Flowmaster 50 question
Discussion in 'Performance and Tuning' started by geoff5093, May 10, 2009.
  1. May 11, 2009 at 8:14 PM
    commtrd
    commtrd commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    Is the magnaflow more restrictive than the stock muffler?
  2. May 11, 2009 at 8:19 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Yes that was stated earlier in this thread!
  3. May 11, 2009 at 9:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If its the straight thru Magnaflow, it will flow a little better than stock
  4. May 12, 2009 at 3:57 AM
    commtrd
    commtrd commtrd
    Corpus Christi TX
    It was stated that the Flowmaster was more restrictive than stock. No specific mention of the magnaflow vs. the stock muffler. I had a magnaflow on my '07 V6 w/ auto and the mileage figures improved slightly with that muffler.
  5. May 12, 2009 at 3:58 AM
    commtrd
    commtrd commtrd
    Corpus Christi TX
    It would seem that the main reason to swap muffs would be to get a different sound? A huge increase in mileage probably not going to happen.
  6. May 12, 2009 at 4:10 AM
    geoff5093
    geoff5093 [OP] Well-Known Member
    Goffstown, NH
    2013 Subaru BRZ
    Exactly, I'm not trying to gain any power or mileage, I just want to get a deeper sound from the exhaust.
  7. May 12, 2009 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. May 12, 2009 at 8:23 PM
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    Alright, I got it installed this afternoon for $130 (muffler + labor), and only took about 30 minutes. It sounds excellent when the truck starts up and when it's accelerating in first gear. Unfortunately that's all I heard from the outside, my friend is going to drive it around so I can hear it from the outside.
    Inside the truck the muffle does sound a tad ricey at certain RPM's, but hopefully that is just on the inside. I'll post up a video shortly.
  9. May 12, 2009 at 8:26 PM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    shoulda went with a magnaflow
  10. May 13, 2009 at 6:56 AM
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    I heard the Magnaflow was worse.
  11. May 13, 2009 at 11:08 AM
    allupinsydeyou
    so cal / vegas
    nooope.. flowmaster is known to be ricey in high rpm... i had the 40 series on my truck with a built v6 and headers... hated it... went spintech and love them... however the next ones i do on my next race truck will be magnaflow race series.... motherfuckers are meannnn.
  12. May 13, 2009 at 5:51 PM
    geoff5093
    Goffstown, NH
    2013 Subaru BRZ
    I think it sounds great at low RPM's, but yeah, high RPM's aren't exactly what I had in mind. My next exhaust will be a cat back.
  13. May 13, 2009 at 6:10 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    i've got the 50 series on mine, basically i had drug the factory barrel on the rocks so i figured it was time to get a new "smaller" one. i decided on the 50 series and was a bit worried that it would be either to loud or to ricey... after having it on the truck for awhile now i can say that i am perfectly happy with it, it gives the truck some tone without being to loud... and you wont mistake it for a honda either.
  14. May 13, 2009 at 6:15 PM
    allupinsydeyou
    so cal / vegas
