Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Sep 29, 2022 at 4:43 PM
    ljh824
    ljh824 Regular Guy
    Lou
    Kabul, Afghanistan / Oviedo, Florida
    -21 AG Sport 4x4 DC
    Damn Timbo, sorry brother. We just have debris to clean up. house is in tact and power is still on. i consider that a win for us.
  2. Sep 29, 2022 at 4:51 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Oviedo HS class of 1992.....
  3. Oct 2, 2022 at 7:36 PM
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    My place was directly in the path but was unscathed. My mom’s place in South Daytona, not so much. Her house flooded and her car is toast. My younger brother was there too, so his car got trashed as well. Flooding cleared up enough today so we could start dragging furniture to the curb, then started pulling the carpet and laminate floor and cutting out the wet drywall. I’m off until Wednesday, so I’m hoping we can get it all done by then.8AE7F359-15B5-455B-8498-D129B5B27B17.jpg 33F9FCA2-E5FE-47B2-BF27-390A8F5EE841.jpg
  4. Oct 2, 2022 at 8:27 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Damn, sorry to hear that. That definitely sucks hard.
  5. Oct 2, 2022 at 9:00 PM
    Taco No Baka
    Lee
    Tampa, FL
    This came today...
    JEhS35x67IcZVPcF0-XVUZBNA2-Zaza3hJumVWQS_0d816ee02ce341d76cb828349dd12a70dd7d9d24.jpg
    W2KfyIS4L7oDYneUUleL4Jby9ojOEjP8dr58JlMQ_08b665b10a93567e8150d84bd07458885699228c.jpg
    Was supposed to be my Christmas present, but I guess it's my Halloween treat now. Check out the size of that bore! :cool: It's pictured with the Silencerco three port muzzle brake threaded on which will allow their Hybrid 46M suppressor to thread over it. Not sure when I'll be able to pony up the cash for that addition, but all I'm lacking now it the butt stock, gas block, and the sight.
    I'll admit, I'm not completely happy with the Cerakote color (Sig Dark Gray). I would rather have had it done with Magpul Stealth Gray. I might eventually have to do the handguard and maybe the upper and lower in three color multicam with Sig Dark Gray, Magpul Stealth Gray and either a different, slightly lighter shade of gray or black. Either that or have the handguard, upper, lower, and muzzle brake done in Magpul Stealth Gray with a black butt stock and grip.
    Edit: I went ahead and preinstalled the barrel in the upper and installed the BCG and with the bolt locked in and the muzzle brake on, I have 16.5" from the bolt face to the tip of the muzzle brake, a half inch to spare for the super-anal ATF agent that might want to be a prick.
    TacoTRD78 likes this.
  6. Oct 2, 2022 at 9:12 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Are y’all good? What’s the on-the-ground needs look like?
  7. Oct 3, 2022 at 2:07 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Sorry man glad they are ok
  8. Oct 5, 2022 at 11:11 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    Why did you rule out a two piece adjustable gas block? JP has some affordable ones.
    pro's: Removable even with muzzle brake welded, adjustable to your gas system needs
    con's: price ???
  9. Oct 5, 2022 at 12:33 PM
    golfindia
    Yes.
    pickup truck
    JP Enterprises adjustable gas blocks are garbage and their customer service is worse. Had a toolless version and the adjuster cracked off. They just said "sorry, we don't make that model anymore". Second one siezed up in the closed position after 10 rounds.
  10. Oct 5, 2022 at 1:22 PM
    Taco No Baka
    Lee
    Tampa, FL
    I actually went with the JP clamp on block. :fingerscrossed:
    Umm...oops. :anonymous: Hopefully my mileage may very. It had pretty decent reviews on Midway. This isn't a rifle that's going to get thousands of rounds a year down the tube. Neither my shoulder or my wallet would be likely to handle that kind of volume. Probably just enough to set up a load for it and then enough to stay proficient. I anticipate it's going to be a thumper and not terribly fun to shoot beyond the first mag, lol. Until, or unless, I get the suppressor, it won't be any fun for the folks next to me either. o_O
  11. Oct 5, 2022 at 4:07 PM
    Rob MacRuger
    2006 4X4 SR5 4.0
    Bummer, I'd be pissed too.
    I have two, first one was $115 less tax and shipping. It has been working great. Second one was under $100 and is also working well although I like the more expensive one better. Both use allen wrenches for the adjustment.
    I must have gotten lucky.
  12. Oct 5, 2022 at 4:40 PM
    Taco No Baka
    Lee
    Tampa, FL
    The one I got was ~$126, nearly twice as much as the one piece AP block I was planning for, but since that one wasn't in stock it gave me time to reconsider going with a clamp on model so I could take it off if needed. I'm not thrilled about where the adjustment screw is, but I'm not afraid to make a little modification to my handguard to access it.
  13. Oct 6, 2022 at 3:27 AM
    Rob MacRuger
    2006 4X4 SR5 4.0
    I had to keep taking the hand guard off to adjust but only on the first time shooting. I was going to drill an access hole but decided against.
  14. Oct 6, 2022 at 5:50 AM
    Taco No Baka
    Lee
    Tampa, FL
    Yup, looks like the one I got. I might just take the handguard off, but if I ever go through the cost and effort to get a can, I might need to adjust it. There's also the fact that I'm planning on running light to moderate handloads in it, so I might need to change the setting from time to time if I want to fire factory ammo out of it without getting a face full of gas. I'm not sure how big a difference it will make, but I'd like to keep the muzzle velocity down to around 1500 FPS with the handloads, but with a 14.5" barrel I might get that out of full power factory loads. It'll be fun to play with to get the tailored load I'm looking for anyway. Even if I'm getting the desired velocity out of factory loads, I might still try some handloads. I've noticed that factory powder tends to burn a lot dirtier than handloading powders. That's a plus in my book. Especially if I can use a faster powder to get the same velocity without a big loud fireball coming out the brake.
  15. Oct 6, 2022 at 6:13 AM
    Rob MacRuger
    2006 4X4 SR5 4.0
    In your case I would probably drill the hole.
    Taco No Baka[QUOTED] likes this.
  16. Oct 6, 2022 at 9:39 AM
    Xtremsiege2
    Xtremsiege2 Well-Known Member
    Norwalk CT
    21' LR Pro. Lots of fast bikes
    Which one of you was this in the storm?
  17. Oct 6, 2022 at 10:51 AM
    Rob MacRuger
    2006 4X4 SR5 4.0
    Just out of curiosity what kind of buffer weight does that caliber rifle take?
  18. Oct 6, 2022 at 6:38 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    If there wasn’t gun talk this thread would have cob webs all over it deep in the pages
    :laser:
    TC_Mic and Taco No Baka like this.
  19. Oct 6, 2022 at 6:41 PM
    2013TacoDCLB
    2013TacoDCLB Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    Is everyone in SW FL ok?
  20. Oct 6, 2022 at 6:47 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Hi
