Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Nov 12, 2017 at 12:45 PM
    Snakedoctor
    Snakedoctor Well-Known Member
    Taylor
    Land O Lakes, FL
    2017 Tacoma TRD OR
    Mandatory tint, in-channel visors, and 265/75R16 MT Toyos.
  2. Nov 12, 2017 at 1:49 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Yeah that's a spst but basically the sam size as the spdt I have.
  3. Nov 13, 2017 at 9:54 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Thought I'd try a different color out...what do you think?
  4. Nov 13, 2017 at 11:11 AM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    what would you guys recommend for a handheld CB radio? im sick and tired of my shit not working after I got the fiberglass put on, im about done with it lol; ive had nothing but issues with it. Even after moving the antenna up front and mounted to my bumper I still cant transmit or receive very well. im thinking of getting myself a HAM radio license and a handheld HAM radio
    EDIT: I found this one on Amazon
    https://www.amazon.com/Midland-75-8...pID=31uJdlK24NL&preST=_SY300_QL70_&dpSrc=srch
  5. Nov 13, 2017 at 11:19 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    You can use frequencies that don't require a license. I love my baofengs...that's what we used at Lazy springs instead of cb.
  6. Nov 13, 2017 at 11:23 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    you sure about that? everywhere ive seen says no matter what to transmit on UHF and VHF you are required to have a license, even on a handheld
    Ill prob end up having both in the truck at some point just for ease of communications between people who do and dont have HAMs
  7. Nov 13, 2017 at 11:25 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Correct me if I am wrong, but does your ATC cert not grandfather you in with the FCC?
    Alfuh[QUOTED] and 5 Lug Fury like this.
  8. Nov 13, 2017 at 11:27 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    you know im not sure, I do need to look into that...I do transmit on UHF and VHF radios on an hourly basis taking to aircraft lol
    Trident904[QUOTED] likes this.
  9. Nov 13, 2017 at 11:30 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    ^^^^ x2
    I use marine vhf the most inland because the channels are quite and require no license, there's also murs and frs (old school walkie talkie)
  10. Nov 13, 2017 at 11:35 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    well im not really too sure where to look for the ATC deal, but its only $15 to take the test and get the license lol
    Trident904 and Key-Rei like this.
  11. Nov 13, 2017 at 11:47 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I have an FCC GROL (General Radiotelephone Operators License) I got when I was in A&P school that will permit me to operate any sort of transmitter, HAM or otherwise. I can't imagine that an ATC certification wouldn't do something similar.
  12. Nov 13, 2017 at 11:51 AM
    Broverlanding
    Broverlanding Well-Known Member
    Grant
    St. Augustine, Fl
    2016 TRD OR
    CBI all the things BP51 Shadow Awn - Custom bed rack
    I REALLY like the midland stuff. I have the GMRS setup now and cant be happier honestly.
    Alfuh[QUOTED] likes this.
  13. Nov 13, 2017 at 11:51 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Yes, yes you do. I fully expect a to be addressed via a super cool callsign at the annual meet while on the CB. Something like Penetrator47 should work.
  14. Nov 13, 2017 at 11:59 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    ill have to do some digging or call someone at the FCC or something to figure it out. itd be nice lol
    I think I'll get that one then, thanks!
    Penetrator69 it is!!!
    ManBeast and Trident904[QUOTED] like this.
  15. Nov 13, 2017 at 12:15 PM
    Broverlanding
    Grant
    St. Augustine, Fl
    2016 TRD OR
    we get like 2 or 3 miles in ocala with the GMRS. We use the MXT115s
  16. Nov 13, 2017 at 2:26 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    not bad at all!
  17. Nov 13, 2017 at 3:01 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    So this is happening...
    5 Lug Fury and NABeast like this.
  18. Nov 13, 2017 at 4:43 PM
    Taco No Baka
    Lee
    Tampa, FL
    :popcorn:
  19. Nov 13, 2017 at 4:47 PM
    Key-Rei
    Key
    Florida
    For having unmudded my truck there sure was a sheit tone of mud on her still. I think between this, my taillight, and radiator I've learned my lesson about playing in the liquid dirt.
    If only Florida had better offroading than mud puddles. :rolleyes:
  20. Nov 13, 2017 at 4:52 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Cut that exhaust while it is exposed
    5 Lug Fury likes this.
