Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. May 23, 2018 at 10:25 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Lee's right since today is the first day I drove it farther than around the neighborhood. I did notice it picks up alittle faster on the low end and I can go about 75 doing 2k - 2.3k rpms which is already way better. It feels really wierd because of the soa and stiffer springs as well as my rear tires being out further than my front rn.
    Taco No Baka likes this.
  2. May 23, 2018 at 10:27 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    Lee, just bedline Your interior
    allenfab, TacoTRD78 and Taco No Baka like this.
  3. May 23, 2018 at 10:29 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Looks good.
    Taco No Baka and TacoTRD78 like this.
  4. May 23, 2018 at 10:33 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I'd honestly consider it if I could afford to have it professionally done, but those acoustic panels glued to the floor don't look like they'd be any fun at all to get up, so I'm not messing with it. I might get some rear floor mats to cover the ugly ass things up and try to learn to live with no carpet though.
    LMarshall73 likes this.
  5. May 23, 2018 at 10:37 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    What about outdoor carpet?
  6. May 23, 2018 at 10:38 AM
    Trident904
    Brian
    17 4Runner TRD OR
    The OGT is going Brazilian...
  7. May 23, 2018 at 10:39 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
  8. May 23, 2018 at 10:42 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Roll on bedliner + all weather floormats = done.
    You're welcome.
  9. May 23, 2018 at 11:03 AM
    Taco No Baka
    Lee
    Tampa, FL
    All weather floor mats bug me. The truck had the Toyota versions when I got it and they drove me nuts. And I'd still have to get the acoustic panels up to roll on the bedliner. The passenger rear floor looks like someone dumped half a tube of sealant on it before they stuck the carpet down. It's ugly as hell and probably hell to get off too.
    Like I said, if I could afford to have Linex or someone like that do it, I'd seriously consider it. Likewise, I remember my YJ had carpet that was all Velcro'd down and it was easily removed without disassembling anything in the interior. In fact, I rarely ever had it in the Jeep. If I could afford that, I might challenge some Auto Interior shop to make me a set of carpets like that I could take in and out with out taking anything apart. Maybe with some closed cell foam backing for a little cushion and sound deadening.
  10. May 23, 2018 at 11:06 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    It really isn’t all that bad
  11. May 23, 2018 at 11:07 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    You can get a gallon of bedliner for relatively inexpensive depending upon the brand. There is also a vinyl floor liner option for the 2nd gens and I believe for the first gen also.If my memory serves me correct it was somewhere around $500. If I had $500 to spend I would op for a different mod.
  12. May 23, 2018 at 11:08 AM
    Taco No Baka
    Lee
    Tampa, FL
    But you only had to do half the space I would, haha. :rofl:
  13. May 23, 2018 at 11:10 AM
    TacoTRD78
    Stuart,fl
  14. May 23, 2018 at 11:21 AM
    Taco No Baka
    Lee
    Tampa, FL
    Okay, I'll spring for the Duplicolor good stuff. You guys come over and scrape up that sealant and those acoustic panels, sand the floor, clean it with acetone and a tack cloth, and roll it out for me and I'll supply the pizza (at lunch time) and the beer (after the work is done). I'll even take the seats, kick panels, door sills, and console back out for ya. Of course, I'll be kicked back drinking beer while all this is happening. :burp: :cheers:
  15. May 23, 2018 at 11:24 AM
    TacoTRD78
    Stuart,fl
    Ok but in exchange will you replace my cv when it breaks considering you have way more experienced than me in that field.
  16. May 23, 2018 at 11:28 AM
    Taco No Baka
    Lee
    Tampa, FL
    I have way more experience at FAILING to get the CV separated from the 2nd Gen hub in that field, haha. I've never successfully managed it, but I did hear about a method I haven't tried before that seems to work.
  17. May 23, 2018 at 11:29 AM
    TacoTRD78
    Stuart,fl
    I just have a feeling that it would be my next epic fail.
  18. May 23, 2018 at 12:02 PM
    Taco No Baka
    Lee
    Tampa, FL
    Well, if the method I saw that I haven't tried yet works, changing a CV axle is easy. It's maybe a 2 hour job if you take your time and laid back about it. If you're young and hyper you can probably do it in an hour or less, haha. Maybe I'll make a video when I change the current broken one. The only real difference between mine and yours is my manual locking hubs that allow the stub axle to slide out easily instead of being a press fit like the 2nd Gens with the ADD system.
  19. May 23, 2018 at 12:16 PM
    cdk
    cdk Well-Known Member
    san angelo,tx
    2012 PreRunner TSS
    BruteForceFab rear bumper, Ranch Hand front grille guard w/ led lights, leds here and there, seat covers, dash cover, console and handle covers, weathertechs, upgraded audio system, bed mat
    I'll be in Orlando June 4-6, anyone have good food places or stuff to see that isn't disneyland/universal studios?
    Or stuff between there and Texas? we're driving I10 from Austin then I'm flying back home. Thanks
  20. May 23, 2018 at 12:17 PM
    allenfab
    Todd
    Lakeland, FL
    I'll be busy that weekend, whichever one it may be lol.
    My only recommendation is that you use a 2 part liner (with a separate hardener that you have to mix together and quickly apply) because it will hold up a lot better.
