Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Sep 11, 2011 at 6:55 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    buy it and i'll stop :cool:
  2. Sep 11, 2011 at 6:56 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    i got a cover that im thinking about sell but it comes off so easily i dont think i will lol
  3. Sep 11, 2011 at 10:56 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    I know we talked about cross members a while ago and jason posted some pics (maybe even colin too) about how you guys routed the exhaust but what about the cross member itself? Did you leave it off or flip it or what? Ordering a aero turbine 2525xl and want to do the exhaust for the last time. So what did you guys do?
  4. Sep 11, 2011 at 11:09 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you talking about the frame crossmember, or the exhaust crossover?
    jason and i have both done it. this is what mine looks like (heat wrap has since been torn off on rocks). jason's is essentially the same, but he still has the heat wrap i believe.
    looking back, i got lucky.... when i got my skid plates, the new crossover happened to be routed in a way that the crossmember built into the transfer case skid cleared it. could have been a pain if they tried to ocupy the same space
  5. Sep 12, 2011 at 2:32 AM
    yotamikez
    Valrico
    mhmm this has me thinking. Do you gain any more clearance or is that bracket still hanging below. Wish I had a side shot of my truck handy will get one when I get off work. I'm just trying to get the bottom as flat as possible. And Colin have you ever thought about running a fjc transfer case? I see guys doing it but is it really stronger? Or are they doing it to get away from the electric 4wd?
  6. Sep 12, 2011 at 6:11 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    if you're talking about the frame cross member, then no, it's in the same place. the exhaust, however, is up much higher. it used to hand down lower than the crossmember, but is now tucked up inside the frame of thetruck. my underside is completely flat, but that is due to having skid plates from bumber to bumber, it's a heavy way to flatten out the uderside, but it deffinately works.
    here's the only side shot i could find that sort of shows the lack of low hanging exhaust. it used to hang lower than the crossmember 2/3 of the way up the front door. you can't do anything about the crossmember though since it supports the ass end of the transmission.
    i haven't really looked into the FJ case thing. I love our crawl gear, and actually like the electronic 4x4 shifter. sure you're kindof in a spot if the motor goes out, but if you really need it, you can just get under there, pop the motor off and shift it in and out of 4x4 with a screwdriver. we had to do that to the e-locker on a first gen this summer at rausch creek when his motor failed. quick and easy.
    lots of guys also do the fj case and a second reduction box for a lower gear for crawling, but with an automatic tranny, i've never been in a spot where i've needed it. might considder it if i were on the rocks every weekend, but that would be more to save the torque converter.
  7. Sep 12, 2011 at 1:33 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :eek: Wyat's going to link the rear of his truck, and said they might out a 4.7L in it over the winter!
  8. Sep 12, 2011 at 1:41 PM
    johnw
    john
    orlando florida
    Link *****
  9. Sep 12, 2011 at 1:51 PM
    yotamikez
    Valrico
    Thank you colin thats what I needed!!!
  10. Sep 12, 2011 at 3:46 PM
    DaWillDaBeast
    DaWillDaBeast Well-Known Member
    Will
    Colorado
    05 Tacoma 4x4 with some goodies
    Things
    You should see my engine compartment....... the white paint looks very........different lol :crapstorm:
  11. Sep 12, 2011 at 3:47 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    there's nothing yet really, just a picture of his truck on jack stands with no wheels on.
    he said that the welds that hold the traction bar heim joints to the axle keep breaking.
    couple pictures in his build thread, as well as a link to the domello forum
    no problem. so whatcha got in the works?
  12. Sep 12, 2011 at 3:49 PM
    GatorComa
    GatorComa Well-Known Member
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    Alright man will do
  13. Sep 12, 2011 at 4:00 PM
    yotamikez
    Valrico
    For the exhaust I'm getting a aero turbine 2525xl and I am going to the exhaust shop to see what it will cost to reroute the whole exhaust. If its cheaper to order that pipe bomb set up I'll do that. I'm going to be ordering some 265/75/r16 mtr's or m/t's looking for a good m/t. But this friday I am ordering a front bumper stock color matched cause mine is pitted from previous owner, and after that I may order a color matched grille. I still need to do tint and a short throw shifter. I think I'm keeping the truck.
  14. Sep 12, 2011 at 4:05 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    glad to hear you are able to keep it!
    if the pipe bomb thing is a cat back, i'd assume having them reroute it like mine and jason's with some 2.5'' aluminized tubing would be cheaper.....but who knows.
    what are you thinking for the exit? gonna dump it?
  15. Sep 12, 2011 at 5:33 PM
    yotamikez
    Valrico
    I got a dynomax super turbo dumped now the muffler sucks I sound like a crx lol I want to get that aero turbine and put it out the rear like stock. I just want a flat bottem and when I order those new tires I'm putting the spare in the bed.
  16. Sep 12, 2011 at 5:45 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
    so guys i only got another couple weeks here before i go to my Tech Skool in NC, i was hoping there was gana be another meet and great before i let. but i guess not, no bigs tho.
  17. Sep 12, 2011 at 6:02 PM
    yotamikez
    Valrico
    You want to wheel or grub? I think we could get a tampa meet going pretty quick there has been some talk about one.
  18. Sep 12, 2011 at 6:08 PM
    Finks99Taco
    Finks99Taco Well-Known Member
    'Fink'
    Coconut Creek, Florida
    1993 pickup
    Or get those trying to start that Orlando meet to do it here shortly.
    I'd be down for a meet in the next week or so.
  19. Sep 12, 2011 at 6:09 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    how many more weeks do you have? if i can get some extra gas money worked up, i was thinking about going to the offshore powerboat races in clearwater on the weekend of the 30th.
  20. Sep 12, 2011 at 6:55 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    off shore powerboat?? what!!! im down. where, when, and how much!
