Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Jul 27, 2022 at 2:56 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Depends on what trails you run and if they've been maintained recently or not.
    But overall nothing that won't buff out unless you're more or less trying to stripe it up.
    ljh824[QUOTED] likes this.
  2. Jul 27, 2022 at 2:57 PM
    Key-Rei
    Key
    Florida
    Bummer.
  3. Jul 27, 2022 at 3:01 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Yeah, but that was before the Forestry Service went all "No fun shall be had" and blocked off all the good spots. There might be some mud out there that requires 4WD, but who wants to play in that? Haha, damn, have I changed since I joined TW. That and the OG4 is just too nice to subject to mud.
    Depends on the trail. I haven't been out there since Covid so I couldn't honestly tell you what to expect from what trail ATM, but usually pin striping can be pretty minimal depending on how careful you are and how fast you're going. I like to do the speed limit (30 MPH) in between fun spots, which can seem pretty sketchy on the tighter trails and doesn't leave you a lot of time to react to a bush hanging out into the trail or a small tree limb hanging low over the trail, but if you drive at Jeep speed (4Lo as soon as your tires are off the pavement and about 5 MPH on the trails), you can pretty much avoid most of the pin striping dangers.
    ljh824[QUOTED] and Key-Rei like this.
  4. Jul 27, 2022 at 3:10 PM
    Key-Rei
    Key
    Florida
    Damn didn't realize they cracked down on Citrus, any other recommendations?
    Was also considering just getting lost in Ocala but most if those trails are nothing but meandering sugar sand.
    What's around that might have some kind of obstacles other than Hardrock OHV?
  5. Jul 27, 2022 at 3:23 PM
    Taco No Baka
    Lee
    Tampa, FL
    I don't know for sure how much they blocked off. I have heard that they have the first spot on trail 14 blocked off and maybe the second one as well. Not sure. There might still be some spots you can have fun with on trail 11 on the south side of Stage Coach and possibly the spot near the 11 and 20 intersection. Like I said though, it's been long enough since I've been out there that it could be an entirely different place than it was last time I saw it. At the very least you can have a nice relaxing trail ride in the woods, which sometimes can be just as good.
    Maybe someone else has some more up to date intel?
    Key-Rei[QUOTED] likes this.
  6. Jul 27, 2022 at 3:28 PM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    :turtleride:
  7. Jul 27, 2022 at 3:34 PM
    Key-Rei
    Key
    Florida
    Done with your new project you swore you'ed never have yet? :bananadead:
    Where would you go in Florida if not Citrus?
    allenfab[QUOTED] and GuyHuey like this.
  8. Jul 27, 2022 at 3:43 PM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    I know, except for a few odds and ends all the money is spent.
    I need to have a finish Guy's swap party. Get a few members over and get it done. Maybe when it cools off.
    allenfab[QUOTED] and Key-Rei like this.
  9. Jul 27, 2022 at 3:47 PM
    Key-Rei
    Key
    Florida
    I'm down.
    Dunno if you saw my post whenever ago that it was but remember pulling my dumb ass out of the swamp in Richloam with the blue 80's 4Runner?
    I replaced my carpet about a year ago and the factory one still had condensation in it from that and silt in most places on the cab floor that I found when totally gutted for Dyna mat treatment.
    Went to the factory vinyl flooring and peeled the jute off the back, humidity in the cab dropped considerably I was honestly surprised thought I had everything dried and cleaned out.
    Fortunately no mold was found anywhere.
    LMarshall73 and GuyHuey[QUOTED] like this.
  10. Jul 27, 2022 at 3:51 PM
    Taco No Baka
    Lee
    Tampa, FL
    Hey, give the man a break. Engine swaps are complicated with all the computers and wiring and shite. It's not simple like reengineering you whole suspension for a solid front axle and three linking the front. That's just cutting some shite off and welding a few tubes and brackets on, and Bam! Bob's your uncle. :thumbsup:
  11. Jul 27, 2022 at 4:07 PM
    allenfab
    Todd
    Lakeland, FL
    Lol this one is gonna take a while.
    I’ll be exploring the panhandle more. I’ve got some property up there now for a base camp so I’ll be seeing what there is to offer up there
    I’d be down to contribute! Been a while since we got a group of the boys together for a wrench day
    :D
    That’s when you just fork over the money to the companies that custom make harnesses. Those are definitely complicated and beyond my knowledge at the moment
  12. Jul 27, 2022 at 5:13 PM
    GuyHuey
    Guy
    Holiday, Florida
    I have the conversion harness. I really have no excuse except for lack of motivation. That, and getting the Tacoma how I want it has occupied my car guy interests.
    We'll set something up this fall/early winter. Beer and food will be supplied of course.
  13. Jul 28, 2022 at 2:05 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I already have plans for the weekend, I think once it starts cooling off Ill plan a camping/riding trip. You reach out on facebook TW doesn't get much love nowadays
  14. Jul 28, 2022 at 3:41 PM
    Key-Rei
    Key
    Florida
    @Taco No Baka
    Hey Lee, can you do me a huge quick favor?
    I'm working on a 1997 T4R Limited trim that was brought to my Uncle to fix after someone ripped out the plugs on the auto transmission during a botched swap about to solder on a new pigtail but there was no remnant of jacket to identify which wire goes where into the plug.
    Can you slip under the OG4 and tell me which wires go where on this plug?
    It's on the drivers side near the back after what I think is the shift solenoids.
    PXL_20220728_215906909.jpg PXL_20220728_215910861.jpg PXL_20220728_215923121.jpg
  15. Jul 28, 2022 at 8:32 PM
    Taco No Baka
    Lee
    Tampa, FL
    I'll take a look in the morning. Dunno if I'll be able to see it though with the center diff T-case, or if it's even there on an ought-one.
  16. Jul 28, 2022 at 9:30 PM
    Key-Rei
    Key
    Florida
    No worries I posted a thread in the first gen section and someone with the electric wiring diagram chimed in with the answer, I certainly appreciate it though thanks!
    :thumbsup:
    Taco No Baka[QUOTED] likes this.
  17. Jul 30, 2022 at 5:22 AM
    Key-Rei
    Key
    Florida
    I decided not to camp out citrus it was too damn hot and had some other stuff going on yesterday, my buddy is dragging behind but I'll be at the campsite trail head around 10, planning on hitting dirt by 11 if anyone is coming.
  18. Jul 30, 2022 at 10:40 AM
    Key-Rei
    Key
    Florida
    Somehow I keep forgetting I don't own a boat.
  19. Aug 1, 2022 at 3:27 AM
    Taco No Baka
    Lee
    Tampa, FL
    Looks oddly familiar...
  20. Aug 10, 2022 at 6:20 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Well I'm starting my move to TN next week. Got a job up there in the Knoxville area.
