Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Oct 31, 2018 at 3:29 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
  2. Nov 1, 2018 at 3:17 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Damn Lee, you fix your radiator issues and the rest falls apart. Oi!
    By the way, I have some seal lube/sealant, it's loctite brand we use it at work for input/output gearbox seals, works great and may be necessary if your housing is a little loose. Works great, used in in the '00's rear axle seals when I rebuilt the locker axle.
    *LOCTITE 573 FLANGE SEALANT
    It's rated for use with gear and engine oils.
  3. Nov 1, 2018 at 3:28 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Cool. I was thinking about using Ultra Black on the next seal. I should have on this one. The real kick in the teeth is this was the expensive-ass Toyota seal I have no idea why I bought after I heard how much they wanted for it. Guess I was hoping it would last another 20 years like the first one did. I suppose that'll learn me. :bananadead: So far, I've replaced the inner axle seal on the other side with one from Marlin and I replaced the front output T-case seal with one from NAPA and both have been in there three or four years now and haven't leaked a drop.
  4. Nov 1, 2018 at 4:10 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Tim will he give anybody a discount or is pretty much only available to you.
  5. Nov 1, 2018 at 5:08 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    He is a commercial customer I have and offered it to me when I was talking to him about picking up some tires soon.
    @TacoTRD78
  6. Nov 1, 2018 at 5:19 AM
    TacoTRD78
    Stuart,fl
    Right on man
  7. Nov 1, 2018 at 5:53 AM
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Hey guys, I’m in Jacksonville Florida, I need stock second gen trd suspension. Front and rear. No leafs, and stock rims and tires like ASAP. Anybody have laying around?
  8. Nov 1, 2018 at 6:41 AM
    TacoTRD78
    Stuart,fl
    @Soul Surfer you have any stock suspension laying around?
    Soul Surfer likes this.
  9. Nov 1, 2018 at 7:00 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    What are you looking for?
  10. Nov 1, 2018 at 7:02 AM
    dnpbakon
    Kevin
    Stock front struts complete and rear shocks
  11. Nov 1, 2018 at 7:07 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    Negative Ghost Rider.
    TacoTRD78[QUOTED] likes this.
  12. Nov 1, 2018 at 7:20 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    TacoTRD78 likes this.
  13. Nov 1, 2018 at 8:23 AM
    Key-Rei
    Key
    Florida
    I have front struts and shocks from a sport 2017 for sale, 12k miles.
    $100 for another $40 I'll throw them on for you.
    Little ways from Jax though.
    ORLANDO
    Soul Surfer and dnpbakon[QUOTED] like this.
  14. Nov 1, 2018 at 8:41 AM
    dnpbakon
    Kevin
    $100 for front and rear?
  15. Nov 1, 2018 at 9:33 AM
    Key-Rei
    Key
    Florida
    Yep! But you gotta come get them.
    dnpbakon[QUOTED] likes this.
  16. Nov 1, 2018 at 9:35 AM
    dnpbakon
    Kevin
    I’ll be in touch soon
    Key-Rei[QUOTED] likes this.
  17. Nov 3, 2018 at 5:14 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Perfect day for wheelin
  18. Nov 5, 2018 at 9:56 AM
    Taco No Baka
    Lee
    Tampa, FL
    Well, I'm certain that something has gone horribly wrong. I changed out that right front axle seal (again) today and it actually went smoothly and I DIDN'T make a huge mess while draining and filling the diff. My pressure filler thing I made worked perfectly. Only thing that didn't go right is my back is killing me now, but that's not unusual. I guess if I'm not laid up tomorrow, I'll change the rear pinion seal. After that, I'll be ready to start bugging @allenfab about which Sunday I can swing by so we can change my throw-out bearing and installate my new crossmember. :D
  19. Nov 5, 2018 at 10:02 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Starting to mock up parts of the supercharger so I can make the missing brackets for the intercooler.
    Also just about finished the jig for my uppers I was going to make. I ended up buying a set off someone but already had all the parts so I figured might as well finish the project. And yes I know the welds are garbage. I've only had a few hours of time welding and I'm using a vastly underpowered welder lol
    And she's level!!!!
    Just need to drill and tap a hole for the uniball slug
  20. Nov 5, 2018 at 10:42 AM
    Soul Surfer
    Jimi
    :thumbsup: Make sure your housing vents aren’t clogged.
    Taco No Baka[QUOTED] likes this.
