Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Apr 20, 2018 at 7:17 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Spring under you may catch on obstacles easier if you plan on climbing
  2. Apr 21, 2018 at 8:37 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Soooo does anyone have a set of stock 6 lug leaf springs :D
  3. Apr 21, 2018 at 9:45 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Anybody from the Tampa area headed over to the West Palm Beach/Lakeland/Orlando area anytime soon that might be willing to TW express a couple of leaf packs to Kenny?
    5 Lug Fury likes this.
  4. Apr 21, 2018 at 11:36 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
  5. Apr 21, 2018 at 2:06 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Send it
  6. Apr 21, 2018 at 6:04 PM
    Taco No Baka
    Lee
    Tampa, FL
    :itllbuffout:
    Timbo's Customs likes this.
  7. Apr 21, 2018 at 6:15 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    I was there today lol
  8. Apr 21, 2018 at 6:17 PM
    Taco No Baka
    Lee
    Tampa, FL
    :ohsnap:
    Rattletrap66[QUOTED] likes this.
  9. Apr 21, 2018 at 8:06 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    So next weekend Im reinstalling my add-a-leaf, drivers side hub, and doing the spark plugs. I have all the instructions for each thing and the proper torques for each nut but had one question. The spark plugs I got say not to use anti seize. That seems weird to me. I ordered the Bosch Double Iridium plugs.
  10. Apr 21, 2018 at 8:24 PM
    Taco No Baka
    Lee
    Tampa, FL
    I did some research on that a few years ago. IIRC, when the plugs say don't use anti-seize it's because they are plated in such a way that the plating acts in the same manner as anti-seize. It's designed to come loose when the plug is removed. It didn't seem like that great an idea to me given that if it flakes off the flakes are going to end up in the cylinder when you put the new plugs in which I can't imagine would be healthy for the cylinder walls, but what do I know? Maybe the flakes burn up and get blown out the exhaust port before they cause too much damage.
    FWIW, I prefer NGK to Bosch any day of the week. :D
    Key-Rei and Timbo's Customs like this.
  11. Apr 21, 2018 at 8:27 PM
    anders99
    Matthew
    Penscola, FL
    Thanks! I went with the Bosch because thats what my mechanic buddy told me to order haha. But if they are crap I will know how to change them on my own after next weekend.
    Taco No Baka[QUOTED] likes this.
  12. Apr 21, 2018 at 8:37 PM
    Taco No Baka
    Lee
    Tampa, FL
    It's a matter of personal preference, I guess. I just think that Bosch is overrated and I like NGK better. Anyway, no problem. I was curious about that myself at one time, so I looked it up, especially since we always used anti-seize on the turbine engine ignitors on aircraft.
  13. Apr 21, 2018 at 8:49 PM
    anders99
    Matthew
    Penscola, FL
    I will report back next. Sunday on how it all goes. After the plugs get replaced its a 2 hour drive home so if any issues popup it should be on that drive.
    Taco No Baka likes this.
  14. Apr 21, 2018 at 9:05 PM
    Taco No Baka
    Lee
    Tampa, FL
    Oh, and here's a tip: Use a spark plug socket to remove and install the plugs, but lube the rubber insert in the socket with Vaseline or something and tape the socket to your extension so you don't pull the extension out of the socket after the plug is installed and you go to pull the socket out. :thumbsup:
    LMarshall73 and anders99[QUOTED] like this.
  15. Apr 22, 2018 at 9:19 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    One of the benefits/curses to traveling for work is that I end up having a lot of time to plan out modifications to the truck. I've got the 4xInnovations shackle flip kit sitting in my garage, as well as a set of Bilstein B110 5100's for the extra travel in the rear. I noticed after adding the HC bumper (coupled with the bed rack and RTT) that my springs are pretty much flat. I'm currently on stock springs with an AAL. In my storage unit in Daytona, I've got a set of leafs that I pulled off of my Ram 1500 QC when I lowered it. I think that when it comes time to do the flip kit, I'm going to shuffle a couple of the Ram leafs (cut to fit, of course) into my stock leaf pack. I've already ordered U-Bolt flip plates and U-Bolts from Barnes, new center pins, and the poor man's superbumps (frame mounted GMC 1500 rear bump stops). I've got the extended brake lines already. That should pretty much do it, right?
  16. Apr 23, 2018 at 8:06 AM
    advan7
    advan7 Buy once, cry once!
    Orlando & Duuuuuuvalllll!
    2018 Cav Blue Pro
    V2.2021
    Looking for recommendations in the Central Florida area for installation of the sdhq hidden winch bumper and winch.
    I usually do all my own car installs but just don't have time cuz of work and going back to school.
    Thanks in advance.
  17. Apr 23, 2018 at 1:06 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Are 2nd and 3rd gen leaf springs the same?
  18. Apr 23, 2018 at 1:14 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I have a set with an add-a-leaf in them I will sell for $50
    bigfoote13 likes this.
  19. Apr 23, 2018 at 1:30 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I may have found a local set off a 3rd gen but I need to figure out if they're the same.
    allenfab[QUOTED] likes this.
  20. Apr 23, 2018 at 2:36 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Yes they are, suspension is the same
    5 Lug Fury[QUOTED] likes this.
