Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Oct 12, 2018 at 6:02 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Thanks Guy but I don't have facebook
  2. Oct 12, 2018 at 11:13 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
  3. Oct 12, 2018 at 11:30 AM
    Taco No Baka
    Lee
    Tampa, FL
    The AWD mode is kinda cool and I do use it when the roads are wet, not that I have to, but being as Natty is a pavement princess, I have to do something to knock the rust off the front ring and pinions, haha, but I think I'd still rather have the old skool J shift manual T-case for a trail rig. You could go with a 1999 SR5 with an E-locker and get the manual T-case.
    I should have mentioned this before, if you haven't found it already, T4R.org has a pretty good that tells you what models had what and where the problem areas to look for are.
    I'd also be a little scared of a Maryland truck. There's a good chance the frame might be rotten. Of course, I know where there's a good solid frame, but that would be an crap ton of work.
    TacoTRD78[QUOTED] likes this.
  4. Oct 12, 2018 at 12:03 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    TacoTRD78 likes this.
  5. Oct 12, 2018 at 12:09 PM
    TacoTRD78
    Stuart,fl
    I did find a 96 with a e locker for 4K in orlandohttps://orlando.craigslist.org/cto/d/1997-4runner-limited-4x4/6705541301.html
    Taco No Baka[QUOTED] likes this.
  6. Oct 12, 2018 at 12:52 PM
    Taco No Baka
    Lee
    Tampa, FL
    The mileage is a little high and the interior is a tad rough, but that probably doesn't matter for a trail rig, especially the interior. I'd probably pull the carpet and the rear seats anyway in favor of a drawer type arrangement like Dom has for carrying spare parts and gear. Slap a set of Wet Okies (Sp?) on the front seats and you'll be good. Not sure if the Limiteds in '97 had the J shift though. At any rate, it's not one I would feel bad about carving up to fit 35s under it and then taking it out and beating the crap out of it. :thumbsup:
    If you're savy with transmissions at all, I have a 2WD A340E that I believe is fairly low mileage that I'd let go cheaply. Everything but the tail shaft should be the same as the 4WD transmission, so if you did have a transmission problem you could use the guts out of the one I have.
  7. Oct 12, 2018 at 1:01 PM
    TacoTRD78
    Stuart,fl
    im so on the fence even considering a 1st gen tacoma singcab v6
  8. Oct 12, 2018 at 1:08 PM
    Taco No Baka
    Lee
    Tampa, FL
    Personally, I'd get a 4Runner before I'd buy a single cab Taco. The T4R has a slightly longer wheel base than the SWB Taco so it's kind of a nice trade off between break-over angle and the benefits of a longer wheelbase. Plus, the T4R has a much better departure angle and a bigger fuel tank.
  9. Oct 12, 2018 at 2:01 PM
    TacoTRD78
    Stuart,fl
    What is your take on a 4runner being top heavy compared to a tacoma?
  10. Oct 12, 2018 at 2:20 PM
    Taco No Baka
    Lee
    Tampa, FL
    I doubt there's much difference after you start adding bed racks and roof top tents and other stuff to the Tacoma. The T4R is definitely heavier than the Taco but the Taco has a greater GVWR. I think even if you put a roof top tent on the T4R, if you added cargo drawers and armor (bumpers, sliders, full belly skids, etc...) and widened the stance a bit with either 16 or 15x10 wheels or 8s with wheel spacers, it pretty much evens out with the Taco with bed racks and a roof top tent. The longer wheel base would help a little there too. I'm not an expert on it since I haven't wheeled Natty to get a feel for the difference between how she behaves off camber vs the OGT, but since you can get higher on an RTI ramp with a long wheel base vs a short wheel base, I think the longer wheel base of the T4R would help even with it having a little higher CG than the SWB Taco.
  11. Oct 12, 2018 at 2:26 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Bed racks and RTT's are not conducive for wheeling places like AOP or Windrock. I personally did not feel comfortable with my bedrack on the truck in a couple of spots up there. When Todd and I were up there, we saw several people with RTT's on cab height bed racks wheeling but they weren't hitting anything that was very difficult for an IFS rig. Keeping as low of a CG as possible is key when wheeling were off-camber situations are regular. Wheeling in Florida, RTT and bedrack all day long.
    There were several places at AOP where having a long wheel base would have left you high centered while the shorter wheel base was a non issue.
  12. Oct 12, 2018 at 2:34 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Have you been able to find one at all? I think they were only around for the 95-97 years.
  13. Oct 12, 2018 at 2:35 PM
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, that's pretty much why I've never seriously considered a bed rack or RTT (beyond the fact that I want a tent I can stand up in to change clothes and stuff, because getting old sucks). I have considered having a low bed rack that didn't stick up above my tool box to carry my spare tire recessed down into it, to keep the CG as low as I could and I may end up doing it someday, but I might just do a tire gate. I dunno. It's pretty low on my list of priorities.
  14. Oct 12, 2018 at 2:38 PM
    TacoTRD78
    Stuart,fl
    Yeah but they are few and far between and there is one in Tampa but never replied back. If i go first gen I wanna bob the bed.
    allenfab[QUOTED] likes this.
  15. Oct 12, 2018 at 2:50 PM
    Trident904
    Brian
    17 4Runner TRD OR
  16. Oct 12, 2018 at 3:01 PM
    Taco No Baka
    Lee
    Tampa, FL
    Daaaaayum. I really wanted to throw the BS flag there with as clean as that engine bay was. It looked like it just rolled off the lot. You think even if it was kept in the garage and never driven it would have dust or cobwebs or something in there, but dayum that thing is clean.
  17. Oct 12, 2018 at 3:53 PM
    Taco No Baka
    Lee
    Tampa, FL
    All this talk about T4Rs and such is making me think about what I would have done differently if I had it to do over again. What a trip down memory lane that is. I guess it would have started with my first 4WD. Instead of a Bronco II, I should have looked for an 85 HiLux, put it on 38s and held on to it. Then I should have kept my 81 HiLux put it on 38s and held on to it. Then there was my 83 HiLux and my 87 HiLux. Instead of selling the 83 and attempting to put a 350 in the 87, I should have taken the engine out of the 87, put it in the 83 and then put the 87 cab on the 83 frame, then put it on 38s and held on to it. Then instead of buying the Honda brand new, I should have bought a 97-98 3rd Gen T4R and kept it. So many missed opportunities...:frusty:
  18. Oct 12, 2018 at 4:31 PM
    TacoTRD78
    Stuart,fl
  19. Oct 12, 2018 at 5:11 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Welded up a sos bumper Tuesday. Nice kit and easy to figure out the layout. Lots of wire on this and garage is covered In a blanket of metal dust.
  20. Oct 12, 2018 at 5:13 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Placed a order with swag offroad. Can’t wait for that to come in. The fun of bending up to 19”s of 3/16” plate is now going to be a easy task.
    Also ordered a porta band table also.
    5 Lug Fury and Taco No Baka like this.
