Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Apr 30, 2019 at 6:31 PM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    My old truck is good up to 74 mph. At 75 all hell breaks loose.
    When my front leaf bushings were worn out I would get a terrible death wobble at 30 mph.
    I guess the rear bushings could be a factor.
    Hopefully that fixes it.
    Taco No Baka likes this.
  2. May 4, 2019 at 5:44 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Teaser...
    IMG_20190504_193921935.jpg IMG_20190504_193947582_HDR.jpg IMG_20190504_194032155.jpg
    The poor OGT just keeps getting smaller and weaker. Although considering the plans and parts I'm stock piling, she might be just collapsing in on herself before going supernova, lol.
    I have to say though, I have no idea how Dom managed to cram 35s under his 3rd Gen T4R. While I did do a lot of trimming to make room for the 33s at full bump, they in no way, shape, or form, other than pointed straight ahead clear everything. I'd have to tub the floor boards/fire wall and move the washer reservoir. Instead, I'm going to be leaning heavily on the sway bar to limit articulation.
    I suppose I should start a build thread for Natty as well.
    Soul Surfer likes this.
  3. May 5, 2019 at 3:42 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    That's some dark ass tint how do you get away with that without the cops hassling you?
  4. May 5, 2019 at 4:52 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    If you want, you can have my washer reservoir that sits on the passenger fender (for either the runner or the Tacoma, can't remember if either have abs). Mine won't fit anymore
    Taco No Baka[QUOTED] likes this.
  5. May 5, 2019 at 8:35 AM
    Taco No Baka
    Lee
    Tampa, FL
    Dunno. The tint was on it when we bought it from ex-Spruce Taco. Maybe it's not as dark as it appears in the picture? :notsure:
    Cool beans. I'll take you up on that. :hattip:
    allenfab[QUOTED] likes this.
  6. May 6, 2019 at 3:09 PM
    Taco No Baka
    Lee
    Tampa, FL
    OGT Lite?
    Same OGT, just 100% lamer. :rofl:
    I think I pin pointed the vibration though. I still have to test it out on the interstate, but I think I might have put too much weight in the new 33s that are finally on Natty now.
  7. May 6, 2019 at 8:07 PM
    FlyinRyan893
    FlyinRyan893 Well-Known Member
    Orlando, FL
    15 TRDOR DCSB 4X4 6MT
    2" lift. 37s SCS F5s
    Woohoo! My diffs from ECGS have shipped! :bananadance::bananadance::bananadance:
    Timbo's Customs and Taco No Baka like this.
  8. May 6, 2019 at 9:01 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    What ratio did you go with?
  9. May 6, 2019 at 9:49 PM
    Taco No Baka
    Lee
    Tampa, FL
    I'm feeling something weird here (and no, I'm not drunk). I think I made a mistake with Natty's tires. I think I should have stayed with the 265/75R16s and just got the Trxus tires in that size. I don't think I've ever regretted going up in tire size before. :eek: o_O :facepalm: Those heavy 33s have severely impacted Natty's performance. She can't maintain interstate speed going up hill with out dropping out of overdrive and some times as low as 2nd on the steeper grades between North Tampa and Westley Chapel on I275. I'm not sure I can live with that, but the only solution is to regear a size or two lower or go back down to 32s. 32s would be cheaper and I was kind of impressed that she did as well as she did at Citrus on 32s. They would also clear better when stuffed.
    The OGT still vibrates. Not nearly as bad, but it's still there, just at an acceptable level that I can blame on the tires not being balanced perfectly. I think the weight of the front bumper magnifies any vibration by an order of magnitude for some reason.
    Natty now has a strong wiggle in the steering wheel at about 40-45, but goes away into a little vibration in the steering wheel at interstate speeds. I figure the strong wiggle is because the tires aren't rolling fast enough for the beads to settle in a balanced condition...probably because I used too many of them, since they are supposed to settle in at ~30 MPH or so.
  10. May 7, 2019 at 1:07 AM
    FlyinRyan893
    Orlando, FL
    4.56
  11. May 12, 2019 at 8:59 AM
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Ok who has the fish taco 5 lug? Merritt Island, Fl.
  12. May 18, 2019 at 7:37 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    What’s up :bananadead: <<<————- how it feels out
  13. May 22, 2019 at 3:08 AM
    Taco No Baka
    Lee
    Tampa, FL
    No disrespect, but, man, I bet those look like some pizza-cutters. The 265/75R16s the OGT is currently wearing look skinny as 'ell.
  14. May 22, 2019 at 4:48 AM
    trackdaybro
    trackdaybro Well-Known Member
    Yep tall skinnies was the goal. Looking forward to getting them mounted.
    16F6BDAA-77B0-436F-93F8-318B8B46B9CD.jpg 4B59298A-64DF-4FC2-B1E2-C99EBD4B39CF.jpg
    AR15xAR10 and Scooter WCT like this.
  15. May 22, 2019 at 5:26 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I was considering going the 255/85-16 route. I'd lose about an inch in diameter but gain a ton of wheel well clearance. If I didn't need new rims to go along with the tires I would have pulled the trigger.
    Scooter WCT likes this.
  16. May 22, 2019 at 11:52 AM
    trackdaybro
    What size rims do you have right now? They actually make a better selection in 255/80/17s!
  17. May 22, 2019 at 1:07 PM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    16x9. I'm not interested in doing a whole wheel and tire package. I was just looking at tires. I might drop back to 33's and call it a day.
  18. May 22, 2019 at 1:15 PM
    trackdaybro
    Ahh wide ones ya got
  19. May 25, 2019 at 11:37 PM
    Taco No Baka
    Lee
    Tampa, FL
    Still looks lame, but I'm finally moving in the right direction. :anonymous:
    snoope and ETsemaj like this.
  20. May 26, 2019 at 6:47 AM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    That looks awesome! I know you love them Interco tires. But that setup there, looks badass man.
