Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Sep 19, 2018 at 11:08 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    It’s a 8.4” by most standards
    5 Lug Fury likes this.
  2. Sep 19, 2018 at 11:41 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Rgr. I thought I read somewhere that later 2nd Gens just went to a 8" rearend and dropped the 8.4 entirely. If my 3rd will fit into it, I might have some interest in the housing and axles when you swap it out.
  3. Sep 19, 2018 at 11:49 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I also have an 8.4 rear end along with a mech lsd that I was going to use until I got the elocker axle
    TacoTRD78 likes this.
  4. Sep 19, 2018 at 12:20 PM
    Taco No Baka
    Lee
    Tampa, FL
    I'm not ready to move on anything any time soon. I have my crossmember and my regear to get done first, but assuming you're willing to sit on it for a while, how much would you want for just the housing and the axles (assuming my 8.4 3rd fits into it and the axle shaft splines are the same)?
  5. Sep 19, 2018 at 12:30 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    They should the only thing is my axle shafts have 5 lug patterns on the end. Everything else is the same. Honestly I was just planning on pulling the 3rd and tossing it lol.
  6. Sep 19, 2018 at 1:43 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
  7. Sep 19, 2018 at 6:33 PM
    Taco No Baka
    Lee
    Tampa, FL
    In that case, I'll take the housing if you are giving it away and want to bring it to the Camp & Ride. The five lug axles won't do me any good, but I can definitely use the housing. :hattip:
    @Timbo's Customs : I still might be interested in your housing and axles when you do the swap as well.
    Timbo's Customs likes this.
  8. Sep 19, 2018 at 6:45 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    So just to make sure you only want the housing? It'll be alot lighter without the axles lol
  9. Sep 19, 2018 at 7:14 PM
    Taco No Baka
    Lee
    Tampa, FL
    Correct. The housing only. :thumbsup:
  10. Sep 19, 2018 at 7:14 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    What are your going to be doing with said axle. Just curious
  11. Sep 19, 2018 at 7:38 PM
    Taco No Baka
    Lee
    Tampa, FL
    Yours, I was thinking about putting under the OGT for a wider stance and more stability, especially when I go to 35s, but I'm still trying to figure out a solution for the front. Running wheel spacers to match the rear would mean a lot more floorboard/firewall tubbing. On the other hand, I could always hang on to it in the event I ever win the lotto and can afford to SAS, then I can get a front axle to match the rear. Kenny's, I was going to use to make an adapter for pressing axles out of wheel bearings for if/when I ever have to replace the rear wheel bearings on the T4R or the OGT if it ends up with a 2nd Gen axle under it.
    edit: also, I was thinking that the wider 2nd Gen axle might let me run air bumps on the OB sides of the frame, which would be a bit more comfortable when I end up slamming the bumps.
  12. Sep 22, 2018 at 5:39 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Them poor harbor freight castors. Axle does not touch the ground. Looks like it does but it don’t
  13. Sep 23, 2018 at 8:42 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
  14. Sep 23, 2018 at 9:05 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Looks like @SpruceTaco Mikes old truck
    Taco No Baka and Hugopreston like this.
  15. Sep 24, 2018 at 9:54 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Had a little fun out at Citrus yesterday with the No Mall Crawl group. We ended up with something like 34 trucks split into two groups. I ran tailgunner for the group I was in. Most of the trucks were pretty much stock and a handful of the guys had never been off-road before, which made for quite a few recoveries. @Timbo's Customs you need to get some business cards made so that we can hand them out at these events. I know at least a few of the trucks running OEM/N-Fab side steps are going to be looking for sliders soon...
    I didn't get any pictures out there, but I did find the 35's like to grab my rear fenders. Now I know where to trim...
    [​IMG]20180924_123949 by Lee, on Flickr
    [​IMG]20180924_123941 by Lee, on Flickr
    [​IMG]20180924_124015 by Lee, on Flickr
    I found the driver side tire was rubbing the HC bumper, but I don't think it's significant enough to warrant cutting.
    [​IMG]20180924_123957 by Lee, on Flickr
    [​IMG]20180924_124044 by Lee, on Flickr
  16. Sep 24, 2018 at 11:29 AM
    replica9000
    2019 T4R ORP
    Looks like the police travel in packs on 75. Must have seen 10 people pulled over within a mile.
  17. Sep 24, 2018 at 11:45 AM
    TacoTRD78
    Stuart,fl
    Quotas and being the end of month :notsure:
  18. Sep 24, 2018 at 1:01 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    @LMarshall73 tell them to hit me up on here or on Facebook
    LMarshall73 likes this.
  19. Sep 24, 2018 at 2:04 PM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I haven't seen FHP do it for a while, but they'll park a handful of cruiser on an onramp and have someone on the overpass running radar. They'll pop one after another.
    Another trick I've seen FHP (and troopers in South Carolina) use is really clever. You'll pull up on a marked cruiser and 1-2 unmarked cars with lights on behind another car. If someone fails to move over or slow down (or just generally speeds by) the car that's "pulled over" will hit their lights and chase them down while the next unmarked car in line kills their lights...
  20. Sep 25, 2018 at 11:55 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Technically that's a speed trap and a form of entrapment. Those types of "set-ups" were banned in a lot of states. Florida doesn't seem to be one of those. My uncle who is a Texas Ranger was on the state task force that cruised around the state busting local departments that weren't following the state no speed trap law about 10 years ago.
