Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Aug 4, 2020 at 8:58 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I just checked my RMR with a strip of electrical tape covering the fiber optic. The tritium is still good enough for low light (I keep the FO partially covered with tape anyway because it blooms like a MF'r in bright sunlight). I bought it back in 2010, so 10 years old and still glowing.
  2. Aug 4, 2020 at 9:00 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    The half life of tritium is 12.5 years. So, 12.5 years after it's manufacturing date it'll be half as bright as it was before.
  3. Aug 4, 2020 at 9:04 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I got my 96 from a coworker that bought it in 2001. 19 years later they are deader than dammit.
  4. Aug 4, 2020 at 9:06 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    That's fine with me. In low light, the fiber optic will still be "assisting" the tritium. In complete blackout? Tritium would be the least of my worries.
  5. Aug 4, 2020 at 9:08 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I think this is the way to go.
    The HS507C is an open reflex optical sight designed for pistol applications. Features include Holosun's Super LED with up to 50k hours battery life, Multi-Reticle System, Solar Failsafe, and Shake Awake. In the Box. Picatinny Mount.
  6. Aug 4, 2020 at 9:21 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I've been looking at that one a little. I prefer to have an optic directly mounted to the slide instead of a picatinny. Right now I'm limited by the footprints that can be milled into the slide. It does look like the 507C fits an RMR footprint, so if it sits low enough to clear suppressor height sights it could be a viable alternative. Of course, I'd have to make sure it can survive on a pistol slide where the RMR has a proven track record. My RMR has survived multiple classes and thousand of rounds with zero issues.
    [​IMG]IMG_3715 by Lee, on Flickr
    [​IMG]IMG_1005 by Lee, on Flickr
    [​IMG]7238971968_6eed01136a_h by Lee, on Flickr
  7. Aug 4, 2020 at 9:22 AM
    TacoTRD78
    Stuart,fl
    Comes with a picatinny mount capable of mounting to the slide I believe
  8. Aug 4, 2020 at 9:28 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    It looks like the sight can be removed from the picatinny and mounted straight to the slide.
  9. Aug 4, 2020 at 9:33 AM
    Taco No Baka
    Lee
    Tampa, FL
    In the mean time, I can live with changing the battery every time I rotate mags. It's not like I go that many places.
    I'm going to get an RMR for my 96. I'm also going to do some custom gunsmithing on the forward frame so I can put a pic rail on it to mount a Streamlight TLR-1s on it and the will be my bedside weapon. Assuming it shoots worth a shit. If not, I'm going to have to either trade it for a full frame Sig, or source a new (hopefully stainless) barrel for it. That could be a problem since not even Beretta makes barrels for it anymore.
    The PX4 will be my carry weapon.
  10. Aug 4, 2020 at 9:33 AM
    TacoTRD78
    Stuart,fl
    Thats what I meant you just have to buy the plate milled to holosun. They are great sights long battery life and the solar panel is a nice touch
    LMarshall73[QUOTED] likes this.
  11. Aug 4, 2020 at 1:35 PM
    Taco No Baka
    Lee
    Tampa, FL
    Any of you guys practice your draw and dry fire in front of a mirror? I figure I'm going to do so 100x a day until I get my sight picture perfect. Don't know anywhere around here that would let you draw and fire a live round, CCWL or not.
    Edit: That guy in the mirror is a dead mudder trucker though. :rofl:
    TacoTRD78 and Front sight like this.
  12. Aug 4, 2020 at 1:49 PM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I do, just not as often as I should. Any time I take a class I'm one of the fastest students, so I'm not too concerned. I've been carrying the same way (appendix) for a little over 20 years, so it's really a reflex at this point. When I took my first point shooting class, we would rock the pistol back as soon as it came out of the holster and start firing as we brought the pistol to eye level. Nine times out of ten, by the time I have sight alignment on target it's time to reload. With enough practice (and if you do it right), you end up with a string of bullet holes from bellybutton to forehead.
    YotaOverAll and Front sight like this.
  13. Aug 4, 2020 at 8:44 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I have several times. Not lately though..
    Taco No Baka[QUOTED] likes this.
  14. Aug 5, 2020 at 6:51 AM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    I got one of the laser pointer rounds in a kit that has a phone tripod, targets, and such that I use in my EDC regularly. I do not recall the brand, am at the office now, but I think it is "Laser hit" or something like that. There are several out there and the one I picked up is available in several calibers, and seemed to be the best as far as reviews that I saw indicated. It allows use of almost any target with dry fire practice from holster or any situation you like. The laser round also has worked well with any dry fire app I have tried to date.
    I use it far less than I probably should, but I can also say using several different apps to record hits and ratios...my time to fire, groupings, and multiple target accuracy has definitely improved.
  15. Aug 7, 2020 at 8:43 AM
    kaijac03
    kaijac03 Well-Known Member
    Kai
    Florida
    2017 Tacoma, TRD Off Road
    Hi all,
    please have a look at the company I created to help fight for nature conservation and land use for recreation. Please also share through any channels that you use for your Toyota and Off-Roading passion.
    www.offroadyota.com
  16. Aug 7, 2020 at 4:00 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Nice job! I’ll be ordering a couple decals from ya for sure
    kaijac03[QUOTED] likes this.
  17. Aug 10, 2020 at 11:52 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Guess who's back on the group!!! Once I'm done modifying the driver side header to clear the steering shaft, I can then drop the engine in.
  18. Aug 13, 2020 at 5:42 PM
    Meatloaf
    North Florida
    Controlled burn at Tyndall AFB this weekend.
    Resized_20200808_132443.jpg Resized_20200808_133225.jpg Resized_20200808_132948.jpg
  19. Aug 13, 2020 at 8:14 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Soul Surfer and f86sabjf like this.
  20. Aug 16, 2020 at 2:08 PM
    Meatloaf
    North Florida
    Pulled up to the local FD because one of the guys had a real nice 3rd gen sport. Asked if my son could check out the fire trucks and they said absolutely! Son had a blast and even though he's a little shy he hasn't stopped talking about it. Thanks Springfield FD!
