Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 10, 2018 at 1:30 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    if you have a good ground from the battery to the frame it will be fine to ground the winch to the frame correct?
  2. Dec 10, 2018 at 1:37 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I don't see why not, as long as the ground will support the amperage draw. Of course, if you really wanted to be OCD about it, you could determine how much wire it would take to get to the winch and pick a grounding point on the frame and ohm it out and see which had the higher resistance and go with the lower. But either way would work fine, IMHO.
    Key-Rei likes this.
  3. Dec 10, 2018 at 1:39 PM
    TacoTRD78
    Stuart,fl
    I do think a battery would supply a better ground just not sure if it is necessary.
    Key-Rei likes this.
  4. Dec 10, 2018 at 1:44 PM
    Taco No Baka
    Lee
    Tampa, FL
    Agreed. That's a lot of wire to run for minimal gain, IMHO.
    TacoTRD78[QUOTED] and 5 Lug Fury like this.
  5. Dec 10, 2018 at 1:52 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    If you don't want to run cables, you can go this route. A three foot pigtail to the winch with a plug and then 30ft of jumper cables that you can plug in and hook to the battery. I'm running this on my trailer winch
  6. Dec 10, 2018 at 3:53 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    So you got the winch done on the trailer? I sold my boat today and was going to give Marlin crawler a call tomorrow.
    Timbo's Customs likes this.
  7. Dec 10, 2018 at 4:17 PM
    allenfab
    Todd
    Lakeland, FL
    Almost. I plan on finishing it this weekend, pending weather.
    No Atlas?
  8. Dec 10, 2018 at 4:40 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    No, I’m pussying out. Gonna just do the reduction box+fj case.
    allenfab[QUOTED] likes this.
  9. Dec 10, 2018 at 4:44 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Found another fj case?
  10. Dec 10, 2018 at 4:44 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Browsed on ebay briefly. Not even gonna twin stick it, just slap one in there.
  11. Dec 10, 2018 at 9:47 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
  12. Dec 11, 2018 at 1:58 PM
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Whatsup guys, so possibly upgrading my wheels to a 3.5BS, looking to get ride of 5 SCS f5 wheels. 16x8, 4.5 Backspacing.
    currently wheels have 285/75/16 st maxx on them, the 5th wheel is in the spare spot and is brand new with a brand new tire. will sell with or without tires. please pm if interested. located in Jacksonville beach florida. 9546558316
    JPinFL likes this.
  13. Dec 11, 2018 at 2:27 PM
    Manwho
    Manwho Still ignoring the voices in my head
    15 a/c sport 4x4 884/ bilstien front OME Dakar/Nitro-charger sport
    87 4runner 2in B/L N' shit 96 4runner back burner project
    I have one with the shift lever I will let go, send me a PM if interested
  14. Dec 11, 2018 at 6:18 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Pm sent.
  15. Dec 12, 2018 at 2:23 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Nice truck.
    dnpbakon[QUOTED] likes this.
  16. Dec 12, 2018 at 1:10 PM
    Taco No Baka
    Lee
    Tampa, FL
    If you ain't on the FB Florida Tacomas group, Wreaths Across America this Saturday. If you want to participate, see the details below.
    From FB...
    REMEMBER our fallen U.S. veterans.
    HONOR those who serve.
    TEACH your children the value of freedom.
    Meet at Sonny's BBQ @0830 and leave @0900 hrs
    2684 West County Road 48, Bushnell, FL 33513
    On National Wreaths Across America Day each December, volunteers will place wreaths on individual veterans' graves in over 1,100 locations throughout the U.S., with ceremonies at sea, and at each of the national cemeteries on foreign soil. This year that day falls on 12/15/2018 and we will be part of an event to place over 25,000 wreaths on veteran gravestones at the Florida National Cemetery in Bushnell.
    The cemetery is located beside part of the Croom WMA and is only about a 25 minute ride from Citrus WMA. Once the ceremonies are over we can break off for trail rides or meet up at the VFW down the road for lunch.
    JPinFL and kamakazie_1 like this.
  17. Dec 12, 2018 at 8:55 PM
    Taco No Baka
    Lee
    Tampa, FL
    I know I posted the notice, but we don't usually get a huge turn out for this. It's usually only 6-8 of us. We'd really like to see that number go up. For those that might be considering it, or even not considering it, I would like to say that the first time I participated in this, I went because so many of the men in my family are veterans. My father's father served in WWII on a sub in the Atlantic. My mother's father served in the Army Air Corps in WWII in the Pacific, building runways for our bombers. My great uncles on my moms side served in the Navy or a nuclear sub and a aircraft carrier respectively. My uncle on my dad's side was in the Navy and served on a destroyer off the coast of Vietnam. My uncle on my mom's side served in the Navy, although I'm not sure what his posting was. My father was in the Marine Corps and saw combat in Vietnam, his best friend having been killed right next to him by friendly fire. He earned a Silver Star for Valor for carrying his friend's body back out of the bush. My father and I don't have a relationship and I haven't spoken to him in 18 years, but regardless of that, I will always be proud of his service in Vietnam. Sadly, although it was my full intention to carry on the family tradition of service with the Marine Corps, I was denied the chance because I am blind in my left eye. I tried every branch even the Army which was my last choice, coming from a Navy/Marine family, haha, but it was not to be.
    That's why I went the first time, to honor my family, but having participated in this event, it hit me that I was doing something bigger than just placing wreaths. I was honoring not only my family but these veterans that had passed and not letting them be forgotten. Not all of them gave their lives for their country, but even though they may have survived whatever conflict they fought in, they gave part of their souls so the rest of us wouldn't have to.
    I promise you, if you come out with us and participate in this event, you can't help but feel like you've done something bigger than yourself, more important than your own problems. It's an honor to be able to place a wreath, not just something you volunteered to do. Please consider coming out with us.
    TacoTRD78, k9cop, JPinFL and 7 others like this.
  18. Dec 13, 2018 at 3:35 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Anyone ever successfully get diminished value claim paid? Truck was in an accident and I am looking for some guidance.
  19. Dec 15, 2018 at 8:12 PM
    rjaneway34
    rjaneway34 Member
    South Florida, USA
    15 Blue Ribbon TRD Sport DCSB
    SCS Stealth 6 Wheels 265/70 R17 Duratracs Bilstein 5100's @1.75 Fold-A-Cover G4 Elite WeatherTech Floor Mats Rough Country Step Bars WeatherTech Window Deflectors
    k9cop, Black Taco and rblalliance like this.
  20. Dec 17, 2018 at 3:57 PM
    dnpbakon
    Kevin
    Whatsup guys! Any one near Jacksonville beach area confident and willing to do a CMC for me? I can’t weld and want it to like like factory. I can travel for good work. Thanks!
