Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Oct 6, 2022 at 7:18 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    You'll need to take the adjustable gas block apart and clean it frequently, or it will get siezed in place. Ask me how I know that....
  2. Oct 7, 2022 at 12:13 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Remains to be seen. Right now I just have the standard carbine buffer that came with the lower. I have been trying to do some research about it, but I haven't really found anything conclusive. Most of the people that have played with them were doing so with a factory built rifle with a non-adjustable gas block. The only thing I have so far is a general but not quantified idea that a heavier buffer will reduce felt recoil, but only to a barely noticeable extent. I've found nothing about the effects of changing the buffer spring rate. Only thing I did find is that had I not selected a barrel with the adjustable gas block option (which has a larger gas port size), it should run reliably with a standard carbine buffer.
    My plan at this point is to get a heavy buffer, perhaps an H4, and try it out to see if makes any difference from the standard buffer. As for the spring rate, I'm going to have to talk to someone knowledgeable about it. Maybe my barrel manufacturer.
    Copy that. Define frequently? :D
  3. Oct 7, 2022 at 7:16 AM
    golfindia
    Yes.
    pickup truck
    Mine froze shut after about 10 rds.
  4. Oct 7, 2022 at 6:29 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    :cheers:
  5. Oct 8, 2022 at 5:36 AM
    Taco No Baka
    Lee
    Tampa, FL
    You mean the "BS" doesn't stand for the Florida Big Shooting Thread? :confused:
    TC_Mic and Rob MacRuger like this.
  6. Oct 8, 2022 at 6:47 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    EABCO sells a pack of three tungsten buffer weights. Last I looked was $30.
    Taco No Baka[QUOTED] likes this.
  7. Oct 9, 2022 at 12:49 PM
    Rob MacRuger
    2006 4X4 SR5 4.0
    I'd be pissed too, JP should have stepped up to the plate and replaced those defective ones. No excuses for crappy products especially when the sales are good.
    BTW, I used a very thin application of MMC78 nickel based anti-seize when installing the gas blocks. I'll see if it did any good when I remove the blocks to clean.
  8. Oct 9, 2022 at 9:04 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    That’s the new title lol. Hop on to see what’s happening and it’s just gun talk so didn’t miss much.
    anyone have a Juliet to pair with my Romeo?
  9. Oct 26, 2022 at 10:04 AM
    MI-FLoffroader
    MI-FLoffroader Brett
    Brett
    Merritt Island, FL
    12' T4R LE/2003 SR5 SPORT V8/1988 DLX 22RE AUTO
    2012 T4R LE -Shoreline Blue Pearl 2003 T4R SR5 Sport V8 -Stratosphere Mica
  10. Oct 26, 2022 at 12:03 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Yota X, golfindia, Grey 2015 and 3 others like this.
  11. Oct 26, 2022 at 4:24 PM
    MI-FLoffroader
    Brett
    Merritt Island, FL
  12. Oct 28, 2022 at 1:44 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    getting mine sunday
  13. Oct 30, 2022 at 4:54 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    @huyner dropped by for his today. Beat my personal time on this one at just under 4 hours to do.
  14. Oct 30, 2022 at 6:25 PM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    Enough with the truck stuff....I thought this was a gun thread. :rofl::rofl::rofl::rofl:
  15. Oct 30, 2022 at 6:30 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    :bananadead:
  16. Oct 30, 2022 at 7:42 PM
    Taco No Baka
    Lee
    Tampa, FL
    I dropped the ball when I went to see Todd a couple weekends ago to have my muzzle brake pinned and welded. I forgot the barrel shims so it was a wasted trip but for getting to drool on Todd's current project. Now I'm going to have to try to get over there on a weekday afternoon via hell's highway. I might see about taking 301 to 98 in Zephyrhills into Lakeland. Might (or might not) take longer, but the chance of getting killed drops considerably, lol. Anyway, that's why I'm not posting pics of the mighty .458 completed.
  17. Oct 30, 2022 at 9:25 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    I4 isn’t that bad
  18. Oct 30, 2022 at 10:05 PM
    Taco No Baka
    Lee
    Tampa, FL
    Pretty sure it's the deadliest stretch of road in Florida. I'd have to be headed east during rush hour. If I don't get killed in a TA, then I'd be sitting in a parking lot, lol.
  19. Oct 30, 2022 at 11:41 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    I’ll take i4 over 75 any day lol
    Taco No Baka likes this.
  20. Nov 3, 2022 at 3:27 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    How about neither :p, driving through the "woods" gets me there quicker 75% of the time..
    We are relocating thanks to "Ian" and will be "Moving" up in your neck of the "Woods" come Mid-December ; Haines City.. :cool:
    I will have to make time to stop by and see the SHOP after the New Year...:hattip:
