Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Aug 18, 2019 at 6:00 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I've only done a D35 (trice), D30, and a Ford 8.8. I cut corners on the 8.8 and it didn't last long, the D35 broke the threaded portion of the pinion under the strain of 1 ton u-joints, a Jeep 4.0 HO I6 and 16x35 Boggers, and the third time was because somehow, the u-joint was hitting the pinion nut and it backed off, but the D30 never had a problem.
  2. Aug 19, 2019 at 7:07 PM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Who knows how to replace rearend gears in a golf cart???
  3. Aug 19, 2019 at 7:08 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    @Timbo's Customs ;)
  4. Aug 19, 2019 at 7:10 PM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    Sorry for the dumb question but what's the easiest way to check for an exhaust leak? Not so much a hole but just making sure I clamped shit together tightly enough?
    Still new to wrenching certain things and exhaust install was one of them.
    Just like an air leak in a tire? Soap and water around joints?
  5. Aug 19, 2019 at 9:49 PM
    Taco No Baka
    Lee
    Tampa, FL
    It's sound mostly. There will be a ticking sound and you might be able to feel the hot exhaust coming from the joint.
    THE_KiRRAx[QUOTED] likes this.
  6. Aug 20, 2019 at 7:07 AM
    THE_KiRRAx
    Tampa, Florida
    Thanks for the tip mate. I just installed my new Borla exhaust and on the old system the flanges literally touched when bolted together, but with the Borla exhaust the flanges have about a 1/16" gap between them when torqued down. I just wanted to make sure it wasn't causing a leak at all, shouldn't be as the gasket is still installed. Just checking, thanks mate.
    I'll probably go check the bolts and clamps after a few days of vibrating around from normal driving, make sure it's all buckled up right.
  7. Aug 20, 2019 at 9:22 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    typically theres a gasket that goes in between the flanges for the exhaust. some are flat, some are ring like, and some are bowl shaped, really depends on the system. But you would know if there was an exhaust leak, I know on my truck Im positive my header to Y pipe has a slight leak because when I step on the gas I can hear an extra air noise and its there all the time; so I know it's not the manifold to cylinder head exhaust gasket
  8. Aug 20, 2019 at 9:56 AM
    THE_KiRRAx
    Tampa, Florida
    Yeah, I left the gasket there reusing it for the new exhaust (have a new gasket just in case though). I'll check again tonight to see if there is any air movement around the flanges but I didn't notice any, that small gap just had me iffy. For all I know Borla just didn't bore out the seat for the gasket deep enough, no worries as long as gasket is there I assume.
  9. Aug 20, 2019 at 10:19 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
  10. Aug 20, 2019 at 11:00 AM
    THE_KiRRAx
    Tampa, Florida
    @Timbo's Customs
    Heya mate, do you happen to fab sliders (bolt-on to be specific) by any chance? You're fairly close and are well known in the community for your work, figured I'd hit you up. Wouldn't need it for actual OR function, more so door protection without getting in the way like ugly ass steps do.
  11. Aug 20, 2019 at 11:46 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    Unfortunately I don’t have the stuff to cut the frame plates for bolt on. I do weld on only right now.
  12. Aug 20, 2019 at 11:58 AM
    THE_KiRRAx
    Tampa, Florida
    Alright mate, much appreciated for the response. I can understand that, plasmas/lasers aren't cheap.
    If I was to bring a pair of frame mount plates with me in the future, would you be interested in fabbing the tubing and slides themselves welded to my plates?
    I might be able to sweet talk my boss into letting me cut/form a pair here at work. I think I got that CAD file that's been lingering around the forums.
    If not it's all good, I could always buy prefabbed just looking to avoid those hefty shipping fees by staying local.
  13. Aug 20, 2019 at 1:01 PM
    rawlobst3r
    rawlobst3r Well-Known Member
    Tampa Bay FL
    2016 TRD SPORT
    Hi guys. Might have a deal lined up but figured I’d throw here as well just in case, and I don’t have enough age on my account to BST section.
    Just picked up my diamondback se coated in line-x, short bed but think I want to go another route.
    Looking for 1500obo or more so even a trade for wheels and tires. Looking 285s with wheels similar to scs, fn, level 8 etc.
  14. Aug 21, 2019 at 9:48 AM
    taco8603
    taco8603 Well-Known Member
    Philip
    Kenneth city Florida
    2019 White Tacoma DCSB SR 4x4
    lt265/75/16
    IM BACK
    Taco No Baka and Soul Surfer like this.
  15. Aug 21, 2019 at 9:50 AM
    THE_KiRRAx
    Tampa, Florida
    The one, the only, THE LEGENDARY!
    Who are you again? lol
    Smiley52 and Soul Surfer like this.
  16. Aug 21, 2019 at 10:07 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR
    Hey Philip :wave:
    taco8603[QUOTED] likes this.
  17. Aug 26, 2019 at 11:38 AM
    Taco No Baka
    Lee
    Tampa, FL
    Bought my rear bumper and my winch mounts today. :D
    XofRu6PgM4q1htxGdBjLsvzvT57v9t9M4ntUS7JF_16165c6cb68d630953265846c028b1f09ecda01e.jpg
    VIBNbiIpP70qegYIWksZNPy1L22vmfI9k9r1p8ii_0707f8b8e7a3ed048944c209acdd768b4517ffbe.jpg
    ejFv5FC6C4H8NyrYHOGV6V9VtlHOnQpAUdbgjE-S_8482d683a19db65391805cd9f8b7c9d91994ca53.jpg
    Now I just have to build them. :sawzall::welder::bananadead:
    Oh, and the new axle seal I installed yesterday is leaking again. I'm starting to think it might be the CV axle. I'm going to switch the CVs side to side and replace the seal again. If the passenger side starts leaking, I'll exchange the CV for a new one.
    rblalliance, TacoTRD78, Alfuh and 2 others like this.
  18. Aug 26, 2019 at 2:41 PM
    rawlobst3r
    Tampa Bay FL
    2016 TRD SPORT
    Got everything installed. What a bitch doing the heavy leafs in the back was solo.
    I think it turned out great. I didn’t take pre and post measurements but it’s gotta have given over 3 in the back with no weight just based on how high my tailgate sits now and I’m guessing 2-3 in the front. I really like it still sitting with a little rake.
    TacoTRD78, Scooter WCT, Alfuh and 2 others like this.
  19. Aug 26, 2019 at 3:06 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    dont forget everything is gonna settle in, give it about a week or so then check it again, it'll most likely go down anywhere from 0.25"-0.5"
  20. Aug 26, 2019 at 3:27 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Nice man decided to tackle it yourself. I see more pride in looking at something, saying I did that or I built that.
    Looks great.
