Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Jan 19, 2021 at 7:49 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The possibility of a split case, squib, or accidental double charge make me nervous, that's why reloading isn't for me.
    I still haven't "grown up" and graduated to accuracy practice. I still like my tacti-cool toys and mag dumps. As much as I do actually try to practice the fundamentals... Yeap.
    I wanna be able to trust my ammo so I buy mass production stuff since I'm too ADHD to trust myself or enjoy reloading.
  2. Jan 19, 2021 at 7:57 PM
    Key-Rei
    Key
    Florida
    Yeah probably not, but I've always wanted one (Scar fever) and knew I had to have one after shooting one.
    Not particularly fond of M1A pattern rifles, just not modern enough for me I suppose. Though I did consider a scout for a little while or even an EMR chassis I'm not crazy about Springfield and their practices.
    And I just don't like the AR platform, probably just cause everyone has one and I wanna be different, or I just feel like it's not as good... I dunno, haven't been able to put a particular finger on why I don't like ARs.
    I guess I just want a modern gas piston rifle I feel like I can trust.
    LMarshall73 likes this.
  3. Jan 19, 2021 at 8:42 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Meh, everything I load for it's impossible to double charge with the powder I use. There's not enough case capacity for it. And I will confess, I do try that sometimes if I get distracted and forget to move the funnel to the next case after I dump a charge. It gets messy from there since I have to get the case and the funnel up to the powder hopper to dump the powder back in without lifting the funnel off the case and spilling powder everywhere.
    With my 6.5 CM with the heavier 130-140gr bullets seated .020" of the rifling, the higher pressure loads are damn near compression loads. I can just barely hear the powder moving around the shoulder area when I shake them next to my ear. The 107-123gr bullets leave a bit more case capacity. The .223 rounds are more forgiving since the heaviest bullet I'll load is a 69gr, which is the heaviest that will fit in the mag. If I wanted to single feed the rounds by hand, I'd get a bolt action, haha. Anyway, the rifle doesn't like 69gr bullets that I can tell. I think it's because with the 18" barrel I'm not getting enough muzzle velocity for them to stabilize even though the 1:8 twist barrel should support them. I've basically narrowed it down to using 60gr Sierra Ballistic tipped Matchkings for 100 yards and out and 55gr Sierra Blitzkings for under 100 yards (and home defense since they are hunting bullets made to expand "explosively" after impact).
    On the other hand, it's easy enough to take a flash light and check to see all the cases in the loading block have a powder charge before seating a bullet in them. Split cases necks are easy enough to check for after sizing (and it will be really apparent if you seat a bullet in a split case mouth) and if you anneal before every fourth or fifth loading, it shouldn't be much of an issue. And who doesn't like using a burns-o-matic and power drill at the same time? :cool:
  4. Jan 19, 2021 at 8:50 PM
    Taco No Baka
    Lee
    Tampa, FL
    There's always the Ruger Mini 30. Although it is based on the M1 Garande action so it's not exactly cutting edge, nor is it as customizable. It would probably survive any bans though.
    I wonder if they are offering the SCAR in 6.5 CM? I would imagine FN is in the process of making them in that caliber for the US Military as we speak.
  5. Jan 19, 2021 at 9:10 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    G3 (ptr) or the FAL are also proven designs
    Taco No Baka likes this.
  6. Jan 20, 2021 at 5:45 AM
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    What's up y'all.
    If you have been interested in getting OVtuned but haven't had someone near you, I am doing a limited "Tour De Florida" mid february.
    From February 16th - 21st, I will spend one day in Gainesville, Tampa, Ft. Myers, Ft. Lauderdale, and Orlando.
    Message me if you want to commit to meeting up. If you are closer to Jacksonville, hit up @G8R_Taco
    G8R_Taco likes this.
  7. Jan 20, 2021 at 6:01 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    What we are seeing now is why I leaned more towards buying ammo and paying for training instead of buying new guns for the past few years (aside from the C308 and 308 bolt gun, but I bought a case of 7.62x51 M80 when I bought those). I'm good on 5.56, 9mm, and I've got enough 7.62x39 and 7.62x54R to last pretty much through the siege of Stalingrad. :infantry:
    TacoTRD78 and GuyHuey like this.
  8. Jan 20, 2021 at 6:18 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Morning, so I just moved to the panhandle and working on get my driver license transferred to here. Anyway, are there any decent gun stores near Milton? Also looking for a ccp class for wife and I. Any suggestions would be helpful? Thanks
  9. Jan 20, 2021 at 6:54 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I've got a couple of Mosin Nagants (one a 1939 vintage, the other a 1944). They are great for pot shots 2000 meters away. Or if you need to bayonet someone on the other side of a river.
    lucky13don and 5 Lug Fury like this.
  10. Jan 20, 2021 at 7:05 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Ive got a few of those, the carbine makes a great improvised flamethrower when fired at night.
  11. Jan 20, 2021 at 7:06 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I cut an M44 (back when they only cost $79) down to 16.5". People at the range don't like me.
    Key-Rei and lucky13don[QUOTED] like this.
  12. Jan 20, 2021 at 7:16 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    My ears hurt just reading that...lol. looking back now, i should've bought crates of mosins when they were 500 bucks..
  13. Jan 20, 2021 at 7:21 AM
    Key-Rei
    Key
    Florida
    I really should get an M44 just cause *Boog? Grab nugget go innawoods* memes.
    Running a bolt gun fast is fun as hell especially when you got not bad feelings about beating the ever loving frigg out of it.
    Shot a mosin a good couple times, I like the positive recoil, got pretty good with the pitted and shot out barrel.
    Used to be able to get them for $200 for a decent one, they're close to $500 for an okay one now.
    lucky13don likes this.
  14. Jan 20, 2021 at 7:24 AM
    Key-Rei
    Key
    Florida
    When it needs to be shot, blinded, deafened and set on fire all at the same time.
    OBREZ
    46b9608e26f8f35d6bc5ff87a130d051.jpg ab37960969788a460115a957bfeec0d1--bang-bang-hunting.jpg
  15. Jan 20, 2021 at 7:25 AM
    Key-Rei
    Key
    Florida
    More than a SCAR17 I want a CZ Bren 2 .308 they make them, they just haven't imported any yet as far as I know.
  16. Jan 20, 2021 at 7:33 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Another fun one is the nagat 1895 pistol, got a couple of those too. Real quite and a good host for a can.
    Key-Rei[QUOTED] likes this.
  17. Jan 20, 2021 at 7:35 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    I kinda want one..
  18. Jan 20, 2021 at 7:36 AM
    Key-Rei
    Key
    Florida
    The revolver? Really? That cylinder gap looks MASSIVE. :eek:
    Figured you'd get plenty of sound leak there.
    But Google may have also failed me.
  19. Jan 20, 2021 at 7:37 AM
    Key-Rei
    Key
    Florida
    Me too but I like my nose and wrist intact and I just know that things going to break a wrist and smack me in the face.
    lucky13don[QUOTED] likes this.
  20. Jan 20, 2021 at 7:38 AM
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I wasn't a big fan of PC gaming until a friend turned me on to Escape From Tarkov. The mechanics/ballistics are incredible with ammo selection being more important than the gun you choose to run (there are 10 variants of 5.56x45, 11 variants of 5.45x39, and 6 variants of 7.62x54R, not to mention 9mm, 7.62x51, etc, etc, etc). The Oberez is a favorite as both a meme gun and for mid range combat. They've recently added the .300 Blackout and .338 Lapua Magnum (aka Satan incarnate).
