Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Apr 22, 2019 at 9:13 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Definitely not prepared for how heavy this thing is.
  2. Apr 22, 2019 at 1:48 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Pics sideways.
    GuyHuey and Timbo's Customs like this.
  3. Apr 22, 2019 at 6:04 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Crazy thought. Why not get Todd’s treps @allenfab
  4. Apr 22, 2019 at 6:29 PM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    Because Interco tire snob status would be revoked.
    Taco No Baka likes this.
  5. Apr 22, 2019 at 6:34 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    True.
    :hattip:
  6. Apr 23, 2019 at 3:01 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    There's a couple other reasons too. Mainly, because they are radials, but they also aren't aggressive enough for my taste. IMHO, any dedicated trail rig should have bias ply tires. Granted, I don't trailer the OGT and I do use it as an actual pickup truck to haul stuff too big or dirty for Natty to haul, but half the mileage I put on the OGT is off-road...more than half if you count going to and from the off road location. For the little bit of pavement traveling I do with it, I can deal with the rougher ride from the bias plies.
    Now if only the new LCAs and the new coilovers cure that vibration I'm getting at 65-80 MPH, that will be half the battle right there. Haha, I'm going to be using the death sticks to compress the coils since I got these unassembled. I figure I'll either kill myself or conquer my fear of the things.
  7. Apr 23, 2019 at 3:44 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    @Timbo's Customs.... Tim I need to replace the power window lift motors in the 06 scion xb could you look at work and see if its the same part number? Im wondering if it is right,left ,rear ,front specific. I can only find front replacements and I need a driver rear thanks in advance.
  8. Apr 23, 2019 at 6:14 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    Don’t go back to work until the 1st
  9. Apr 23, 2019 at 6:27 AM
    TacoTRD78
    Stuart,fl
    Oh nice dude enjoy your time off, Hope everything is ok
  10. Apr 23, 2019 at 6:30 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    All good. Just burning up some vacation time
  11. Apr 23, 2019 at 6:31 AM
    TacoTRD78
    Stuart,fl
    Good for you enjoy it:cheers:
  12. Apr 23, 2019 at 6:43 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Looks like different part numbers:
    Driver front: 85720-32160
    Driver rear: 85710-52090
  13. Apr 23, 2019 at 6:43 AM
    Taco No Baka
    Lee
    Tampa, FL
    Are you cutting up that T4R for the tons? :cool:
    I guess I'm now qualified to build coilovers. I disassembled Natty's OEM ones for the top hats and assembled my new OME coilovers for the OGT and I still have all my limbs, appendages, and vital organs. Didn't even spill any blood. The death sticks were definitely bowed, but for some reason it seemed a lot less sketchy than watching someone else doing it.
    I should be getting my steering parts in today so I can get rolling on installing the new LCAs, coilovers, outer tie rod ends, and new steering rack boots. Then I hit the alignment shop, after which I can see if the vibration is gone. If it's not, then I don't know where to go from there other than starting over with a different truck, lol.
    TacoTRD78 likes this.
  14. Apr 23, 2019 at 6:57 AM
    TacoTRD78
    Stuart,fl
    Thanks lee, SOB them lil fuckers are outrageous. If i replaced all 4 its more than what I paid for the XB
  15. Apr 23, 2019 at 7:03 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    TacoTRD78[QUOTED] likes this.
  16. Apr 23, 2019 at 7:11 AM
    TacoTRD78
    Stuart,fl
    Thanks now that I have a part number I can cross reference and see if I can find them cheaper
  17. Apr 23, 2019 at 7:14 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    C'mon, join the radial world :D
    Timbo's Customs and TacoTRD78 like this.
  18. Apr 23, 2019 at 7:15 AM
    TacoTRD78
    Stuart,fl
    @Scooter WCT I might be making a trip to Lake placid If you wanna meet?
    Scooter WCT likes this.
  19. Apr 23, 2019 at 7:25 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    $50-ish on eBay
  20. Apr 23, 2019 at 7:30 AM
    TacoTRD78
    Stuart,fl
