Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Nov 13, 2017 at 4:55 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I want to build my plate rear ( takeing measurements for it now) and do a "boat exit" exhaust.
    So it'll come up to clear the axle then go straight and make a turn and come out the wing of the high clear rear.
    TacoTRD78[QUOTED] likes this.
  2. Nov 13, 2017 at 5:02 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I wouldn't recommend that. It sounds cool and all, but you really want the P-trap effect it has where it goes over the rear axle. It makes it harder for water to backflow up the pipe if the exhaust gets submerged. ;)
  3. Nov 13, 2017 at 5:06 PM
    Key-Rei
    Key
    Florida
    Noted.
    However this is still my daily so sometime cool > function. :rofl:
    That and I hope I never go in water deeper than my frame. Last thing I want is water in my cab/carpet. Buck a fuket full that! :mad:
    Not all of us have a dedicated wolverine to ride! :D
    Taco No Baka[QUOTED] likes this.
  4. Nov 13, 2017 at 5:08 PM
    Key-Rei
    Key
    Florida
    Think I'm going to take a nap before my night shift nocturnalism kicks in so I can keep going all night. Been up most of the day so I didn't miss the signature required deliver of the pump. That and it'll give the frame a chance to dry some, URD pump/filter install to follow! :cool:
    TacoTRD78 likes this.
  5. Nov 13, 2017 at 5:31 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    :cheers::popcorn:
  6. Nov 13, 2017 at 8:18 PM
    Taco No Baka
    Lee
    Tampa, FL
    Cool is NEVER > function, period...unless you're a ricer. :rofl: Function is a cool all its own. :thumbsup:
    The thing you have to consider though is even if you don't go in water up to your frame, if you get stuck, you could end up submerging your exhaust when your tires dig a rut, especially since the rear end tends to end up lower than the rest of the truck much of the time. It's one of those things where it's better to have it and not need it than to need it and not have it.
    FYI, the OGT isn't technically a dedicated trail rig. It's used to haul stuff and is a backup to the T4R. It used to be my preferred ride before the T4R since I'd much rather drive the OGT than the 2000 Honda Civic the T4R replaced...but now I kinda like the T4R better for tooling around town.
  7. Nov 13, 2017 at 8:30 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    my dedicated daily...haha, ive been actually thinking of a new paint job (now that I have an air compressor), wheels/tires, and new shocks and drop springs (like 1" drop lol).........is that considered rice????!?!?! haha
  8. Nov 13, 2017 at 8:35 PM
    Taco No Baka
    Lee
    Tampa, FL
    Don't forget the fart can no-muffler. :D
    Key-Rei and Alfuh[QUOTED] like this.
  9. Nov 13, 2017 at 8:37 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    ok.....im not going THAT ricey....hahaha. I dont think there will be anything to make a 1.5L....thats ONE POINT FIVE LITER (lol) 4 banger sound great...haha. I at least was able to get my 80s old 2.2l 20r to sound relatively decent haha
  10. Nov 13, 2017 at 8:43 PM
    Taco No Baka
    Lee
    Tampa, FL
    That's not hard. Those 20/22R four-bangers can sound pretty awesome for four-bangers. :thumbsup:
  11. Nov 13, 2017 at 9:01 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    yeah that is true lol. all of the exhaust videos ive seen of Tercels sounded like complete garbage haha, one vehicle I will not put an exhaust on lol
  12. Nov 13, 2017 at 11:05 PM
    Key-Rei
    Key
    Florida
    Ugh. That nap ended up being more of a sleep. :bored:
    Back in action, a little ingenuity and the pump is out.
    Soul Surfer likes this.
  13. Nov 14, 2017 at 12:42 AM
    Key-Rei
    Key
    Florida
    Well the hard part is over I guess. New pump in, just have to rig up the filter and cross my fingers she starts up without burning up. :bananadead:
  14. Nov 14, 2017 at 6:52 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I had a straight pipe on my Fiat 500. It made a wicked little growl out of its 1.4L (the MultiAir system and short shot intake may have contributed to that). Dropped it 2.5"F/3.0"R with Koni Struts and Madness springs, threw on a Road Race Motorsports rear sway bar, upper and lower braces on the front, and a short throw shifter. It was a blast to drive.
    Soul Surfer and Alfuh[QUOTED] like this.
  15. Nov 14, 2017 at 10:24 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    oh nice, I really dont want to be dropping THAT kind of money on my Tercel lol, just looking for replacements is all haha. I dont think theres an exhaust out there im willing to put on lol, im not gonna be one of those guys with a 4 banger ricer haha.
    this was my 80s exhaust, 2.2L 20r with a Pacesetter header straight to a Flowmaster Super 10
    https://youtu.be/ixo_WXE7yx0?t=29s
  16. Nov 14, 2017 at 10:49 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Yeah. I get that. My original intent was to get something fun for autocross. Found out after the fact the non-Abarth 500s are/were expressly prohibited by SCCA. Not to mention that the few modifications I had exceeded what was allowable for SCCA TCB class (division of the Pirelli World Challenge racing series)...
    Nowhere near as insane as the Road Race Motorsports M1 Abarth. That thing was stupid fast. 240hp, 280 ft lbs of torque in a package that weighs right around 2000 lbs...
  17. Nov 14, 2017 at 10:55 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    thats insane power wise lol, something that light with that much power...its crazy. Its funny though, I originally did not want to do any modifying to the Tercel...but now that ive had it a couple months....ive been wanting to haha. upgrade the suspension with new shocks and drop coils and new wheels tires. all that would run around $1,000~ give or take. which id be perfectly fine shelling out to make the thing look and drive a little better lol
    LMarshall73[QUOTED] likes this.
  18. Nov 14, 2017 at 12:19 PM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    To carryover the tire conversation from last week, I'll be picking up a set of Falken AT3's on my way to ONF on Friday. :D:D
    I'm hopping up one size as well. Going from a 275/65 R18 Goodyear Wrangler Adventure Kevlar to a 275/70 R18 on the Wildpeaks, so from a 32 to a 33.
  19. Nov 14, 2017 at 12:43 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    There used to be a red one that ran around here with hood exit blowoff or some shit. It sounded cool as hell :laugh:
    Alfuh likes this.
  20. Nov 14, 2017 at 8:36 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    dirty7s or gtfo!!!! hehe
