Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Nov 5, 2017 at 4:18 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Diet Dr. Pepper here, haha. In all honesty though, you guys are making me wish I had some Mich Ultra in the fridge. :rofl:
    I'm really hoping they've never been touched, but the previous owner to you being an older lady probably isn't a good sign if she ever had it done...although there were regular maintenance records for the most part from the stealership, so I fervently hope that an actual Toyota technician wouldn't hack the things up like those axles today. Only record I couldn't find any info on was the scheduled timing belt change. There was a big maintenance visit in the system at 90k miles, but it didn't mention the timing belt, so I'm thinking it was never done which makes it about 60k overdue. Seems to run good though so I might try to ride it out until the 180K mark when it'd be due again...with the mileage we put on it, that should only be about 20 years from now. :D
  2. Nov 5, 2017 at 4:21 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Lol, I was thinking older lady means dealer did the work but that doesn' always mean that & it it was done at the dealer there would be a record of it.
    Taco No Baka[QUOTED] likes this.
  3. Nov 5, 2017 at 4:22 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I wish I would have taken pics of Hugo’s axles before I doctored them up.
    I guess you can’t let just anyone use a cutoff wheel or a torch lol
    Key-Rei and Taco No Baka like this.
  4. Nov 5, 2017 at 4:27 PM
    Hugopreston
    Hugopreston Well-Known Member
    Hugo
    Tampa, Florida
    20 TRDOR MT DCSB
    Hey, mine were fucked but kyles axle we took apart was a little worse. Hahah.
    Key-Rei and allenfab[QUOTED] like this.
  5. Nov 5, 2017 at 4:28 PM
    Taco No Baka
    Lee
    Tampa, FL
    I could only get the records back to 2007 though. There wasn't anything before that. I'm thinking they might have used a different system before that and the records didn't make the transition.
    At any rate, I'm perplexed why if the vehicle was in for a big maintenance visit at 90K why the timing belt wasn't changed. That's when it was due to be done. Frankly, it's weird, but oh well, I guess. I've read that the 3.4L valve train clears the top of the piston so there shouldn't be any major damage if the belt fails.
  6. Nov 5, 2017 at 4:44 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Maybe she was on a budget & couldn't afford to do it all at once so took it back later to do the belt. :notsure:
  7. Nov 5, 2017 at 4:59 PM
    Taco No Baka
    Lee
    Tampa, FL
    All evidence points to it never having been done. The little placard on the timing cover meant to be filled out with the date and mileage of the change is pristine and appears to never have had any writing on it. There's a sticker with that info on it in that position on the timing cover from when I had it done on the OGT right after I got it. It's possible that it was done and nobody filled out the placard, but with no record of it in Toyota's system and no data on the placard, I have to assume it was never done. Again, though, if it fails it shouldn't hurt the valve train according to what I've read, so I'm not going to loose sleep over it, haha. It'll either make it to 180K with no issues and it'll get done then or either it, or the water pump, will fail and it'll get done then. :thumbsup:
  8. Nov 5, 2017 at 5:22 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    No you can not! LoL! So folks shouldn't be allowed near implements of cutting.
    You made great cuts and did an excellent job patching the one gouge from the previous monkey wrencher.
    Going to try my had at un-fuggering my axels tomorrow, I have a small laundry list of little weld projects to do, haven't had gas till this last Friday been so busy. Glad to get the metal glue gun out again! :welder:
  9. Nov 5, 2017 at 5:24 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    I fired mine up when I got home. Had to do a flag pole mount to ship on Tuesday.
    Key-Rei likes this.
  10. Nov 5, 2017 at 5:27 PM
    Timbo's Customs
    Timothy
    Lakeland FL
  11. Nov 5, 2017 at 5:51 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Oh I thought you said the belt had been changed. Haha
  12. Nov 5, 2017 at 5:58 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Any of you guys with a grey/silver 3rd Gen on 75 going through fort Myers dragging an off road trailer and a canoe on the roof? Looked like you were heading for some fun!
    Key-Rei and TacoTRD78 like this.
  13. Nov 8, 2017 at 5:30 AM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Is there a hardrock meet this month?
  14. Nov 8, 2017 at 5:35 AM
    allenfab
    Todd
    Lakeland, FL
    Next weekend I believe
    NABeast[QUOTED] likes this.
  15. Nov 8, 2017 at 5:35 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Is it posted anywhere ?
  16. Nov 8, 2017 at 5:39 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  17. Nov 8, 2017 at 5:44 AM
    TacoTRD78
    Stuart,fl
    Thanks Frank I need Facebook I guess
  18. Nov 8, 2017 at 8:16 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Yes, John, you do.
    Rattletrap66 likes this.
  19. Nov 8, 2017 at 10:40 AM
    Taco No Baka
    Lee
    Tampa, FL
    Nobody needs facebook. :puke:
    :D
    Key-Rei, TacoTRD78 and bigfoote13 like this.
  20. Nov 8, 2017 at 10:43 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    no one needs TW either but here we are
    Key-Rei likes this.
