Flowmaster 40 + 2 cats removed
Discussion in 'Performance and Tuning' started by Annolino122, Jan 5, 2013.
  1. Jan 5, 2013 at 12:17 AM
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    So a few days ago I decided to get my exhaust redone, I removed 2 out of the 4 cats on my 4.0L. I removed a cat on either side of the headers, right after the sensors, that way the engine/computer would not know the difference. So my new set up is 2 stock cats piped into a single pipe using a custom made Y pipe, then its piped into a flow master single in/out 40 series muffler, and dumped before the axel. All the piping was custom welded and bent to have as little creases and bends as possible, to maximize air flow.
    Seeing there are 2/4 cats, i still get enough back pressure to not lose noticeable low end power/torque seeing on a NA engine, some back pressure is good. But where i really noticed the difference was high end RPM, where the increase air flow helps. It has this quickness and agility about it at higher speeds now, and i love it. so the combination of back pressure and air flow has been great so far.
    MPG wise, i will give an update when i have time to go through a tank of gas on regular drives, but for now im enjoying my exhaust and have been getting on the throttle a lot!! Also i just installed a BakFlip so i will see how the combination goes.
    Sound wise, i love it. I've had LOUD vehicles, from a 89 blazer with a 350 block engine, no cats, and a flowmaster, to a WRX tuned for 300+ WHP, straight piped from the turbo, no cats or muffler... so i have had LOUD and OBNOXIOUS vehicles... but this combination sounds awesome. Its loud when you hit certain throttle percentages, but when cruising it mellows out. During idle it sounds nice (ALSO lowered my idle rpms), when WOT, its got this turbine sound to it and throaty sound. Sounds amazing, and my dad who has a magnaflow on a hemi ram, said that for a V6, it sounds beastly.
    So overall, i am super happy with the results of my exhaust modifications.
  2. Jan 5, 2013 at 12:34 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    just curious, the 40 series is chambered right?
    instead of straight through like a magna?
  3. Jan 5, 2013 at 12:59 AM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    Yes, I have the same muffler. Im not sure if it bad or good to be chambered though.
  4. Jan 5, 2013 at 7:52 AM
    Annolino122
    Evansville
    Chambered is correct... And all the chamber does is redirect flow for sound. Not too big of a deal
  5. Jan 5, 2013 at 7:55 AM
    Annolino122
    Evansville
    That way... Instead of using a material like a cat, it won't wear over time. There is no "breaking in" the muffler.
  6. Jan 5, 2013 at 8:31 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    Post up some pictures of the work. :thumbsup:
  7. Jan 6, 2013 at 3:19 PM
    Annolino122
    Evansville
    I will tonight. Been busy sorry
  8. Jan 6, 2013 at 3:40 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    A little lift & some extra steel....
    I'm interested to see if u have any major changes in mpg.....keep us updated!
  9. Jan 7, 2013 at 9:39 AM
    Annolino122
    Evansville
    Let me know if these come out clear
  10. Jan 7, 2013 at 9:40 AM
    Annolino122
    Evansville
    And I'm almost empty on gas, so when i fill it... ill drive normally and get you guys an update on MPG
  11. Jan 7, 2013 at 6:18 PM
    chris66
    chris66 ( ͡°( ͡° ͜ʖ( ͡° ͜ʖ ͡°)ʖ ͡°) ͡°)
    dust
    CO
    2004 Prerunner
    bfg at ko2, method double standard
    post a video with some nice sound clips :D
  12. Jan 7, 2013 at 6:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    it fucks up the engineered scavenging of the exhaust, thus causes a loss of hp.
  13. Jan 9, 2013 at 3:48 PM
    Annolino122
    Evansville
  14. Jan 15, 2013 at 5:49 PM
    Annolino122
    Evansville
    Went 249.4 miles on 11.6 gallons of gas... average of 21.5 MPG's.
    This is even in a mtn town, with slow speeds and a lot of stops and goes.
    Not bad for the exhaust and bak flip addition
