Flowmaster 40 install
Discussion in '1st Gen. Tacomas (1995-2004)' started by Anthony250, Nov 18, 2010.
  1. Nov 18, 2010 at 5:39 PM
    Anthony250
    Anthony250 [OP] Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    So right now i have my 99 tacoma prerunner v6 ex. ca with only a magnaflow catalytic con. and it sounds better has a nice tone, but i want to get an flowmaster 40 or 50 series muffler, now i know that its 2.25 tubing stock , i see mufflers cheap under $50 but with 2.5 tubing and with center/offset since center/center is supposed to fit real easily, . , how did you guys install your aftermarket mufflers ? Pictures? ive seen some mufflers install with center/offset somehow ,
    Thanks
    How much louder is the 40 over the 50 series?
  2. Nov 18, 2010 at 6:50 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    I would think it would be a bit louder. I had a super40 last year, it was okay... I like the sound of FM, but FM mufflers have back pressure unlike the magnaflows.:)
  3. Nov 18, 2010 at 7:00 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    weld it on
  4. Nov 18, 2010 at 8:25 PM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    Here's my Dynomax ST. Used a center/offset and it worked out fine. Chopped off the stock exhaust pipe after the rear axle and had the old hangers welded on.
  5. Nov 18, 2010 at 8:27 PM
    04LTtacoma
    Outer Space
    Nice, that is what mine looks like as well.
  6. Nov 18, 2010 at 8:33 PM
    Blue
    Dylan
    Sierras
    do you notice any difference with the pipe chopped?
  7. Nov 18, 2010 at 8:35 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Thank you i wanted to see if C/O works , i see it does, but im gonna run the stock pipe all the way , no dump
  8. Nov 18, 2010 at 8:39 PM
    gobias
    02 Dbl TRD
    Nope. It makes the exhaust sound a bit louder than a side exit just because it's bouncing off the road, but that's it.
  9. Nov 18, 2010 at 10:46 PM
    Anthony250
    Anthony
    San Gabriel Ca
    i was gonna get the 40 but i saw there is a Flowsound 40 series , i heard thier exactly the same , cuase flowmaster lost thier patent , for half the price i can get a flowsound , should I ?
