Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 8, 2018 at 11:53 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Welcome to TW. Prepare to have your wallet savaged ruthlessly. Your credit cards will be smoking and your bank accounts will be empty in no time. You'll be jonesing like a meth head for that next upgrade for the Taco. :thumbsup:
    BTW, if you check the little "alerts" tab at the top of page, I tagged you in the Citrus meet thread.
    If you're on facebook, join the Florida Tacomas group.
  2. Dec 8, 2018 at 12:24 PM
    ETsemaj
    ETsemaj @Koditten Pirate Radio member #001
    James
    Cape Canveral, FL
    2018 Cement Tacoma Off Road
    speaker and tweater upgrade DMM phone mount and a large wishlist
    Im down to be a tool bitc*
    Keltic-K9 likes this.
  3. Dec 8, 2018 at 12:38 PM
    Keltic-K9
    Keltic-K9 Keltic-K9
    Craig
    32825 O-town
    2019 Off Road 4x4 Tech Pkg.Barcelona Red
    Mods,mods, and more mods to come...
    Lol,
    I see that $$ spending already with jus the basic goodies I’ve been buyin as is,, it’ll only get worse!
    Thx for the add, now what to buy what to buy??.
  4. Dec 8, 2018 at 12:47 PM
    Taco No Baka
    Lee
    Tampa, FL
    If you plan on spending any time off-road, the very first mod you need to do is get a set of decent rock sliders to protect your rocker panels. We have a couple of good fabricators in the Lakeland/Auburndale ( @allenfab @Timbo's Customs ) area that can make and install them for you, or you can get a set commercially from any number of vendors. Do this before you do anything else like lift/suspension or tires. Many of us have learned the hard way of the importance of sliders, so learn from our painfully earned wisdom.
  5. Dec 8, 2018 at 12:48 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Don't forget some basic recovery gear. A simple strap, shovel and shackles will go a long way
    Grey 2015 and Keltic-K9 like this.
  6. Dec 8, 2018 at 12:58 PM
    Taco No Baka
    Lee
    Tampa, FL
    You'll want to get at least a 4" wide strap. Those little 2" ones will break the minute things get serious. And never go alone. ;)
  7. Dec 8, 2018 at 1:09 PM
    Keltic-K9
    Keltic-K9 Keltic-K9
    Craig
    32825 O-town
    Researching now for the above posts,, annnd it begins:spending:
    5 Lug Fury and Taco No Baka like this.
  8. Dec 8, 2018 at 1:57 PM
    Taco No Baka
    Lee
    Tampa, FL
    Keltic-K9[QUOTED] likes this.
  9. Dec 8, 2018 at 10:52 PM
    Taco No Baka
    Lee
    Tampa, FL
    Timbo's Customs likes this.
  10. Dec 9, 2018 at 1:50 PM
    rjaneway34
    rjaneway34 Member
    South Florida, USA
    15 Blue Ribbon TRD Sport DCSB
    SCS Stealth 6 Wheels 265/70 R17 Duratracs Bilstein 5100's @1.75 Fold-A-Cover G4 Elite WeatherTech Floor Mats Rough Country Step Bars WeatherTech Window Deflectors
    So I did a thing today...
    Before...
    After...
    Joaopac, kamakazie_1, jbroke2 and 7 others like this.
  11. Dec 9, 2018 at 2:53 PM
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Look great! Make a such a difference.
  12. Dec 10, 2018 at 11:55 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    If I were to wire a rear winch would I need to run the ground to the battery or just to the frame in the rear?
  13. Dec 10, 2018 at 12:06 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    To the battery I think.
    Why a rear winch? Why not up front where it matters?
    5 Lug Fury[QUOTED] likes this.
  14. Dec 10, 2018 at 12:09 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I've been putting off running rear power in general and want it capable to support a small winch in the rear that I got for free at hf. The wire would mainly be for air, water, outlets the usual stuff.
  15. Dec 10, 2018 at 12:50 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
  16. Dec 10, 2018 at 1:02 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    You should be fine grounding it to the frame clean the frame up and make a good connection you should be fine.
  17. Dec 10, 2018 at 1:12 PM
    Taco No Baka
    Lee
    Tampa, FL
    Although, you might want to beef up the bonding wire to the frame from the battery. Usually the big ground wire from the battery goes to a ground on the engine block with a small wire going to the body and another bonding strap that goes from the engine block to the firewall. Either one of those could fail under the power draw of a winch.
    Trident904 and 5 Lug Fury like this.
  18. Dec 10, 2018 at 1:12 PM
    Trident904
    Brian
    17 4Runner TRD OR
    I don’t know, the instructions on my smitty winch said to ground to the battery.
  19. Dec 10, 2018 at 1:13 PM
    Taco No Baka
    Lee
    Tampa, FL
    See above for the reason. :thumbsup:
  20. Dec 10, 2018 at 1:23 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I've already done a big 3 upgrade so all my grounds are beefier. Thanks for the info.
    Key-Rei likes this.
