Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Apr 23, 2019 at 7:34 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    window motor.jpg Score:yay:
    LMarshall73 likes this.
  2. Apr 23, 2019 at 7:35 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Sooooo, I noticed a funky hum the other day on my way home from Ft Pierce. I can't really hear it until I get over 55 and it's a different pitch than the rumble of the dirty-fives. Seems like my driver side front wheel bearing is going bye-bye. Looks like I'll be putting in an order with @BamaToy1997 in the very near future.
    BamaToy1997 likes this.
  3. Apr 23, 2019 at 7:39 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I already have. I'm running radials on Natty, being as she's a pavement princess and all. ;)
  4. Apr 23, 2019 at 8:49 AM
    BamaToy1997
    Bill
    Navarre, FL
    :headbang:
  5. Apr 23, 2019 at 9:24 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Lol. Radials hang with bias tires just fine. Tread pattern and tire construction aren't big factors imo for all-around off road performance
    Rattletrap66 likes this.
  6. Apr 23, 2019 at 9:40 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    allenfab[QUOTED] likes this.
  7. Apr 23, 2019 at 11:20 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
  8. Apr 23, 2019 at 12:28 PM
    Taco No Baka
    Lee
    Tampa, FL
    We'll have to agree to disagree on that one. :thumbsup: One of the very few points we do disagree on actually.:cheers:
  9. Apr 23, 2019 at 12:40 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    You'll have to come wheel out of state and actually find out :boink:
    FlyinRyan893 and allenfab like this.
  10. Apr 23, 2019 at 12:42 PM
    TacoTRD78
    Stuart,fl
  11. Apr 23, 2019 at 4:47 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    @Scooter WCT can you help this guy @Abumarf ,he’s having some issues getting his truck serviced, i told him you may be able to help him out.
    Scooter WCT, Abumarf and TacoTRD78 like this.
  12. Apr 23, 2019 at 5:59 PM
    Abumarf
    Abumarf Meep meep
    Hamza
    Tampa, FL
    2018 BR Wolfpack Edition
    I really would appreciate the help @Scooter WCT. PM me when you're not busy. Thamks
    Scooter WCT and NABeast like this.
  13. Apr 23, 2019 at 9:24 PM
    Taco No Baka
    Lee
    Tampa, FL
    Actually, I don't have to. Just look at what all the rock bouncers are running. If it's not an Interco tire, it's an agg tire (which still might be an Interco tire since they make agg tires too). There's a reason you don't see them running radials or even other bias ply tires.
    Here you guys go. Check this article out and see it changes your mind.
    https://www.pirate4x4.com/tech/billavista/PR-TSLs/
  14. Apr 24, 2019 at 3:21 AM
    TacoTRD78
    Stuart,fl
    It was a good read, however the only thing I can comment on is that is appears that the article is 13 years old. I believe the technology of tire manufacturing has changed.
    5 Lug Fury and Rattletrap66 like this.
  15. Apr 24, 2019 at 4:34 AM
    Taco No Baka
    Lee
    Tampa, FL
    Doesn't make it any less relevant. Sure, some radials are now using a layer or two of kevlar instead of polyester but the design is pretty much the same. I would posit that if any manufacturing technology has advanced, the advances could be used on bias ply tires as well. the cost thing is definitely a lot closer than it used to be, or even reversed, in the case of the Trepadors. They come in both radials and bias plies and the bias plies are hideously expensive compared to the radials.
  16. Apr 24, 2019 at 5:02 AM
    TacoTRD78
    Stuart,fl
    It comes down to what you are using the truck for is it offroad only or used for both on and off road. The reason why a lot of the buggies and rock crawlers use bias tires is because they are easier to make in a tire size of 42" or bigger. I dont think a bias out performs a radial. I just feel that is less acceptable sidewall damage at a low PSI.
    allenfab likes this.
  17. Apr 24, 2019 at 5:06 AM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
  18. Apr 24, 2019 at 5:06 AM
    allenfab
    Todd
    Lakeland, FL
    Billavista has the best articles in the industry.
    But to say "look at what the rock bouncers are running" isn't really saying much. I could say look at what the KOH/Ultra4 guys are running which is probably 98% your typical "mud" tire, both radials and bias, and only difference is that they are probably a sticky (which on rocks, is the real bread and butter choice).
    But from personal and first hand experience from the terrain that I have wheeled, there is no noticeable difference in any of the tires I have ran. Hell, frank ran all of the stuff I did at Black mountain (minus the rock garden) on a bald set of Toyo m/t's and I don't recall him even getting stuck in mud.
  19. Apr 24, 2019 at 8:14 AM
    Taco No Baka
    Lee
    Tampa, FL
    You're talking traction. All I'm saying here is that a bias ply tire will take more abuse than a radial. I'm not really addressing traction. Swampers come in radials too. In fact, there's a set of Interco radials on the OGT right now and, given how soft they are, they probably count as "Stickies".
  20. Apr 24, 2019 at 11:35 AM
    allenfab
    Todd
    Lakeland, FL
    I will raise your call and show you a pic of this year's 165 mile KOH 4600 winner on radial trepadors :luvya:
