Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Mar 1, 2019 at 3:11 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I buy a set for $15 shipped. Paypal ok?
    FlyinRyan893 likes this.
  2. Mar 1, 2019 at 3:17 AM
    i30nes
    i30nes Well-Known Member
    Tampa, FL
    21 MGM Sport
    Next you know he is coming back with a couple boxes :rofl:
  3. Mar 1, 2019 at 3:17 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    can do!
  4. Mar 1, 2019 at 8:27 AM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Just a wee bit of trimming gonna be needed
  5. Mar 1, 2019 at 8:32 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    You going to tub the firewall?
  6. Mar 1, 2019 at 8:37 AM
    FlyinRyan893
    Orlando, FL
    If I have to. Gonna try to massage with a bfh first.
    TacoTRD78 likes this.
  7. Mar 1, 2019 at 8:38 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Gotta love the bfh
    FlyinRyan893[QUOTED] likes this.
  8. Mar 1, 2019 at 8:43 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    THATS GOONA LOOK SICK!
  9. Mar 1, 2019 at 8:48 AM
    FlyinRyan893
    Orlando, FL
    Might have to get a 10 pounder..
  10. Mar 1, 2019 at 8:48 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Fookin yuuuuge.
  11. Mar 1, 2019 at 8:56 AM
    FlyinRyan893
    Orlando, FL
    RIP steering rack and ball joints and CVs.
  12. Mar 1, 2019 at 9:09 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I was planning to go all in with a 12lb'r. :cool: Just need a couple of guys like @kaijac03 and Dom to wield it for me, lol.
    Anyway, today is not my day. Had an appointment with the probate lawyer and that went okay, but I left my phone at home forgot my gum and then on the way home my A/C didn't appear to be working. Had it off with the windows down on the way to the lawyer's office, but it was pretty warm when I came back out. So I was about halfway home when I noticed the T4R didn't seem to be getting cooler, a short investigation revealed it was set to defrost. I switched it to the dash vents and the air was still about ambient temperature. Now I'm starting to panic. I don't need to spend money fixing Natty's A/C when the OGT needs to go in for attention. So I figured when I got home I'd check the compressor to see if it was turning, then I'd put the refrigerant can on it. However, after confirming the compressor was turning on and off properly, I happened to notice I had the temperature dial turn just passed halfway to the warm side. :facepalm::smack:I turned it all the way cool and instantly cold air started blowing out of the vents. So there was no A/C issue and I was getting worked up over nothing because apparently, I'm an idiot. Still doesn't top my mom driving her car for two years thinking the passenger side window was broken and wouldn't roll down when she finally took it in to the shop to get it fixed and it turned out it was just the child lock on the driver's door controls was locked, but I have a feeling I'll get there some day, lol.
  13. Mar 1, 2019 at 9:27 AM
    TacoTRD78
    Stuart,fl
    I have drove for 30 minutes and was was like WTF why is my window fogging up and it not getting cold DEFROST lol and I must just be stupid because im not that old.
  14. Mar 1, 2019 at 9:27 AM
    TacoTRD78
    Stuart,fl
    Looks good on my truck :fistbump:
    Key-Rei and FlyinRyan893[QUOTED] like this.
  15. Mar 1, 2019 at 10:35 AM
    Taco No Baka
    Lee
    Tampa, FL
    I'm second guessing myself now. I'm wondering if I should go with 4.56s instead of 4.88s. The benefits would be stronger gears, and with 35s at 70 MPH I'll only be turning a little less than 2600 RPMs. The downside is I wouldn't have as low a crawl ratio, but I should still have a lot more power than I have now (3.90s, ~2400 RPMs on 33s @70 MPH). The benefits to the 4.88s would be a lower crawl ratio, less stalling, less wear on the clutch, and less work for the engine off-road. The down side is weaker gears, and I'd be turning ~2800 RPMs at 70 MPH on 35s...about 3000 RPMs on 33s.
    If I go with 4.56s, I can get a decent interstate gear that doesn't have the engine screaming to do the speed limit, and I can get a 4.70:1 Taco Box, and still get a ridiculously low crawl ratio, but that might take a while and will probably be expensive so I'd be wheeling with the 4.56s for a while.
    Any thoughts?
  16. Mar 1, 2019 at 10:40 AM
    FlyinRyan893
    Orlando, FL
    I’m asking myself the same question with 4.88 vs 5.29 on 37s. I think I’m gonna go with 4.88 and eventually get a taco box or atlas at some point in the future. For the majority of the wheeling we do 4.56 will be fine for you I think. I’m most likely going 4.88 so I’m not turning 3100rpm at 75mph. I’m jelly of the 3rd gens with their double overdrive. If I had that I’d go 5.29.
    Taco No Baka[QUOTED] likes this.
  17. Mar 1, 2019 at 11:11 AM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    3.4 i assume? After all I've looked at I've decided to go 4.88 when I do 35s. But my truck isn't a crawler whatsoever lol
  18. Mar 1, 2019 at 11:41 AM
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, it's a 3.4L. Again, it's a double edged sword. I'd like to go up north with that crew and get some real rock crawling experience where the 4.88s would come in handy...but that's also a lot of interstate driving at 2700-2800 RPMs. Not really healthy for the engine, although I am about to have to drop a rebuilt one in it. I'm definitely not going any further away than Ocala with the current engine...at least not without trailering it.
  19. Mar 1, 2019 at 11:43 AM
    FlyinRyan893
    Orlando, FL
    2700-2800 isn't too bad. I turn about 2650 at 75. Thats currently in stock form. I think on 4.88 ill be around 2750 at 75.
  20. Mar 1, 2019 at 11:54 AM
    Taco No Baka
    Lee
    Tampa, FL
    What's your overdrive gear ratio? I know 2nd Gens run taller factory gears than 1st Gens.
    Have you looked at this? You have to know which transmission you have, but I'm sure you do.
    https://www.marlincrawler.com/differential/ring-pinion#calcs
    Edit: kinda like the numbers on that RA61F. If a 5VZ bellhousing would bolt to it and there was a properly splined clutch disc, plus an FJ t-case, I wouldn't mind running it with 4.88s. Nice low first gear, higher overdrive than my R150F.
