Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Mar 28, 2019 at 5:04 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Well, what do you know? I accomplished my entire chore list today. It's a spring time miracle!
    Now if I can just keep the momentum going until tomorrow so I can pull the OGT's rear driveshaft and take her for a test drive on the interstate and see if my vibrations go away. If they do, then I have to put the front half back in and see if they are still gone. If they are, then I need to replace my pinion Ujoint and if that doesn't take care of it, I either need to find the rear half of the driveshaft at the salvage yard, or see if I can get the current one rebalanced.
    edit: Either that, or the DC joint is bad, but I don't even want to think about that.
  2. Mar 28, 2019 at 5:39 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Definitely need to have another Taco Tuesday. I'm taking a class M-F, so I couldn't make the last one.
  3. Mar 28, 2019 at 5:51 PM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    We are planning this up coming Tuesday in stuart
  4. Mar 28, 2019 at 5:52 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    In class again next week down south, so not sure yet.
  5. Mar 29, 2019 at 10:09 AM
    Taco No Baka
    Lee
    Tampa, FL
    :frusty:
    Good news is it's not my rear driveshaft causing the OGT to try to vibrate herself apart at interstate speed. I removed the rear driveshaft and test drove it on the interstate and the vibration is still there.
    Bad news is: I'm out of ideas as to what it might be. It has fairly new upper and lower ball joints, the LCAs are used off a 2001 2WD T4R and they looked alright when I installed them. The UCAs look okay as well. The steering is tight and the wheel bearings were good (I'm going to check them again because the last time I had a vibration this bad it was a front wheel bearing). I'm wondering if my coilovers might be blown out. They've taken enough abuse over the last five and a half years, but if you bounce on the bumper, the truck doesn't bounce more than once after you let go which usually indicates the shocks are good. The bushings on the bottom mount, on the other hand, do look a bit rough. I need to put 883s on her anyway for the winch install, so I may try getting a new set of coilovers.
    I hate shotgun troubleshooting. Anybody got any other ideas?
  6. Mar 29, 2019 at 10:35 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Tires out of balance or out of round? Wheel bent?
    TacoTRD78 likes this.
  7. Mar 29, 2019 at 11:12 AM
    Taco No Baka
    Lee
    Tampa, FL
    Brand new tires and wheels, dynamically balanced. It was vibrating with the old tires too, which i just put down to them being bias plies and damaged. The new tires ride buttery smooth up until about 60 MPH. I am going to swap them over to the T4R (where they belong anyway) to eliminate that possibility, but I think they are fine. I KNOW the T4R's tires and wheels ride smooth with a tiny vibration in the steering that comes and goes as the beads move around.
    Trident904[QUOTED] likes this.
  8. Mar 29, 2019 at 3:57 PM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    We're heading up around 10, just sent me a note with a ya or nay.
    Taco No Baka[QUOTED] likes this.
  9. Mar 30, 2019 at 3:08 PM
    Taco No Baka
    Lee
    Tampa, FL
    Just got back from Citrus. Had a great time today. Hopefully @GuyHuey will get the videos he took up soon. Weird thing is, I think this is the first time I've gone wheeling and the vehicle has no mud on it. Just a lot of dust. It's as dry as I've ever seen it out there. Even the water hole on the corner of 15 and 20 barely had any water in it. Still looked pretty soft and mushy, but if I had 35s I would have tried it.
    TacoTRD78 and GuyHuey like this.
  10. Mar 30, 2019 at 3:26 PM
    GuyHuey
    Guy
    Holiday, Florida
    Great time, I needed a day in the woods. Ill have the videos I shot up as soon as youtube can get them out there.
  11. Mar 30, 2019 at 3:29 PM
    GuyHuey
    Guy
    Holiday, Florida
  12. Mar 30, 2019 at 3:39 PM
    GuyHuey
    Guy
    Holiday, Florida
  13. Mar 30, 2019 at 4:05 PM
    GuyHuey
    Guy
    Holiday, Florida
  14. Mar 30, 2019 at 4:14 PM
    GuyHuey
    Guy
    Holiday, Florida
  15. Mar 30, 2019 at 4:17 PM
    Taco No Baka
    Lee
    Tampa, FL
    That new exhaust does sound really good in the video. That deep tone was exactly what I was going for. :thumbsup:
    Scooter WCT and Soul Surfer like this.
  16. Mar 30, 2019 at 4:44 PM
    GuyHuey
    Guy
    Holiday, Florida
    I was thinking the same thing, sounds great!
  17. Mar 30, 2019 at 5:18 PM
    Taco No Baka
    Lee
    Tampa, FL
    JK or JL? (or whatever the newest generation is called, lol.)
  18. Mar 30, 2019 at 5:41 PM
    GuyHuey
    Guy
    Holiday, Florida
    Oh, not sure. Most likely you're right. I may have named my son CJ, but I'm no Jeep expert.
  19. Mar 30, 2019 at 5:42 PM
    GuyHuey
    Guy
    Holiday, Florida
    I was impressed with how his bone stock Jeep performed. Aired down with a good driver would have been even more impressive.
    Taco No Baka likes this.
  20. Mar 30, 2019 at 6:12 PM
    GuyHuey
    Guy
    Holiday, Florida
    I reccomend some rocker protection and a good CB. Then for him to wheel it for awhile to see if that's what he wants to do. If he really wants to use it offroad and be happy or if he just wants to look cool are two different paths and one is much less $$$ than the other.
