Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Apr 13, 2022 at 10:26 AM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    I think I'm going to go with this wheel and i'm leaning toward a Toyo open country AT in 265/70/17 for tires. Has anyone here had personal experience with them, I've only had BFG's and Goodyear's in the past. Then a 2 inch or so lift with Bilstein 6112's up front and 5160's rear with an add a leaf. This truck isn't going to be wheeled hard, but I like a capable vehicle.
    I also decided to keep the 2020 and not wait for the 22.
    Soul Surfer likes this.
  2. Apr 13, 2022 at 10:33 AM
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    I’ve ran the Toyo AT3 in that size on my ‘19 T4R and they were on the quiet side for a AT.
    Slight whine at highway speeds.
    I recommend getting that wheel that comes with the clear coat finish. Not sure of the part#
    GuyHuey likes this.
  3. Apr 13, 2022 at 3:00 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Stay with the BFG's in my opinion. I have the Toyo's in 35's and they always need balancing I never seemed to have that problem with BFG's.
  4. Apr 14, 2022 at 6:53 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I saw some photos from someone on one of the tacoma facebook pages earlier in the week about a body mount relocation you did for them. in the photo of where the stock mount was removed, you could see the ground clamp barely holding on to a shred of the old body mount. if you haven't already, put a couple of these on your list of things for the shop. they make everything so much easier. you can remove the gator clamp completely and bolt your ground lug directly to it, or just use your current ground clamp right on the end without the bolt. i have one for my TIG machine and plasma cutter and LOVE them. worth every penny. even though my TIG machine only hits 260 amps, i use the 600 amp magswitch. the larger base and magnet compared to the 300 amp unit makes the ground so much more stable, especially if its upside down or on an angle where the weight of the ground cable wants to pull it off. they are also notched on the bottom to clamp to curved surfaces/tubing.
    https://www.amazon.com/Magswitch-Gr...netic+welding+ground,aps,77&sr=8-1-spons&th=1
  5. Apr 14, 2022 at 10:21 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    For $140 I found it easy to just clamp lol
    colinb17[QUOTED] likes this.
  6. Apr 14, 2022 at 1:34 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    worth every penny if you are in the business of either production, or need very good grounds for sensitive TIG welds. it's certainly overkill for most folks, especially on a hobby level, but if you weld for a living, once you use one, you'll never go back.
    GuyHuey likes this.
  7. Apr 14, 2022 at 5:33 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Got a picture. My grounds are usually clamped good. And which Fb page
  8. Apr 14, 2022 at 7:06 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I just did a couple of quick searches, and of course couldn't find the post. Im on too many Facebook pages.
    Nothing wrong with the weld. Just suggesting it for the convenience, since you likely do a lot of welding on frames and tubing, where clamp points may not be convenient, or on tubing, the clamp may not be big enough to go around.
  9. Apr 14, 2022 at 7:14 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Ah gotcha. If it was part of the old mount it’s possible that was the plasma clamp. It’s a Dinky thing lol. But tend to clamp to the transmission crossmember when I do them now so I get a full clamp on the ground block.
    colinb17 likes this.
  10. Apr 15, 2022 at 6:57 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    It did look like a pretty chincy clamp, and it was on the remnants of the old mount, so probably plasma. It's bizarre how so many plasma machines come with those garbage little stamped steel clamps. Mine was the same way out of the box.
  11. Apr 15, 2022 at 7:30 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    I run the Toyo AT III on mine and love them.
    GuyHuey[QUOTED] likes this.
  12. Apr 18, 2022 at 3:29 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Well, you know my main choice, lol. That said, if I need a tire that's going to wear decently, rather than age exceptionally, I would go with Toyo/Nittos (same carcass). Although, I have a set of Nitto Trail Graps on the T4R that I got at a little less than 50% tread from Jon several years ago. They are a bit over 7 years old and are a smidge dry rotted but they hold pressure for the most part. They ride pretty good, but I'm due to replace them as soon as I get my rear links--I'm holding out for the $1600 5 link Total Chaos set--replaced and get the dang thing aligned. I'm either going to go with the Toyo hybrid, the Nitto Ridge Grap, or another set of Trail Graps (why the hell are hybrids so effin' expensive? You would think that being between an M/T and an A/T in performance, they would be priced between them instead of more expensive than either. o_O ). I did run a set of Toyo AT3s for a minute. They rode good (drove on them to VA and back--no complaints) but they weren't in the best shape when I got them and frankly they didn't have an aggressive enough look for me.
    As far as BFGs, you may have had a different experience than me but I've never had a set that didn't dry rot and separate on me in less than 3 years. I'll never own another set on purpose (the spare for the T4R is a BFG, but that's only because it was a brand new tire and wheel off a 3rd Gen Taco I found a few years back on the trail at Citrus and nobody claimed. It's probably flat as a pancake right now, but it was free so what the hell :D).
  13. Apr 18, 2022 at 3:59 AM
    Taco No Baka
    Lee
    Tampa, FL
    I'd also like to put the new rubber on these wheels...
    Front sight, Soul Surfer and GuyHuey like this.
  14. Apr 18, 2022 at 7:39 AM
    GuyHuey
    Guy
    Holiday, Florida
    I like those Nitto Ridge Grapplers, may have to go that route.
    Taco No Baka[QUOTED] likes this.
  15. Apr 18, 2022 at 8:19 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    Have had the ridge grapplers on my tundra and have a set on my f250. Do great. The f250 though with the tune and delete I can break them loose on the highway @70mph and get sideways if I’m not easing into the throttle. Ride great though ​
    GuyHuey likes this.
  16. Apr 18, 2022 at 8:20 AM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    Love my Ridge Grapplers. Def recommended
    TheMirror and GuyHuey like this.
  17. Apr 18, 2022 at 9:07 AM
    Soul Surfer
    Jimi
    This is the first time trying the Maxxis Razr 811 AT. There’re the same size of the tire that came on it from the Factory, and only 1 pound heaver. 265/70/16. I’m very happy with them.
  18. Apr 18, 2022 at 11:05 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    5 more cab mount relocation kits in stock if anyone is in need of a relocation
    ljh824 and FlyinRyan893 like this.
  19. Apr 26, 2022 at 8:27 AM
    GuyHuey
    Guy
    Holiday, Florida
    I ordered these wheels and a set of Ridge Grapplers in 265/70/17, Might even be able to have them mounted and balanced this weekend.
    TacoTRD78 and Soul Surfer like this.
  20. Apr 26, 2022 at 5:41 PM
    GuyHuey
    Guy
    Holiday, Florida
    I ordered some new speakers for the truck tonight. The stockers have a lot to be desired. Went with the Kicker upgrade that seems to be popular here. I've ran Kicker's in many rides in the past and always had good luck with them. Hopefully the 6x9's give enough bass, I don't want to give up storage space for a sub woofer.
