Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Feb 21, 2018 at 1:31 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Haha, you think it's pretty simple, and it should be, but I've never been a party to successfully separating the CV axles from the hub in a 2nd Gen. It's a bitch. You almost need some sort of press that bolts to the wheel studs and has a jack screw that presses the axle out.
  2. Feb 21, 2018 at 1:42 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Seems pretty straight forward but you know, what can go wrong will go wrong
    TacoTRD78 likes this.
  3. Feb 21, 2018 at 1:52 PM
    Taco No Baka
    Lee
    Tampa, FL
    Oh, don't get me wrong, it is pretty straight forward. It's just getting the axle out of the hub that's a bitch. Obviously if can be done, but every time I've tried it we ended up giving up and coming up with a different process to work around it. Also, I've never searched TW or Youtube to see how others have done it, so maybe there's a trick that we just never clued into.
    Hint: Search TW and Youtube before you tackle it to see how others have done it...and slide me the link so I can finally be in the know.
  4. Feb 21, 2018 at 2:11 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Seems like in every video and post ive seen they just used a hammer and chisel. Some just a pry bar and go town.
  5. Feb 21, 2018 at 2:49 PM
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, curiosity got the better of me so I looked up some videos myself. They did nothing we didn't do (except one guy used like a full sized 15 lb sledge, but he only lightly tapped it and it came loose). They made it look easy. I don't get it. We've wailed on 'em with a BFH and a brass drift with not even the slightest movement. @allenfab can back me up on this. Maybe you'll have better luck.
  6. Feb 21, 2018 at 2:51 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    :notsure:
  7. Feb 21, 2018 at 4:17 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Ive done my wheel bearings a few times, haven’t had any issues. But im a mechanic :anonymous:
    But seriously, the hard part is pressing the hub out and in the new bearing. And getting it bolted up and realized you forgot to put the backing plate on behind the hub. :annoyed:
  8. Feb 21, 2018 at 4:33 PM
    Taco No Baka
    Lee
    Tampa, FL
    :bananadead:
    You're the only one I know personally that hasn't had issues. IIRC, even Wes had issues when he tried to get his CVs out of the hub.
    NABeast[QUOTED] likes this.
  9. Feb 21, 2018 at 5:08 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Air hammer. Like i said, controlled environment haha
  10. Feb 21, 2018 at 5:13 PM
    Taco No Baka
    Lee
    Tampa, FL
    Tried it on Phil's truck. Didn't work.
    Edit: That is, I think I did. That was several years ago, so my CRS might be interfering.
    NABeast[QUOTED] and TacoTRD78 like this.
  11. Feb 21, 2018 at 5:58 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I used to work and live in the salt and snow belt of rust. But my shit was no problems. Ive worked n my share of rust buckets, i can relate.
  12. Feb 21, 2018 at 6:11 PM
    Taco No Baka
    Lee
    Tampa, FL
    Haha, well, now that we've made such a big deal out of it, Charles will probably have no problems at all, just so life can make me look like a chump. :D
  13. Feb 21, 2018 at 6:24 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Depends what life the truck lived. And, in the driveway is different then at work on a lift with your whole toolbox open. Definitely.
  14. Feb 22, 2018 at 7:27 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    I have actually had people ask me what k-9 stood for. I asked them to google it.
    LMarshall73 and TacoTRD78 like this.
  15. Feb 22, 2018 at 8:03 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
  16. Feb 22, 2018 at 8:59 AM
    Taco No Baka
    Lee
    Tampa, FL
    :rofl:
  17. Feb 22, 2018 at 10:36 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    Do you do internet security ?
  18. Feb 22, 2018 at 12:50 PM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Anybody ever replaced their cv boots? Fount a tear thats staring on one of my inners. Would like to get a new boot and fresh grease on it before it tears completely, spits the grease out and trashes the joint.
  19. Feb 22, 2018 at 1:00 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Yeah, make sure you do the boot stretch trick so the ribs aren’t touching at ride height. Or they wear out fast. I learned that the hard way.
  20. Feb 22, 2018 at 1:05 PM
    FlyinRyan893
    Orlando, FL
    How difficult was it to change the boots? Did you have to disassemble the joint?
