Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Jun 4, 2018 at 4:05 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Not sure about what they are doing about achieving that desired lift height. Marie at @HeadStrong Off-Road can assist you.The answer to 2nd question is yes.
    HeadStrong Off-Road likes this.
  2. Jun 4, 2018 at 4:33 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Yes, suspension is all the same
    duece5811 likes this.
  3. Jun 4, 2018 at 4:46 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Thanks fellas.
    bigfoote13 and TacoTRD78 like this.
  4. Jun 4, 2018 at 5:33 PM
    spooots
    spooots Well-Known Member
    James
    2015 TRD Sport 4wd DCLB
    None yet but shopping now!
    Any of you guys have any of those driveline issues as a result of the lift? Seems like a lot of people have vibrations of some kind after moderate 2-3” lifts. Honestly it’s making me think twice about lifting. Aside from vibrations being annoying, my concern would be premature part failure as a result of misalignment. I know anytime you modify a stock vehicle there is a chance of things failing sooner than they would have but this is my daily and I can’t afford to be without it. Thoughts?
  5. Jun 4, 2018 at 5:38 PM
    TacoTRD78
    Stuart,fl
    No vibration issues here. I did do a carrier barrier drop not sure if it was worth it or not. I have had my truck for a lil over three years.The only major things that have gone wrong with it are the front main seal and the ECM non lift related.
    spooots[QUOTED] likes this.
  6. Jun 4, 2018 at 5:43 PM
    spooots
    James
    Cool. As always thanks for the input John. I wouldn’t think much of it but SO many people report the issue to varying degrees.
  7. Jun 4, 2018 at 5:53 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I have a 3rd Gen sport suspension on my 2nd Gen Sport and it is stiffer.
    The shocks and coils are not interchangeable. Meaning 2nd Gen coils won't work with 3rd Gen shocks and vice versa. But the either entire coilover will bolt up to either truck. I added a small spacer and got just over 2 inches up front and an aal in the rear. I did have a small vibe for a little while but it seems to have taken care of itself.
    TacoTRD78 and spooots like this.
  8. Jun 4, 2018 at 6:06 PM
    spooots
    James
    Interesting. I didn’t think about doing that. Glad to hear the vibe worked it self out. Love the white btw. Looks good
    TacoTRD78 likes this.
  9. Jun 4, 2018 at 6:09 PM
    Flordiataco
    Flordiataco Member
    Justin
    Anyone near ocala? Im just outside it in citrus county.
  10. Jun 4, 2018 at 6:09 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Thank you. Ive wanted this truck since 2005. This is the most recent.
  11. Jun 4, 2018 at 6:12 PM
    spooots
    James
    Damn looks great! My first Tacoma was white. Had it 7 yrs. and loved it. Looked for another white one but couldn’t find one so I got MGM. I see it says you are in South Florida. You anywhere near the Sarasota area by chance?
  12. Jun 4, 2018 at 6:16 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    No sir further south near lake o. I was in Bradenton for 8 years.
  13. Jun 4, 2018 at 6:38 PM
    spooots
    James
    Oh cool. Well truck looks great and thanks for the info :thumbsup:
    bigfoote13[QUOTED] likes this.
  14. Jun 5, 2018 at 9:58 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I started a thread for my planned trip to Overland Expo East followed by the Georgia Traverse for November 7th - 15th or 16th.
    LINKY
    Taco No Baka and TacoTRD78 like this.
  15. Jun 5, 2018 at 11:10 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Question, for you guys. I know nobody would ever run anything but that nice cherry red Toyota coolant around here, but if you had to run something different in a pinch, what would you run?
    I'm thinking about the upcoming Richloam trip and if I grind another hole on my radiator with the fan going though deep water, I'm not sure I wanna waste my $30 bottle of Toyota coolant, so I'm thinking about running either plain distilled water tainted with whatever red coolant is left hiding in the engine or using a cheaper sacrificial coolant which will be flushed out after the trip and the cherry red stuff put back in either the current radiator if it survives or the spare one I have if I have t put that one in.
  16. Jun 5, 2018 at 11:14 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I've never run anything but prestone.... Idk why the majority of people are against it.
  17. Jun 5, 2018 at 11:17 AM
    Taco No Baka
    Lee
    Tampa, FL
    The orange dex-cool stuff?
  18. Jun 5, 2018 at 11:39 AM
    TacoTRD78
    Stuart,fl
  19. Jun 5, 2018 at 11:42 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    That will be yuge with the mall crawling crowd. They could have made bank at the Daytona Truck Meat (Meet) this past weekend. :D
  20. Jun 5, 2018 at 11:53 AM
    Taco No Baka
    Lee
    Tampa, FL
