Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Nov 6, 2018 at 5:07 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    That is pretty bad ass Ill prob just buy the hand pump considering Ill be doing a oil change with a air and oil filter and dont wanna get to expensive.
  2. Nov 6, 2018 at 5:18 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    The plastic hand pumps pretty much suck and you end up making a huge mess when they bypass oil and it leaks down the side of the jug. But they'll work until you can build your own pressure filler.
    TacoTRD78[QUOTED] likes this.
  3. Nov 6, 2018 at 8:09 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Forgot to post a top view of the rack.
  4. Nov 6, 2018 at 8:15 AM
    Taco No Baka
    Lee
    Tampa, FL
    In other news, that pressure filler worked perfectly again. Soooo much easier and less messy. Unfortunately, the other shoe I was expecting from things going well yesterday dropped. The first clue was I had to use a gear puller to pull the drive flange of the pinion gear pretty much the entire way. I was looking at the splines and they looked kind of twisted. Might have been an optical illusion, but I doubt it since I had to hammer the flange back on with a BFH to get the nut started to pull everything down. It's back together and seems to be holding oil, but I have a feeling the pinion gear is going to fail soon. Good thing I'll have a back up and I'm replacing the ring and pinions soon.
  5. Nov 6, 2018 at 8:34 AM
    TacoTRD78
    Stuart,fl
    It came out well and multi functional nice job
  6. Nov 6, 2018 at 12:58 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    LUCAS! ECGS recommends using only Lucas oil in the diff. That's all I've ever run in any gear box.
  7. Nov 6, 2018 at 1:09 PM
    TacoTRD78
    Stuart,fl
    Thanks man seems to be fairly priced also
  8. Nov 6, 2018 at 1:17 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    What weight though?
  9. Nov 6, 2018 at 1:18 PM
    TacoTRD78
    Stuart,fl
  10. Nov 6, 2018 at 1:58 PM
    Trident904
    Brian
    17 4Runner TRD OR
  11. Nov 6, 2018 at 1:59 PM
    TacoTRD78
    Stuart,fl
    yeah what you said
  12. Nov 6, 2018 at 2:18 PM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
  13. Nov 6, 2018 at 2:19 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    The rear axle is not 4.6 quarts lol
  14. Nov 6, 2018 at 2:20 PM
    Trident904
    Brian
    17 4Runner TRD OR
    Mine took just under 5 qts when I changed my gear oil.
  15. Nov 6, 2018 at 2:21 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Hmmm. A one ton axle don’t take that
  16. Nov 6, 2018 at 2:38 PM
    Soul Surfer
    Jimi
    ‘25 TRD OR
    amozon has the Full Set Of crush washers for the Tacoma.
    Scooter WCT and TacoTRD78 like this.
  17. Nov 6, 2018 at 2:45 PM
    TacoTRD78
    Stuart,fl
    Soul Surfer[QUOTED] likes this.
  18. Nov 6, 2018 at 2:47 PM
    TacoTRD78
    Stuart,fl
    I guess a average is 3qts for the rear but can go up to over 4
  19. Nov 6, 2018 at 2:50 PM
    Soul Surfer
    Jimi
    ‘25 TRD OR
    :hattip:
  20. Nov 6, 2018 at 5:48 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    So I got some new shoes and I put spacers up front to clear the spindle, the alignment guy says I need spacers in the back too to do a good alignment do you guys know if that’s true?
