Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. May 23, 2018 at 12:29 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    @Trident904 @Key-Rei
  2. May 23, 2018 at 12:33 PM
    TacoTRD78
    Stuart,fl
    Please do tell
  3. May 23, 2018 at 12:52 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    TacoTRD78[QUOTED] likes this.
  4. May 23, 2018 at 4:10 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    https://4rsmokehouse.com/locations/downtown-orlando/
  5. May 24, 2018 at 7:31 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
  6. May 24, 2018 at 7:50 AM
    TacoTRD78
    Stuart,fl
    Looking nice but I think you should add a HC :D
    LMarshall73 likes this.
  7. May 24, 2018 at 7:58 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    that headlight though
    5 Lug Fury[QUOTED] likes this.
  8. May 24, 2018 at 8:07 AM
    TacoTRD78
    Stuart,fl
    5 Lug Fury likes this.
  9. May 24, 2018 at 10:32 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    It's for aero
    Scooter WCT and LMarshall73 like this.
  10. May 24, 2018 at 11:19 AM
    Taco No Baka
    Lee
    Tampa, FL
    It's looking real good Kenny. :thumbsup:
    For realz! Did @Rattletrap66 just call someone out on body damage? :eek: I'm sure there's a statement somewhere that covers this. Something about pots and kettles and the color black. Hahaha, at least Kenny made the trail ride that morning, unlike a certain someone else that was :drunk: :puke:
    :crapstorm:
  11. May 24, 2018 at 11:29 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Yep :luvya:
  12. May 24, 2018 at 11:29 AM
    Taco No Baka
    Lee
    Tampa, FL
    Well, the OGT has been cleaned top and bottom and is now prepped for surgery...while her carpet is hanging from the ceiling of the carport like the sword of Damocles.
    :rolleyes::redxfall:
    Figure I'm gonna start with the easy part, replacing the CV axle. The big greasy mess is bugging my OCD. Then I'll yank the radiator and see how it looks.
    TacoTRD78 and LMarshall73 like this.
  13. May 24, 2018 at 1:54 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Hell yeah kenny! Looks great!
  14. May 24, 2018 at 8:15 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    So i already decided im going to remove the overload spring.....its way too stiff even for the road.
    bigfoote13 likes this.
  15. May 24, 2018 at 8:26 PM
    Taco No Baka
    Lee
    Tampa, FL
    Honestly, the overload spring shouldn't make any difference. It's not supposed to even do anything until you have a load in the truck (or your suspension is compressed). Having said that, you probably don't even need it anyway since it was made for a heavier truck carrying a load. You'll lose a little ride height but that shouldn't be a big deal.
    Alternatively, you could get a tool box and a bed rack and start carrying around 300 or 400 lbs of shit like the rest of us and that should soften the ride a bit. :rofl:
  16. May 24, 2018 at 8:30 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    would it be better to pull a leaf?
  17. May 24, 2018 at 8:44 PM
    Taco No Baka
    Lee
    Tampa, FL
    I didn't get a good look at how your springs are sitting. If the overload isn't tucked up against the leaf pack, which would be weird unless you've got a lot of weight in the back of the truck, then you can try pulling the bottom leaf and see how it feels. If it's too soft and the leaf pack is sitting on the overload, you could try trimming down the bottom leaf you pulled out. That should reduce the spring rate a little and make the ride a little softer. @allenfab might be able to give you some guidance on that since that's what he did with his 63s to tune them for a lighter truck than a 2nd/3rd Gen.
    TacoTRD78 likes this.
  18. May 24, 2018 at 9:04 PM
    Taco No Baka
    Lee
    Tampa, FL
    It occurred to me tonight after my second shot of vodka that given the current state of the OGT, I'm in an ideal position to replace my body mount bushings. They are 20 years old after all and with the carpet out, I have free access to the bolts. It also occurred to me that at the same time I might be able to do something about my fan hitting the radiator when I'm in deep water. I could loosen the body mounts and push the cab forward as far as it will go. That might get me just enough to minimize the fan/radiator contact. The problem with this is the passenger side tire has been rubbing on the firewall slightly, so I might be forced to get my hands on a 10 or 12 lb sledge hammer and beat the hell out of my firewall to make some extra clearance for the tire with the cab pushed forward. While I do have it in me to beat the hell out of my truck with a sledge hammer, it hurts my feelings to do it. Who knows though, with new body mount bushings, I might not need to make any clearance.
  19. May 25, 2018 at 5:29 AM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    Lee I did mine when I first got the 4Runner and I pulled the body lift off. I used the energy suspension bushings, it made a huge difference in felt vibration from the motor. If you go that route or with any energy suspension brand bushings always get the black ones, they're impregnated with graphite and are self-lubricating.
    GH
  20. May 25, 2018 at 7:34 AM
    Taco No Baka
    Lee
    Tampa, FL
    Thanks, Guy. Those were the ones I was looking at at Rockauto. $78 shipped with their discount code (that's more than my new CV axle cost!). Dunno if I want to spend that much money ATM when I'm trying to save up the cash to get ahold of Kyle's 3.4L, but then the carpet is going to be out for a while...maybe for good, so I've got a little time to consider it. ;)
