Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Sep 26, 2018 at 12:28 PM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
  2. Sep 26, 2018 at 9:57 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Priorities, brother, priorities. :thumbsup: I'd rather spend money on building a spare engine once I get the mods I can do done than upgrading something that while it might bring my alignment back into spec is eventually going to cost me more in the long run when it needs the ball joints replaced. And after the spare engine is built (and probably installed so I can rebuild the old one for an actual spare while it's still rebuildable), then I'd rather save up for a crawl box, by which time I'll probably be too old decrepit to go wheeling anyway, lol.
    i30nes[QUOTED] likes this.
  3. Sep 28, 2018 at 5:34 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    Hu? I don' see how one or two unmarked cars, with their lights on, behind another trooper, backing him up, qualifies as entrapment when another car fails to move over for the trooper, which is a law, or speeds by the trooper that has someone pulled over, which is another law, qualifies as entrapment? To me they are clearly visible with their light on. You "should" move over if possible and be doing close to the speed limit. Correct me if I'm wrong? A well defined "speed trap" to me, would be an unreasonable speed limit on a road that does not require such a speed. Also, remember law enforcement does not set the speed limit our elected officials do. Not to stir the pot just saying is all. I'm actually not a fan of troopers but from what I can see in the scenario it does not seem like a speed trap.
    Scooter WCT likes this.
  4. Sep 28, 2018 at 5:38 AM
    k9cop
    Farva
    Hogwarts
    Hahaha quotas are illegal. We don't have them. They can encourage tickets in certain areas especially doing highway interdiction but there are no quotas.tickets are merely at the discretion of the officer. But, in reality that's all troopers do.
  5. Sep 28, 2018 at 5:42 AM
    Flyota716
    Flyota716 Well-Known Member
    Derek
    03 white tacoma
    new fl based group organizing rides every 2 weeks ish check out NO MALL CRAWL on FB
  6. Sep 28, 2018 at 6:43 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    In Texas it’s considered deceptive posting if you have a marked cruiser with lights on posted up behind an unmarked car pretending to be stopped under the guise of a traffic stop for the sole purpose of busting people. I get the “move over law” and that is legit, but posting up like that to catch speeders is considered a type of speed trap.
    There were several municipalities in Texas that had stretches of highway where the speed limit would go from 60 to 45 in less than 1/4 mile and there were no speed limit change warning signs and the 45 limit sign was posted around a blind curve or just over the crest of a bridge and officers would be posted up clocking drivers passing the 45 sign above the limit. Speed trap.
    Florida has a small town famous for this as well. Waldo, FL on US301 between Gainesville and Jacksonville is notorious for it and now has speed trap warning billboards for miles both directions. The speed limit changes from 55 to 40 to 30 to 55 and back to 40 all within a mile through the town and up until 2010, there were no speed change warning signs between the posted limit signs.
    TacoTRD78 and skyking3 like this.
  7. Sep 28, 2018 at 8:23 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Maybe they are referred to as "productivity goals" or something else ,but is not coincidence that there is a increase in tickets"citations" given at or towards the end of the month.
  8. Sep 28, 2018 at 8:27 AM
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    Shhhhh
  9. Sep 28, 2018 at 8:32 AM
    Boatbldr
    Florida
    2002 prerunner
    None
    Quiet down peek are listening. If I could only post a zipper mouth emoji I would.
  10. Sep 28, 2018 at 8:55 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    What do you know? All you do is roam around the bars with your puppy looking at chicks
    k9cop[QUOTED] and TacoTRD78 like this.
  11. Sep 28, 2018 at 8:57 AM
    Boatbldr
    Florida
    2002 prerunner
    None
    Our dive around Lauderdale with that surfboard on your roof rack picking up babes
    k9cop likes this.
  12. Sep 28, 2018 at 10:24 AM
    Trident904
    Brian
    17 4Runner TRD OR
    Those rides are slow moving...
    Lots of newbs getting stuck in shit they shouldn’t be attempting.
    5 Lug Fury and TacoTRD78 like this.
  13. Sep 28, 2018 at 11:05 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    Nothing wrong w/ driving slow on a trail, I don't get out of 2nd gear when I ride, some of y'all like to drive like a bat out of hell for some reason. Yes, there are some 1st timers and they may get stuck, but that's all good. It's a part of the fun. It's a good group of people enjoying some trail time. That's what it's all about. Getting out, riding, getting a little dirty, and shooting the shit. It doesn't have to be some professional Off Road Park every time. Citrus is local for a lot of us/them, so that's why it's been there for the past few times. He started the group just to get a few people to go out and ride, it turned into more than he expected, so obviously, a lot of people don't mind driving slow and getting stuck. I seriously don't understand all the fuckin hate about this lately, it's childish. I still love you guys (nohomo), but damn, lighten up lol.
  14. Sep 28, 2018 at 11:14 AM
    Flyota716
    Derek
    03 white tacoma
    if ur not doing 40mph or driving out of state to ride ur not cool i guess lol
  15. Sep 28, 2018 at 11:25 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    We keep moving. We don’t like when people get out a hundred times to go up one area. We did over 60 a few times a few trips back. Realized how stupid it was and don’t do that anymore. And Derek :boink:
  16. Sep 28, 2018 at 11:29 AM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    60 is weak sauce...
  17. Sep 28, 2018 at 11:32 AM
    Taco No Baka
    Lee
    Tampa, FL
    Well said, even if I am one of those folks that likes moving faster. This is why we divide into groups at the big meets like the Fall Camp & Ride and the Annual Meet, so the people that like running slower can do so and those that like running faster don't get frustrated with the slower folks.
    I tend to do around the speed limit, which at Citrus is 30 mph. If you run faster between the semi-challenging spots it tends to smooth out the bumps so you don't get beat to death. I'll admit though, I don't have the stones to do 60 like some people (cough)Greg(cough) do down those trails.
    From what @LMarshall73 has told me about the No Mall Crawl group, they would probably have more fun at Richloam than Citrus since they seem to like mud (not that there's anything wrong with that) and Richloam mud is a lot more fun than Citrus mud. You actually have a chance to use a little skill to get through the hole at Richloam, where as Citrus, with the hard clay, you either have the ground clearance to walk right through it with no issues, or you end up high centered.
  18. Sep 28, 2018 at 11:56 AM
    Taco No Baka
    Lee
    Tampa, FL
    I should also say, I would probably have fun with the No Mall Crawl group since I enjoy the hell out of doing recoveries. It's pretty much more fun to me than anything else at Citrus is any more. Too bad I'm an old fart that doesn't do FB. :rofl:
  19. Sep 28, 2018 at 12:20 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    I can't wait to get out there next Saturday and just disappear and ride by myself.... LOSERS :luvya:
    TacoTRD78 and Scooter WCT like this.
  20. Sep 28, 2018 at 12:28 PM
    Scooter WCT
    Scott
    Wesley Chapel, FL.
    :rofl:
    allenfab[QUOTED] likes this.
