Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Mar 20, 2019 at 7:13 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    @Taco No Baka I'm puttin this here, so we don't cloud up Tim's Build Thread lol. It was Hammered into my head by Mr. Batt's. He was my Automotive Shop Teacher in High School and it has always stuck w/ me lol.
    Taco No Baka[QUOTED] likes this.
  2. Mar 20, 2019 at 11:36 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    No worries
  3. Mar 21, 2019 at 7:28 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    The OGT got some love with having her idle issues fixed and getting to try out Natty's new shoes before she does, but I headed over to St. Pete to day and got Natty's Flowmaster Super 50 put on today. She sounds pretty damn good. At warm idle you can hardly tell she isn't stock, but with a little throttle she growls nicely. Interior noise...no resonance I could detect and a soft, low growl at interstate speeds you could easily cover with the radio. If I had to critique one thing it would be the welds aren't as pretty as @allenfab 's, but then I've never really looked at Todd's thin walled welds. I'm almost sure he could do better though. I'm happy with it though. It was worth the drive...and sitting in front of the shop for an hour before they opened to make sure I was first in line, haha.
  4. Mar 21, 2019 at 8:26 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Anyone familiar with RFI/EMI? Our new facility in Cocoa is strategically located between 3 radio towers (an FM and Cocoa PD communications directly across the street, and a 50kW AM station a couple of miles away behind us). The RFI was wreaking havoc on our blood processors, so we had to bring in some older units and our digital scales are getting blasted so we had to get old school manual beam scales. Taking RF readings around the facility and equipment in spots reading below 10V/m seem to be okay, but people moving around can cause quite a bit of propagation. We have a couple of areas in the 20-30V/m category and a couple of isolated spots that spike to 1200-2400V/m. We've tried RF chokes and have had the building tested for noise through the electrical system. I'm about to lose my mind...
  5. Mar 21, 2019 at 2:34 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    What idle issues were you having? And how'd you fix them? I'm having some issues with mine also
  6. Mar 22, 2019 at 5:26 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Does it have AFM/DOD? What code is it throwing?
  7. Mar 22, 2019 at 5:48 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Yes it has AFM. P0307 and an occasional rough idle.
  8. Mar 22, 2019 at 7:22 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Clear code, swap injector 5 & 7, run it until code pops back up. If it’s still 7 there’s a good chance you have collapsed a lifter. Those DOD motors are prone to premature failures. I’ve done deletes on 2 6.2’s, if you do have that issue let me know and I can point you in the right direction. I will keep my fingers crossed for you that that’s not the case.
  9. Mar 22, 2019 at 7:41 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Thank you. Would you be able to hear the collapsed lifter?
  10. Mar 22, 2019 at 11:39 PM
    Taco No Baka
    Lee
    Tampa, FL
    Ever since the rear bracket broke off my air box and left a big gaping hole on the clean air side out at Croom which caused ingestion of a bunch of pine needles, leaves, and muddy water (not enough to hydro-lock it) about 3 or 4 years ago, the truck has idled a couple hundred RPMs high. I futzed around with it, pulling, disassembling, cleaning the TB and spraying the MAF sensor down with MAF cleaner with no luck. I took it to Toyota and they said it was the IABV. I replaced it to no effect and decided to just live with it.
    However, after the Fall Camp and Ride, when I had to pull the trans to replace the throwout bearing, the upstream O2 sensor got caught on the bellhousing and stretched bar tight before I noticed it. After I put the transmission back in, the IABV was operating backwards. It would start off at low idle when cold and then idle up to about 1600 RPMs when it warmed up. I replaced the upstream O2 sensor and swapped out the IABV for the old one I replaced before (since it didn't solve the issue when I put the new one in it I held on to the old one figuring it was probably still good). None of that had any effect so I figured I broke a wire or something in the O2 Sensor wiring harness or something it tied into...or the ECU was malfunctioning. The only thing that did have an effect was unplugging the IABV. The truck would idle right down when it was unplugged. Anyway, I took it to Toyota to let them chase wires since I'd rather take a jab in the eye with a sharp stick than chase a wiring problem. Long story short, they once again claimed it was the IABV and proceeded to replace it, which I didn't actually ever authorize, but I didn't really care because I didn't believe that to be the issue and that they would only start looking for the actual problem once they saw for themselves it wasn't the issue. Well...they claimed it was the issue and the truck was fixed, and in fact the truck is idling better than it has since the air box broke. As to whether that was the issue and I was wrong or they were wrong and didn't want to admit it but actually found and fixed whatever was wrong (probably something simple that wouldn't have cost as much as the IABV replacement or they would have charged me for that too), I really don't care. They soaked me for replacing the valve, but I got them to give me a 10% discount by showing them what I could have got the genuine Toyota valve for which was about half of what they were charging me for it, and I just decided to take my beating and be happy the truck was idling better than it had in years.
    Anyway, my recommendation would be to clean the MAF sensor. If that doesn't work, take the TB off and take the IABV off the TB and clean them both good. If you're still having issues, pull your plugs and check them. Replace them if they are worn out. Then it gets expensive. If the problem remains, there are a lot of pricey parts that could be causing the issue: the IABV, the MAF, the O2 sensors, fuel injectors, etc... It could get expensive really fast if you start shotgun troubleshooting. Or you can find a buddy with a code reader with a diagnostics function that knows how to interpret the data and that might help find the problem for you. Otherwise, you can learn to live with the issue if it's not that bad or you can take it to Toyota, take your beating, eat ramen noodles for a while, and be happy the issue is fixed. :thumbsup:
    TacoTRD78 likes this.
  11. Mar 23, 2019 at 12:18 AM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I'm hoping that cleaning the throttle body and MAF tomorrow will do the job lol seems like it wants to die at an idle and is hesitant when I give it gas sometimes
  12. Mar 23, 2019 at 12:46 AM
    Taco No Baka
    Lee
    Tampa, FL
    Check the plugs too. Actually, I think I'd start with the plugs.
  13. Mar 23, 2019 at 1:24 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    you throwing a CE light? I'd start with the easy stuff like the MAF sensor and cleaning the throttle body. If that doesn't help replace your upstream/downstream sensors depending on if your throwing codes or not
  14. Mar 23, 2019 at 1:33 AM
    Taco No Baka
    Lee
    Tampa, FL
    Oh, and another cheap/easy thing it could be...replace the fuel filter.
  15. Mar 23, 2019 at 11:18 AM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    No check engine light, was planning on doing the fuel filter too lol
  16. Mar 23, 2019 at 8:25 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Not likely, it’s not collapsed in the traditional sense. Plus all ls motors tick. The roller on the lifter will most likely be pitted and the cam lob will be damaged. It will just feel like a regular misfire.
  17. Mar 24, 2019 at 12:16 PM
    Taco No Baka
    Lee
    Tampa, FL
    I noticed something interesting today. The T4R pops a P0440 (evap system leak) code periodically, usually when it's over three quarters of a tank of gas and I drive over a rough patch of road. It popped one on me today and I realized, when I installed the suspension, I took the spare tire out and I didn't put it back in until I went to the muffler shop. At no time while the spare was out, even riding trails at Citrus, did it pop the P0440 code on me. Evap canister is located right above the spare tire. Anyone think this is a coincidence? o_O
  18. Mar 24, 2019 at 1:21 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Wonder how to get rid of that trash. Have a big canister system with a bunch of crap on the fender of the driver side on my 97
  19. Mar 24, 2019 at 1:33 PM
    Taco No Baka
    Lee
    Tampa, FL
    So does the OGT. You should have a lot of space on the passenger side fender once you get rid of all that ABS BS. I think I've seen people relocate their Evap cannister to the top of the fuel tank, but it was an 01-04 Taco so it might have already been there.
  20. Mar 24, 2019 at 1:53 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Shocks will be taking its place. Want cruise control lol. That’s going too
