Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Aug 10, 2022 at 6:51 AM
    kaijac03
    kaijac03 Well-Known Member
    Kai
    Florida
    2017 Tacoma, TRD Off Road
    Congrats! Time to get an annual pass to Windrock.
    5 Lug Fury[QUOTED] and TacoTRD78 like this.
  2. Aug 10, 2022 at 7:27 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    That and dollyworld lol
    Key-Rei likes this.
  3. Aug 21, 2022 at 6:21 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Well, I went nuts yesterday, prompted by Aero Precision's site wide 15% off sale. I went ahead and bought my handguard, gas tube, and charging handle. I would have got my adjustable gas block but it was out of stock, dammit. However, I didn't stop there. I went almost all in and got a Tromix .458 SOCOM bolt and a Silencerco three chamber ASR muzzle brake (the silencerco Hybrid 46M supressor screws onto the muzzle brake) and a set of timing shims since the brake will be pinned and welded to the X-caliber 14" barrel I'm planning on getting. The only reason I didn't order the barrel which they say has a 3+ month lead time is they offer two gas block journal lengths and I'm not sure which one I'm going to need. Waiting for AP to get back to me on that.
    So I'm now shy a butt stock, a barrel and a gas block before I can complete this build and have hog (read: home invader) hammer.
    @allenfab I'll have to let you try it out. It won't have the range of your .308, but it'd be perfect for brush hunting for hogs.
    https://youtu.be/LEH7yJ7aHaI?t=293
  4. Aug 27, 2022 at 9:04 PM
    Taco No Baka
    Lee
    Tampa, FL
    Just pulled the trigger on my 14.5" .458 SOCOM Barrel. It should be here just in time for Christmas. 12-14 week lead time...o_O
    Now I just need AP to get my gas block back in stock and get the butt stock, but I guess there's no rush there, lol. Other than the fact that I want to modify the butt pad on the butt stock to a nice thick cushy triple magnum butt pad. The bolt action .45-70 carbine I shot was about the same as a 12 GA, so the .458 SOCOM on an AR platform might be a little more gentle once I get the gas system adjusted right and maybe put a heavier buffer in it.
    Oh, yeah, and I need to check out the EOTech holo-sight with the green reticule. One reviewer said the green was hard to see, but I see green pretty good...better than red, anyway. If it doesn't look that great, I think I'm going to go with a Primary Arms prism sight. It works even if the batteries go dead.
    Key-Rei and crackils like this.
  5. Aug 29, 2022 at 3:52 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    I have the green primary arms 1x prism with the ACSS cyclops reticle on my 300 B/O great optic highly recommend it.
    Taco No Baka[QUOTED] likes this.
  6. Aug 29, 2022 at 4:09 AM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    I just put the same optic with red reticle on my 300 build.
    Taco No Baka likes this.
  7. Aug 29, 2022 at 4:18 AM
    My4thTacoma
    My4thTacoma Pain Don't Hurt
    St Petersburg, FL
    2024 TRD Sport 4x4 (Solar Octane)
    lucky! I’m so tired of Florida but my wife will never leave because she’s from Brooklyn and can’t stand the winters. I’d move to NC or TN in a nanosecond if I could
    allenfab likes this.
  8. Aug 29, 2022 at 5:38 AM
    TacoTRD78
    Stuart,fl
    its great a optic for the price
  9. Aug 29, 2022 at 9:51 AM
    Taco No Baka
    Lee
    Tampa, FL
    I didn't know they came in green. Cool. I had just saw some videos where they were using them as back up sights and mentioned they work even if the battery was dead, and I thought that would be a good feature to have if the SHTF. Of course, in that case, .458 SOCOM ammo would likely be hard to come by, but I could always transfer it to my AR15 5.56x45 or my shotgun.
  10. Aug 29, 2022 at 11:20 AM
    TacoTRD78
    Stuart,fl
    The green is or was a little harder to come by. Exactly still have a reticle with no batteries it cr2032 batteries if I recall with crazy hours and with my astigmatism you can adjust the optic for a crisp image.Sunlight or green background doesn't effect it. I have a couple of batteries in my grip. Oh and technically you really don't need back up sights either since you really never loose your optic when the battery is dead. Just my two cents
  11. Aug 29, 2022 at 11:42 AM
    Taco No Baka
    Lee
    Tampa, FL
    Right. I can't do iron sights anymore since I wear trifocals. The sight picture is just too distorted, so I have to use some kind of optic. It's amazing how much my groups even at 10 yards tightened up when I put the reflex sight on my pistol and I was still able to keep most of the shots around center mass doing rapid fire at 25 yrds. Not anywhere as fast and accurate as Jerry Miculek but fast enough that the RO was keeping a close eye on me and then gave me a thumbs up.
    I think I misstated when I called it a backup optic. I think it was a CQB secondary optic in conjunction with a long range primary optic.
  12. Sep 27, 2022 at 3:04 AM
    TacoTRD78
    Stuart,fl
    Tampa peeps stay safe
    Taco No Baka and Grey 2015 like this.
  13. Sep 27, 2022 at 5:58 AM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Looking like the whole southwest coast better beware.
    FLAK-TAC likes this.
  14. Sep 27, 2022 at 7:21 AM
    TacoTRD78
    Stuart,fl
    not looking good for the bay area keeping you guys in my prayers storm surge is looking nasty
  15. Sep 27, 2022 at 10:00 AM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Stay safe everyone.
    OffroadJet likes this.
  16. Sep 27, 2022 at 7:35 PM
    Taco No Baka
    Lee
    Tampa, FL
    It's starting to look like Tampa's anti-hurricane charm is starting to take effect. We are still in the outer west edge of the cone but it looks like Ian will be making landfall on the southern west coast and heading up through Lakeland. Thoughts and prayers for all in it's path.
    On a lighter note, I guess I won't be getting my Christmas present this year--at least not at Christmas. X-Caliber sent me a shipment notification today. I don't know how I managed it, but it seems they got my barrel done a lot faster than their stated 12+ weeks of lead time. I hope AP has my gas block available soon or I might have to look at other options.
    Hopefully things won't go pear-shaped and they won't end up delivering the barrel to a leveled lot. o_O
    :fingerscrossed::pray:
    @allenfab Hey, brother, did you say you had a tig setup now? I'm going to need to pin and weld my muzzle brake on to be legal and it's stainless. Not sure if it matters or not being as it's basically a glorified tack weld.
    TacoTRD78 likes this.
  17. Sep 28, 2022 at 8:12 AM
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Yup, I can do that for you. Stainless is no biggie
  18. Sep 28, 2022 at 8:44 AM
    Taco No Baka
    Lee
    Tampa, FL
    Cool, thanks! I'll get with you when I get all the parts. I'm going to have to have the barrel nut and the gas block on the barrel before permanently installing the muzzle brake since they won't go around the brake. I have the barrel nut, just need the gas block.
  19. Sep 29, 2022 at 1:39 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    How did everyone hold up. We lost quite a bit of shingles and fence shop held up like a champ
  20. Sep 29, 2022 at 2:28 PM
    Taco No Baka
    Lee
    Tampa, FL
    I did well. Just a couple small downed branches and a bunch of small tree debris.
    Timbo's Customs likes this.
