Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Aug 30, 2020 at 3:21 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    I thought it was a Detroit, maybe it was the camera. When i was following you I didn’t see anything strange. Just thought id ask.
    Taco No Baka[QUOTED] likes this.
  2. Aug 31, 2020 at 11:41 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I had a thought a little bit ago while considering this video. If I had big enough stones, I bet if I could hit that first hump fast enough, I could probably clear the top of the wall, straight up rock bouncer-style. I don't think my stones are that big though, haha.
  3. Aug 31, 2020 at 12:07 PM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Maybe, but the landing would probably knock your stones into the back of your throat!:rofl:
  4. Aug 31, 2020 at 12:49 PM
    Taco No Baka
    Lee
    Tampa, FL
    If done right, I think the the suspension would easily absorb the landing. If it's not done right is what I'd be worried about. Doing a face plant squarely into the wall would pretty much be a head-on collision with the ground and my air bags have been off-line since I attempted that mudhole on the corner of 15 and 20 while it had 40" of water in it so I doubt I'd survive the experience.
  5. Aug 31, 2020 at 12:58 PM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Even better reasons not to try.
  6. Aug 31, 2020 at 1:16 PM
    Taco No Baka
    Lee
    Tampa, FL
    Haha, you don't have to convince me. I think the OGT could do it, but it's beyond my skill level and the consequences of not getting it just right are too big a risk.
  7. Sep 1, 2020 at 8:59 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    While I’d love to see that, that would probably mark the end of the ogt forever lol
    Timbo's Customs likes this.
  8. Sep 1, 2020 at 10:45 AM
    Taco No Baka
    Lee
    Tampa, FL
    Only if I screwed it up, which is highly likely, lol. If done right it would probably land pretty softly on the top.
    That said...Is anyone out there interested in a hydraulic winch that came off of a roll back wrecker?
  9. Sep 2, 2020 at 12:05 PM
    Taco No Baka
    Lee
    Tampa, FL
    So...I discovered a most peculiar thing yesterday. After driving an hour and a half or so home Sunday, presumably on just my battery, occasionally having to use my windshield wipers because I got rained on hard several times and had to stop at a bunch of lights, I pulled in the driveway with the ScanGauge reading 11.5v. So yesterday I went out and put my multimeter on the battery to see how far it was down and discovered it to be completely charged at 12.5 volts. I still put the battery charger on it and after charging most of the day, the battery was still at 12.5 volts. So I started the truck. The battery light was still on and the Scan Gauge was reading 11.9v while the multimeter was reading about 12.1 at the battery while the truck was running. I was tempted, but I didn't disconnect the battery to see if the truck would stay running so I can't say for sure, but the only explanation I can come up with is that the alternator is actually working, though at a diminished capacity. It's very weird that the battery was fully charged though.
    I'm going to take the alternator out and clean it with electronics cleaner then have it tested (I don't want to play the take it out and put it back in several times until it works game). If It works I guess it'll go back in. If not, then I've got a new one on the way that I'll stick in the T4R if it turns out I don't need it. This is a 105 amp alternator out of a Suzuki Grand Vitara so it would be an upgrade for the T4R.
  10. Sep 2, 2020 at 4:01 PM
    allenfab
    Todd
    Lakeland, FL
    I’ve had the same happen on my 02 tundra. Battery light on, scangauge reading low, but a new alternator fixed the problem. Same situation caused it too... mud/water
  11. Sep 2, 2020 at 4:22 PM
    Taco No Baka
    Lee
    Tampa, FL
    Haha, probably the same Scan Gauge too. I just can't figure out how the battery remained fully charged. :confused:
    allenfab[QUOTED] likes this.
  12. Sep 2, 2020 at 4:50 PM
    allenfab
    Todd
    Lakeland, FL
    No clue. Maybe it’s just the voltage sensor in the alternator that sends the reading to the computer went bad, while the alternator itself is still charging at full capacity.
    I noticed today that one of my rear bump stops is missing.... ripped right off the base
  13. Sep 2, 2020 at 4:57 PM
    Taco No Baka
    Lee
    Tampa, FL
    Doesn't explain the multimeter reading though. You lost a bump stop? Geez, and you weren't even the one airing it out. :rofl:
  14. Sep 2, 2020 at 5:28 PM
    f86sabjf
    f86sabjf Well-Known Member
    Jeff
    Deltona, Florida
    2020 Trd sport
    If any of you runs across a topper for a shortbed please pass it along to me . I have a 2020 sport 4x4 in black . Would like a new one but that’s just out of range. Craigslist and fb marketplace have been pretty lean over on the east coast side for me.
  15. Sep 2, 2020 at 5:44 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Put a shout out in the FL classified thread. Maybe someone has seen something.
    f86sabjf[QUOTED] likes this.
  16. Sep 2, 2020 at 5:46 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I think the alternator is working, but not to full capacity. The meter should be in the high 13V range with it running, unless the battery had a bad cell, but since yours seems strong I don’t think that is the problem. I would clean it as good s you can and test it to see any changes, keep us updated on what you find.
  17. Sep 2, 2020 at 6:08 PM
    Taco No Baka
    Lee
    Tampa, FL
    Exactly. Before Sunday, the Scan Gauge was reading between 13.9 and 14.2, depending on the loads. That was both with the adapted 105 amp Suzuki alternator and with the factory 60 amp.
    I'll definitely let you know what I figure out. If I manage to save it, I might put it in the T4R and throw the stock T4R alternator in the tool box on the truck for a trail spare. This is twice now my ride has been cut short by an malfunctioning alternator and they aren't that hard to change. I'm also going to revisit my splash guards. When I made them, I forgot to add 2" to the part that goes over the shock tower, so I'm thinking about putting a piece of thin guage metal in there to give the alternator better protection. Have to do the other side too. I actually have clay piled up on my passenger exhaust manifold.
    NABeast[QUOTED] likes this.
  18. Sep 15, 2020 at 7:33 AM
    You Suck I Suck More
    You Suck I Suck More Well-Known Member
    Meatloaf
    North Florida
    2017 Super White DCSB TRD OR
    Your parents' favorite Airman
    Apparently the rain was too much to handle for someone driving by my house last night.
  19. Sep 15, 2020 at 2:02 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Looks like an oil slick on top of the water.
  20. Sep 15, 2020 at 2:03 PM
    Meatloaf
    North Florida
    I wouldn't be suprised if whoever is responsible lost some fluids
    Grey 2015[QUOTED] likes this.
