US 301/I75, Tampa
    Distance: 198.2 miles
    Fuel: 8.9 gal
    MPG: 22.3
    (Okay, that's the best fuel economy Natty has ever gotten by more than a mile to a gallon, even with the size smaller tires (IIRC, she got about 22.1 MPG going to Bushnell and back for the Wreaths Across America event). Go figure on that. It's pretty weird but I'm not complaining though.)
    Average MPG coming back: 20.4 MPG
    Geez, you'd think I like statistics or something. :rofl:
    Soul Surfer likes this.
  2. Sep 26, 2017 at 3:12 AM
    Broverlanding
    Broverlanding Well-Known Member
    Grant
    St. Augustine, Fl
    2016 TRD OR
    CBI all the things BP51 Shadow Awn - Custom bed rack
    Yeah I get half that
    Taco No Baka likes this.
  3. Sep 26, 2017 at 3:38 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    @Taco No Baka
    Altitude decreases an engine’s octane requirements because of the change in air pressure. The higher elevations have a lower level of air pressure, which means an engine needs less octane to properly fire due to the lower ambient pressure. In certain states, such as Colorado where the altitude is generally above 5,000 feet in the mountain regions, 85 octane gasoline is sold, while in lower elevations 87 octane is the lowest sold.
    When an engine requires lower levels of octane to “fire,” the overall efficiency of the engine is also lowered, which means the engine works harder to achieve the same results. However, less fuel burns, which means the overall fuel-per-mile efficiency is increased because the engine is working at a reduced compression rate. In short, you can get higher miles-per-gallon at higher elevations, but the power of the engine is also somewhat reduced.
  4. Sep 26, 2017 at 4:32 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    TacoTRD78 likes this.
  5. Sep 26, 2017 at 5:07 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
  6. Sep 26, 2017 at 5:13 AM
    ChadsPride
    Sponsored by TacomaWorld.com
  7. Sep 26, 2017 at 5:22 AM
    TacoTRD78
    Stuart,fl
    I thought you guys were heading to Uwharrie in November around Thanksgiving.
    allenfab likes this.
  8. Sep 26, 2017 at 5:37 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I think if you were to do this again adding wind direction and altitude change would explain some of the differences.
  9. Sep 26, 2017 at 6:03 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Black Friday, like what John said
  10. Sep 26, 2017 at 6:03 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :wave:
  11. Sep 26, 2017 at 6:05 AM
    ChadsPride
    Suh dood!​
  12. Sep 26, 2017 at 6:44 AM
    Taco No Baka
    Lee
    Tampa, FL
    I'm guessing the OGT wouldn't have done nearly as well. I wouldn't say half though. I know she's gotten about 16.9 MPG going over to Spruce's house from Tampa and that was on surface streets not the interstate. Both vehicles get similar economy (very crappy...in the 11-13 MPG range) with our normal day-to-day trips, usually so short the engine barely has time to warm up properly.
    That was my understanding, though, I'm a little dubious about the idea that the engine being less efficient will lead to better fuel econ. ;) Seems to me the engine making less power will just lead to more skinny pedal depression and thus more fuel flow. The ECU will probably lean the mixture out from the normal sea-level ratio, but unless you're operating at full throttle all the time, which I do rarely, then the throttle plate will just be open more to get more oxygen in there at a given power demand. Still, I'm not discounting it...other than I got shitty mileage going back over the mountain on the return trip and I got the best mileage ever between JAX and TPA. :rofl:
  13. Sep 26, 2017 at 6:49 AM
    TacoTRD78
    Stuart,fl
    :notsure:
  14. Sep 26, 2017 at 6:51 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    Compared to the 1st Gen like you had, but definitely not 2nd or 3rd Gen ;)
    Nice Truck and Congrats :)
    allenfab[QUOTED] likes this.
  15. Sep 26, 2017 at 7:09 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    For sure. I really wanted a 3rd gen tundra but too much money for my liking lol
    Scooter WCT[QUOTED] likes this.
  16. Sep 26, 2017 at 7:57 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Most squeaky got while stock was 21.7 on I-10. Now I am happy to get 16 lol
    Taco No Baka[QUOTED] likes this.
  17. Sep 26, 2017 at 7:58 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :fistbump:
  18. Sep 26, 2017 at 8:24 AM
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    I'm happy when I get 16 on my MTs
  19. Sep 26, 2017 at 8:43 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Same, thats interstate mileage. 13 around the city
  20. Sep 26, 2017 at 8:55 AM
    Taco No Baka
    Lee
    Tampa, FL
    And just think, you were getting 21.7 with a truck that weighs about a thousand pounds more and has a bigger engine than Natty. Advantage: technology. :rofl:
    Rattletrap66[QUOTED] likes this.
