Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 1, 2017 at 5:06 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  2. Dec 1, 2017 at 11:36 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Getting closer and closer :sawzall:
  3. Dec 2, 2017 at 1:37 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'm meeting up with @JD'STaco This evening if you want me to save you the trip rattles, not trying to cut you out of your meal. :rofl:
    When/where's the Tamlando meet?:anonymous:
  4. Dec 2, 2017 at 4:53 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Now I need links, brackets, steering box, hydro assist parts, 14” coilovers , shock mounts/hoops, rear leafs , drive shafts, transfercase , misc metal for brackets I can’t buy, mounts for said transfercase, gears, lockers, brakes all around, front hub hearings, and a money tree. Lol
  5. Dec 2, 2017 at 5:29 AM
    Key-Rei
    Key
    Florida
    Oh is that all? :rofl:
    Sounds like the majority of the swap!
  6. Dec 2, 2017 at 6:04 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    That’s probably half of it haha
  7. Dec 2, 2017 at 6:50 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Thanks, that’s up to @TacoTRD78
    I’ll see around 5:30 this afternoon. Thanks.
  8. Dec 2, 2017 at 7:24 AM
    TacoTRD78
    Stuart,fl
  9. Dec 2, 2017 at 8:32 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    you going to part out that money tree o_O
    Key-Rei and Hugopreston like this.
  10. Dec 2, 2017 at 11:55 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Can I borrow that money tree when you get done with it? :thumbsup:
  11. Dec 2, 2017 at 12:22 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    That's the thing i had to lay down under truck and kick a bunch of times so it would let my electronic case loose.
  12. Dec 2, 2017 at 12:45 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    The part the transfercase bolts to? That is a essential part for the transfercase to bolt to
    TacoTRD78 likes this.
  13. Dec 2, 2017 at 1:35 PM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
  14. Dec 2, 2017 at 3:58 PM
    Key-Rei
    Key
    Florida
    That's the same buzzbox I got killer little machine! :thumbsup:
    FlyinRyan893[QUOTED] likes this.
  15. Dec 2, 2017 at 4:08 PM
    Taco No Baka
    Lee
    Tampa, FL
    Well, I figured I'd get out there and address some outstanding maintenance on the OGT to see if some activity would help me shake the remnants of being sick I've been dealing with so I pulled the front tires, broke them down with the hilift and put a little over 8 oz of airsoft beads in them. I aired them back up and put them back on the truck and took it for a check ride. There was noticeably less vibration in the steering wheel at interstate speeds. There was still some vibration, but I figure it was either coming from the rear tires or the driveline. Just have to do the rear tires next and see how much difference that makes.
    As of right now though, when I put John's Nittos on Natty, I'm not even going to bother having them balanced. I'm just going to have them put some airsoft beads in them and call it good. No more of those nasty lead weights dicking up the wheels and causing corrosion. :woot:
    TacoTRD78 and LMarshall73 like this.
  16. Dec 2, 2017 at 4:50 PM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I may have to try that airsoft bead trick. I've got a shit ton of weights on my rims after getting the Falkens mounted. I used Dyna Beads when I swapped out the tires on my CB750. They worked pretty good balancing the dual sport tires I mounted. FYI, I will never ever never, never EVER change out motorcycle tires manually with spoons again.
  17. Dec 2, 2017 at 4:57 PM
    TacoTRD78
    Stuart,fl
    Sweet bike Lee
  18. Dec 2, 2017 at 5:00 PM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Thanks. I miss it. Sold in early 2015 because I never rode it. The past week or so I've been itching to give a similar treatment to my Harley...
  19. Dec 2, 2017 at 5:38 PM
    FlyinRyan893
    Orlando, FL
    I'm hoping its fairly idiot proof. I'm a complete noob with welding. Been watching youtube welding videos and it seem fairly simple. Going to be lots of practicing on scrap before i touch the truck with it.
    Key-Rei[QUOTED] and TacoTRD78 like this.
  20. Dec 2, 2017 at 6:15 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Welding tips and tricks on YouTube. What I used and a lot of scrap and get a auto dark helmet
