Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Feb 11, 2019 at 3:31 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    The Pelfrey’s knew what they were doing. It’s not the first time they’ve done this.
    TacoTRD78 likes this.
  2. Feb 11, 2019 at 4:19 PM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    It’s a shame they turned out to be turds. They had great products.
    Trident904 likes this.
  3. Feb 11, 2019 at 4:20 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Its thought to be a master scam from the begining create a demand than recieve funds but never supply the demand you created. There is a special place in hell fof people like that
  4. Feb 11, 2019 at 6:54 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Oddly enough, after I spent all day cleaning Natty, she repaid me by dropping two cylinders on the way to the pharmacy today. I knew it was at least one or more but when I put the code reader on it when I got home, she dropped #2 and #4 cylinders, which is weird because you would think if it dropped 2 cylinders at the same time it'd be a coil pack on a 5VZ. Anyway I pulled the plugs and I could have slipped a penny between the electrodes. I adjusted then by eye to be more in line with what the gap should be and she ran on all six afterward. Guess I'll be getting a set of NGK plugs and wires for Natty now. I'm not looking forward to changing #6. It looks like I may have to take half the engine apart to get to it. :annoyed:
  5. Feb 12, 2019 at 10:29 AM
    Taco No Baka
    Lee
    Tampa, FL
    Well, I went a little nuts. I ordered my new plugs and wires for the OG4 (Natty, now that she's earned her trail stripes...literally) and started thinking about how when I was under there installing the lift the muffler was really rusty. I'm talking I was picking at it a little bit and I'm pretty sure I could put my finger through the side of it, so I was looking at mufflers. Ended up getting a Flowmaster Super 50 for it, which should sound almost stock quiet and I figured while I was doing that, I might as well buy the one for the OGT as well. I got her the 50 series Delta Flow which is a little bit more aggressive sounding than the super 50.
    So... @allenfab when can you weld them in? :D Just kidding I know that's about as likely to happen as an SAS on my truck. Guess I'll be making a trip to Clearwater to visit Rainbow Muffler. They got their work cut out for them though because the whole system is nasty rusty and that tail pipe has a lot of bends to make it around shit. Fortunately I just want it dumped behind the axle, maybe pointed off to the side a bit.
    Soul Surfer and Rattletrap66 like this.
  6. Feb 12, 2019 at 10:54 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    I'm about to do exhaust too. Full 3 in after the downpipe.
  7. Feb 12, 2019 at 10:58 AM
    Taco No Baka
    Lee
    Tampa, FL
    I was thinking about going to 3" after the aft O2 sensor for a long time on the OGT so at least I could get a really low tone out of it, but then I figured it'd just be overkill and make the truck louder than I wanted.
    5 Lug Fury[QUOTED] likes this.
  8. Feb 12, 2019 at 11:17 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I'm not really an exhaust person but I know the current one is restricting the flow for the turbo
  9. Feb 12, 2019 at 11:22 AM
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, you need to at least put a turbo muffler and a high flow cat on it, but going bigger won't hurt either. The less back pressure you have the more efficient the turbo is and the more power you can get out of it.
  10. Feb 12, 2019 at 11:27 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    I plan to do a big old resonator and a muffler.
  11. Feb 12, 2019 at 12:38 PM
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Anyone have know of any decent beach camping in Florida? I’m in Jacksonville, but willing to travel about 2-3 hours east or west.
  12. Feb 12, 2019 at 12:41 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    All of the decent spots are actually up near you.
    Peter's point in amelia, driving and camping on the beach
    Also, I believe Huguenot Park in Jax
  13. Feb 12, 2019 at 12:43 PM
    TacoTRD78
    Stuart,fl
  14. Feb 12, 2019 at 12:44 PM
    dnpbakon
    Kevin
    Right on brotha thanks!!! Btw I saw your truck Saturday morning the day I was leaving citrus. Bummer I couldn’t stay.
  15. Feb 12, 2019 at 12:44 PM
    dnpbakon
    Kevin
  16. Feb 12, 2019 at 12:45 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    :spy:
    I have a full exhaust on my truck
    Rattletrap66 and 5 Lug Fury like this.
  17. Feb 12, 2019 at 12:57 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Welcome! yea man! we didn't get a chance to hang out. Next time for sure!
    dnpbakon[QUOTED] likes this.
  18. Feb 12, 2019 at 2:15 PM
    FlyinRyan893
    Orlando, FL
    you already have a muffler, its that spinny thing that goes woosh.
    Scooter WCT and Alfuh like this.
  19. Feb 12, 2019 at 9:56 PM
    FlyinRyan893
    Orlando, FL
    Woot! Just placed my order with SCS. One step closer. Now just need tires and gears
  20. Feb 13, 2019 at 7:51 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Oh you mean like this?
    I don't want to be a tractor
