Flow 40 or Magna 1225
Discussion in '1st Gen. Tacomas (1995-2004)' started by andycass, Dec 6, 2010.
  1. Dec 6, 2010 at 7:36 PM
    andycass
    andycass [OP] Well-Known Member
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    17 inch FN FX Pro Wheels, 3inch Toytec Adjustable coil-overs w/ rear AAL, OEM Roof Rack, Pioneer double-din in dash, Two Pioneer 10 Inch subs with custom box behind rear seat, HID Hi/Lo and fogs, FLowmaster 40 single in dual out. Weather Tech floor mats, LED Dome/Map lights, Cover Kings Camo seat covers,
    I need some help on choosing a muffler for my 04 double cab 3.4 V6. Im between Flow 40 offset 2.25 in/out and magnaflow 1225 offset 2.25 in/out. Any Comments?
    Nutria Hunt Dec 2010 #1
  2. Dec 6, 2010 at 10:13 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  3. Dec 6, 2010 at 10:17 PM
    andycass
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    not sure man. does it make a difference
  4. Dec 6, 2010 at 10:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It might. If you are going to use your stock tailpipe, look at how the pipe coming out of the stock muffler lines up in relation to the front pipe from the cats.
    On mine I went with center in/out because I have seen some offset ones that couldn't be mounted flat because of the offset. I wanted the muffler to be tucked up flat, as far out of harms way as possible.
    I don't think there is any difference in sound or performance based on offset.
  5. Dec 6, 2010 at 10:37 PM
    andycass
    Andrew
    New Orleans
    2012 DCLB TRD Sport
    Alright cool. Thanks for the help
