Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Apr 24, 2019 at 11:56 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    :notsure: Good for him, even a broken clock can be right twice a day. I'm not seeing the point here. :luvya:
    Tell you what, when I rip the sidewall out of my bias ply tires more times than you have your radials, then I might entertain reconsidering my opinion. So far it's 0-1, my favor. :thumbsup:
  2. Apr 24, 2019 at 12:23 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    I seen those for sale at a local gun show this weekend. Cool looking, but while watching the video the guy had going they appeared very weak not even close to a real flashbang. In all seriousness my son had flashbangs from when he played airsoft that used those little CO2 canisters for BB guns and they seemed way louder.
  3. Apr 24, 2019 at 12:31 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Anybody in here good with transmissions? 2015 Tahoe 6L80 losing pressure after startup. Starts at 85psi and then works down to 20psi. Will go in gear with additional throttle but will not engage/roll when shifted in reverse or forward.
  4. Apr 24, 2019 at 3:06 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Touché :D
    But really though, interco always dicks around with their releases so don't hold your breath. I think the skinnier 36s would be a good substitute. More ground clearance will do more for capability than tire width.... In my opinion of course :cool:
    Taco No Baka[QUOTED] likes this.
  5. Apr 24, 2019 at 7:14 PM
    Taco No Baka
    Lee
    Tampa, FL
    I probably jinxed the hell out of myself with that last post, lol.
    I think 36x12.50s are a solid Plan B. Just worried that I might end up with the same problem I had with the Lincoln Locker if I go with 36s, but then it's entirely possible I could have that problem with 35s too.
  6. Apr 26, 2019 at 11:16 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
  7. Apr 26, 2019 at 11:46 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    When I was in Longview, TX a while back a guy had a Hudson Hornet for sale for $1500, including the trailer it was sitting on. The body looked cleaner than that Studebaker, but lord only knows what it would have cost to get it rolling on its own power...
    TacoTRD78[QUOTED] likes this.
  8. Apr 27, 2019 at 7:19 PM
    Taco No Baka
    Lee
    Tampa, FL
    :frusty: Seems like everything I do to the OGT anymore is backing up. Put the new 883 Coilovers on today and, while it might be my imagination, I might have a slight rake (with another 100+ lbs to add for the winch)...and I still have the :censored::censored::censored: vibration. Seemed a teensy bit better...maybe...but it's still mostly there. There didn't appear to be anything wrong with my LCA bushings, so I didn't replace them, but I guess that's all that's left to try. I do know for a fact that I lost some droop with the 883s. The UBJ doesn't hit the spring anymore at full droop. I figure it's all to the good though, to keep my CV angles at a minimum for the bigger tars.
  9. Apr 29, 2019 at 8:54 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Finally had an insurance adjuster come by to assess the hail damage from a few weeks ago. I didn't think it was that bad. I guess I was wrong. Most of these I hadn't noticed (thank goodness for a white truck).
    RF fender - 3 nickel sized dents
    R bedside - 4 quarter sized dents
    LF fender - 22 quarter sized dents
    LF door - 10 quarter sized dents
    LR door - 6 quarter size dents
    L bedside - 42 quarter sized dents, one large dent
    L A-pillar & roof rail - 42 quarter sized dents, one large dent
    L cab corner panel - 4 quarter sized dents
    Hood - no count, recommends replacement
    Roof - 170 quarter sized dents, one large dent
  10. Apr 29, 2019 at 9:57 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    So they looking at possible total
    TacoTRD78 likes this.
  11. Apr 29, 2019 at 11:11 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Nah. They gave me the assessment and a check to get it fixed. I'm just debating on whether or not to bother fixing it. None of the damage is that noticeable (again, white truck for the win). My brother does paintless dent repair so I'm going to send him the assessment to look over and see what he recommends.
  12. Apr 29, 2019 at 11:14 AM
    TacoTRD78
    Stuart,fl
    https://www.youtube.com/watch?v=PaXsJiOfYJo:notsure:
  13. Apr 29, 2019 at 11:16 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
  14. Apr 29, 2019 at 11:24 AM
    Scooter WCT
    Scooter WCT Well-Known Member
    Scott
    Wesley Chapel, FL.
    2014 DCSB TRD Sport 4x4 w/ 6speed Manual
    3" Lift using Bilstein 5100 Height Adjustable front shocks and complete rear Old Man Emu Dakar springs from Toytec, 17" 4Runner TRD Pro Series w/ 32" BF ATs, Tint and much more to come
    I was gunna reply earlier and say, Phhhhfft take the check and call it trail damage lol
    Timbo's Customs likes this.
  15. Apr 29, 2019 at 11:45 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    They made the check out to me and the bank, otherwise I would.
    Scooter WCT[QUOTED] likes this.
  16. Apr 29, 2019 at 10:46 PM
    Taco No Baka
    Lee
    Tampa, FL
    Replaced the OGT's LCAs today. Haven't taken her out on the interstate since I haven't got her aligned yet, but I suspect from the test drive I did around the block the vibration is still present. So I'm trying a "Hail Mary" and ordered a new set of bushings for my rear leafs, both for the front eye and for the shackles, bottom and top. I'm getting really sick of chasing this vibration issue and I'm running out of shit to replace. :bananadead:
    So far I've eliminated:
    --The rear driveshaft (and front since it doesn't turn anyway unless the hubs are locked)
    --the rear axle shafts
    --the rear third member
    --the tires and wheels
    --the upper and lower ball joints
    --the LCAs
    --the wheel bearings (front and back)
    --the rear brakes
    --the front coilovers
    --the steering rack bushings looked okay upon visual inspection when I had the rack loose to replace the LCAs
    I'm thinking about swapping my rear shocks from one side to the other when I replace the leaf spring bushings. Maybe the exhaust cooked the right one and damaged it internally. Not sure why that would cause a vibration, but apparently I can't rule anything out I haven't addressed already.
    Anybody got any ideas about where else to look? Have I mentioned I hate shotgun troubleshooting?:frusty:
  17. Apr 30, 2019 at 1:51 PM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    I haven't read all your issues, but is it constant or just at certain speeds? I ask b/c I didn't see the needle bearing on the list and I had that issue on front left axle. Vibration went away in 4wd, came back in 2wd.
  18. Apr 30, 2019 at 3:17 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Just put swampers on and let the tires make your vibration issue go away. Or just blame the tires at that point.
  19. Apr 30, 2019 at 4:54 PM
    Taco No Baka
    Lee
    Tampa, FL
    It starts to get really bad at about 65 MPH and goes away at 80 MPH. It wouldn't be a needle bearing because I have manual hubs so nothing is turning up there during normal pavement driving. I'm also not feeling it in the steering wheel so much as the seat.
    It may come down to that. I really wanted it to at least run smooth on radials so I could blame any vibes on the bias plies. I've never really had any serious issues with Swampers riding bad after they warmed up until the LTBs, which Interco told me was most likely because the LTBs were made with a harder compound. I figure the SX or SX2 would probably ride better...at least the set of SXs I had on my YJ before I went to Boggers rode great (so did the Boggers for that matter).
    Anyway, after I rebush the rear springs, if that doesn't work, I guess I'll have to throw in the towel and learn to live with it. It's mainly a trail rig anyway so I guess a smooth ride on the pavement isn't all that important.
  20. Apr 30, 2019 at 5:10 PM
    TacoTRD78
    Stuart,fl
    Lee maybe your seat is loose lol
