Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 25, 2020 at 9:46 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Couple things I forgot to mention...
    To find out if a powder you want to use in ammo you plan to store has a copper deterrent, you have to contact the manufacturer and ask, if it doesn't say so on the bottle.
    And then there's load development. If you're loading for accuracy, I usually load ten rounds of each load and fire them in 5 shot groups and I try to separate the groups by firing other 5-shot test loads between them. I feel this gives me a better picture of how the load performs when I take a measurement of the two groups and average them before comparing them to other test loads. It's a long process and puts a lot of wear on your barrel, but as long as you're not shooting Benchrest for Group, it's not that big a deal. There is another method that is supposedly much quicker that I'm trying with my 6.5 CM, but it's complicated, requiring a chrono and an Excell spreadsheet. I haven't really gotten the results, partly because I've only done the first part and partly because my data is tainted by those crappy match grade primers.
    Anyway, once you have some data, you can take the two or three best loads and load a bigger test batch...the more performance data you have the more the best load for your rifle will stand out.
    Edit: You'll want a vibratory tumbler too for cleaning your brass. I use untreated corn cob media on my fired brass before I start any thing else. Clean brass=clean dies=better sizing. After I have completed resizing/decapping, trimming, and everything else and the brass is ready to be primed, charged and loaded, I'll run the brass through the tumbler again with treated crushed walnut shell media. By treating, I mean it has a polishing compound added to it. Flitz works really good, but a lot of people just use car polish because it's cheaper. This puts a nice polish on the brass and gets rid of any remaining case lube or contaminates that might have gotten on the cases during the process.
    Gearheadesw[QUOTED] likes this.
  2. Dec 26, 2020 at 7:10 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Whew, like I said, I don't know where to start.
    I'll build a bench, take pictures, go from there. I couldn't get your pictures to come up on my computer....
    I used to be fine with buying ammo online, but that's a thing of the past apparently. I'm no where the shot I used to be, I don't know if I'll be able to see the differences in such little adjustments in my shooting I do now. I just really want to see what the 2nd part of shooting part of shooting is all about, and build up my inventory again.
  3. Dec 26, 2020 at 11:21 AM
    Ulfr
    Ulfr Well-Known Member
    Tampa, FL
    2019 DCSB 4x4 Manual
    Well truth be told you're going to have a very hard time finding primers and powder right now. Probably the best thing for you to do is start to reload pistol ammo.
    Pistol ammo is really simple compared to rifle ammo. I can't tell what dies you have. And if you're going to reload once fired brass you're gonna need a tumbler. Really there is no point in reloading of you're going to buy new brass.
  4. Dec 26, 2020 at 12:29 PM
    Gearheadesw
    Davenport Fl
    Here's where I work on my firearms, I could build a new unit, and make the storage available directly behind in the book shelf for supplies.
    I've had several carts loaded with stuff on several different sites, brass, powder, bullets, primers, and there is no savings to be had at the beginning. I'm just really intimidated about this reloading for some reason. Everyone says different stuff, the book says one thing is to fallow the book, no matter what. Then I read of all the different things people do.... just totally lost.
  5. Dec 26, 2020 at 1:02 PM
    Taco No Baka
    Lee
    Tampa, FL
    Haha, I disagree with this. For one thing, I don't handload my rifle rounds to save money. I do it to tailor the ammo for the best performance in my rifle. I reuse my rifle brass because it's easier to recover (brass catcher on my AR and a bolt action rifle for the 6.5 CM). I buy the first batch new because at least I know where it's been then I reload it from there. Plus, with the 6.5 CM the brass is fire formed to fit my chamber exactly and I only neck size until they become difficult to chamber before I body size them.
    For my pistol ammo, I just buy new brass because it's a pain in the ass to pick up your brass from the pile of everyone else's, and since most indoor ranges don't allow reloads, it's a red flag for them if you're collecting your brass so it makes it harder to smuggle in your handloads. I worked it out once and found it was costing me about the same to load 100 rounds of pistol ammo using Hornady XTP bullets as it cost me to go buy a 100 round box of crappy pinking ammo. The upshot is, my reloads were of the same level of quality as a 20 round box of Federal Hydra-shoks or any of the other expensive high performance ammo sold in 20 round boxes. Plus the powder I use burns cleaner. So I was money ahead, even buying new brass every time. I suppose if I just bought cheaper FMJ pistol bullets it would be cheaper than the cheap blasting ammo, but they are also used for home defense.
    Also, I find loading pistol ammo to be more complicated than rifle ammo barring the extra prep I do on my rifle brass. Pistol ammo has to be tamper crimped which adds another step to the process and it's a critical step since semi-auto pistol rounds head space off the case mouth. With most rifle ammo, which in most cases head spaces off the shoulder, the neck tension on the bullet is sufficient to hold the bullet in place.
    BTW, I usually load a dummy round for each bullet I shoot regularly to simplify setting up my dies when loading for different bullets.
    If you're willing to work around it, you could mount the press on the right corner there and just mount your case trimmer on a block of wood and clamp it to the table when trimming. You're powder measure has a stand you can use or you could mount it to the wall. For that matter, Lowes sells furniture inserts for up to 3/8 bolts and they have hand tightening knob bolts so you could install the inserts and take your press off the table fairly easily with no tools required. Could do that with the powder measure too.
  6. Dec 26, 2020 at 1:34 PM
    Gearheadesw
    Davenport Fl
    No, still just little blue question marks for the pics. Thanks on saying that about the table, I was thinking use my existing table, it's study as hell, I can move things here and there depending on what I'm doing. I need to unbox everything and just start, take pictures, and look for guidance. Please bear with me, I suck on the computer, but really want to get going on reloading, I obviously need help, and it's here. Thank you.
    I've unboxed everything, and have looked at videos, read all kinds of stuff, and still have no clue what to do here. No real instructions anywhere, completely discouraged. I can't find anything that looks like my shit, almost done with this again.
  7. Dec 26, 2020 at 3:44 PM
    Taco No Baka
    Lee
    Tampa, FL
    It doesn't really matter if the equipment looks the same. It all serves the same purpose. my set up...3rd time is the charm...
    Don't get to frustrated. Just downshift into a lower gear and grind it out, haha. It's a methodical process.
  8. Dec 26, 2020 at 4:44 PM
    Taco No Baka
    Lee
    Tampa, FL
    these two videos are about as basic as you can get, but he explains the basic process very well.
    https://www.youtube.com/watch?v=LttBArZcQ9g
    https://www.youtube.com/watch?v=yQVpuY9WV60
    The only differences you'll have with your equipment is that you will only need to set your dies up once and leave then screwed into the turret of your press. The exception being is that you'll have to reset your bullet seating depth for different bullets you try.
    Another difference is his priming tool. You can get one like that if you want. Supposedly it is easier and faster, but I like using priming feature on my press because I figure that hand primer will cause a lot more hand fatigue than the press primer if you're doing a hundred or more cases at a time. You should have a primer tray similar to what he had with ridges so you can shake the tray lightly until all the primers are faced the same way. With my press primer, you'll have a tube the primers sit in and in my case I have to put the cover on my tray and turn it upside down. Then with all the primers outside up, I use the tube to pick them up one at a time. the tube should have a little plastic end on it that will grip the primer by pressing the tube down on it. The tube also has a little grasshopper clip that keeps the primers from falling out when you turn the tube over to put it in the press fixture. Once the tube is in you can remove the clip and use it to press the last primer in from where it's held by the plastic gripper. This is why the hand tool is faster because you don't have fool with loading the tube. However the leverage you get out of the press when seating the primer makes it light work as opposed to having to squeeze that hand priming tool for every case.
    What he doesn't show you is the case mouth chamfering and deburring you need to do before sizing the case. Or cleaning the primer pocket, but like I said, this is reloading at it's most basic.
    And do yourself a favor and get a set of digital Mitutoyo calipers with a large display. It makes reading the measurement a lot faster and less prone to mistakes.
  9. Dec 28, 2020 at 5:34 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Does anybody have a stout spring compressor for sale rent or borrow? I want to install my 14-in 700 lb springs and what I've got doesn't seem to be up to the task, and what you can rent from the Auto Box stores is definitely not up to it.
    @allenfab
    @Timbo's Customs
  10. Dec 28, 2020 at 8:56 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    All I’ve got is the cheap autozone one as well.
  11. Dec 28, 2020 at 10:08 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I had my old man emu’s done at a local Firestone broke the spring compressor but it was like $20
    5 Lug Fury and Taco No Baka like this.
  12. Dec 29, 2020 at 3:00 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
  13. Dec 29, 2020 at 3:34 PM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    Anyone ever go to the Dade City gun club/range? Thinking of going tomorrow and looking for an outdoor range.
  14. Dec 29, 2020 at 4:01 PM
    Taco No Baka
    Lee
    Tampa, FL
    I was there a few weeks ago. It's okay and the ROs are friendly, but the Wyoming Antelope Club in Clearwater is a much nicer range. Plus I'm not fond of the rifle benches at Dade city. They seem to be made for much bigger people than me, lol. Dade City might be a little closer to you, but from Tampa Palms, I think it would be worth the extra drive time to shoot at the WAC.
    I live in North Tampa, between Busch and Fowler and it seems like I can get to Clearwater faster than Dade City so it's really a no brainer for me.
  15. Dec 29, 2020 at 4:05 PM
    crackils
    Shane
    FL
    Good to know, I'll check out WAC, thanks for the info :thumbsup:
  16. Dec 31, 2020 at 10:13 PM
    Taco No Baka
    Lee
    Tampa, FL
    Happy new year, y'all!
    GuyHuey and kaijac03 like this.
  17. Jan 1, 2021 at 7:41 AM
    TacoTRD78
    Stuart,fl
    Happy New Year
  18. Jan 1, 2021 at 8:41 AM
    Gearheadesw
    Davenport Fl
    HFNY everyone.
    If your neighborhood is like mine, out in the old citrus groves, the new years at midnight is like a battlefield, guns going off all over the place, along with the fireworks.
    Key-Rei likes this.
  19. Jan 5, 2021 at 12:15 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    so FB popped up with this memory, can't believe it's been 7 years since that 1st citrus meet I went to. oh how she had changed haha, also got big plans for the Tacoma here this year! BIG plans
  20. Jan 5, 2021 at 8:13 PM
    Key-Rei
    Key
    Florida
    So when's the next Florida meet?
