Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Mar 2, 2018 at 11:07 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    @Alfuh did you see the post I tagged you in on Instagram?
    Alfuh likes this.
  2. Mar 2, 2018 at 11:42 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Toyota's herding @ Lowes... :D
    Gonna cross post this one in my build thread, but I put it up here too. This is the rendition of my pressure brake bleeding system I finally got to actually work...
    All parts sourced from Lowes.
    Parts list:
    (1) Mini pressure regulator
    (1) 1/4" NPT (male)--1/4" NPT (female) ball valve (not really nessasary but it's an added layer of convenience.)
    (1) 1/4" NPT (male) air chuck nipple
    (2) 1/4" NPT (male) to 1/4" hose barb
    (1) 3/8" NPT (male) to 1/4" NPT (female) reducer bushing
    (1) 1-1/2" PVC pipe plug (not a cap)
    (1) 1-1/2" rubber pipe coupling (This should fit over the opening of your brake fluid reservoir, but I had to cut the bottom lip off mine to get the clamp down far enough to clamp to the lip of the opening.)
    (1) roll of teflon tape
    (1) package of 3/8" OD x 1/4" ID clear vinyl tubing (the sticker says it came in a 20' roll. I used some of it for the rig above and the rest I used to make hoses for the bleeder valve to run to a catch jar.)
    I'm not guaranteeing this will work with ABS systems. We tried a previous iteration on @Rattletrap66 's truck and got nothing out of the bleed valves. We tried a similar concept, but a cruder implementation on @Sholden223 's truck and got bupkis. It worked on the OGT without ABS, but I haven't tried it on the T4R yet. I've seen a video of it working on a 3rd Gen T4R with the same ABS setup as mine has so I'm assuming it will work, but I have my doubts.
  3. Mar 2, 2018 at 2:23 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    yes! sorry, I meant to comment back on that, but I ended up getting busy at work and forgetting about it lol. That's not a bad spot at all for it since I dont run my spare tire at all...only issue is I'm not a huge fan of how the compressor is mounted upside down with the bolts up, if it were the other way around, id TOTALLY get it. But i think for now, im gonna get a smaller sized toolbox and mount everything in there, that way I have a spot for the compressor and my recovery stuff
    allenfab[QUOTED] likes this.
  4. Mar 3, 2018 at 11:03 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I've got a vacuum bleeder that I had to use on my Harley. I have some extended brake lines to install when I get home that I'm hoping will work .
  5. Mar 3, 2018 at 11:06 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    So, my brother has had a KZ1000 sitting in storage for close to a decade. He offered it up to me for free (total basket case). I'm thinking the power plant might make for a fun SXS buggy...
  6. Mar 3, 2018 at 11:26 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    maaaaaaaaaaaan, I seriously need to figure out where I want to mount this stupid compressor lol. still havent figured out what tool box or something I want to use
  7. Mar 3, 2018 at 12:52 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    It has been done! :devil: dirty fives.
    I_Am_kasc0, ibanez314, Ras61 and 8 others like this.
  8. Mar 3, 2018 at 12:57 PM
    Taco No Baka
    Lee
    Tampa, FL
    Before the new frame?!?
    Edit: Now I won't be able to tell you and Frank apart. :facepalm:
    Timbo's Customs and TacoTRD78 like this.
  9. Mar 3, 2018 at 1:00 PM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    They'll be comming back off till after the frame swap. Just wanted to see them on the truck couldnt help it haha.
    @Rattletrap66 twinning. Especially after my HC rear shows up :rofl:
  10. Mar 4, 2018 at 3:52 PM
    allenfab
    Todd
    Lakeland, FL
    I'll be going to hardrock March 17th for anyone interested
    NABeast likes this.
  11. Mar 4, 2018 at 3:59 PM
    Taco No Baka
    Lee
    Tampa, FL
    @NABeast
    NABeast likes this.
  12. Mar 4, 2018 at 4:02 PM
    Taco No Baka
    Lee
    Tampa, FL
    My nearly completed AllenFab front bumper...:yay:
    More pics in my build thread.
  13. Mar 4, 2018 at 4:07 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    What’s left
    5 Lug Fury likes this.
  14. Mar 4, 2018 at 4:10 PM
    Taco No Baka
    Lee
    Tampa, FL
    We forgot we were gonna gusset the hoop. Just that and paint.
  15. Mar 5, 2018 at 6:27 AM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Im going to be down in Weston all week for training,anyone live close to there and want to get together for dinner? @Trident904
  16. Mar 5, 2018 at 6:34 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    That's 2 hours from me Brother.
    NABeast[QUOTED] and TacoTRD78 like this.
  17. Mar 5, 2018 at 7:04 AM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Well i’ll honk when i come by tonight. Lol
  18. Mar 5, 2018 at 7:09 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    Ugh, that's my Anniversary weekend, so I'll be in St. Augustine w/ the wife. Have fun and take lotsa pics and vids lol
  19. Mar 5, 2018 at 7:24 AM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Im probably going to be gear swapping , or gear break in that weekend. Idk yet.
  20. Mar 5, 2018 at 7:45 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Right on!
    NABeast[QUOTED] likes this.
