Flowmaster American Thunder dual exhaust
Discussion in 'Performance and Tuning' started by WillysTaco, Jul 1, 2010.
  1. Jul 1, 2010 at 7:10 PM
    WillysTaco
    WillysTaco [OP] Active Member
    Willy
    Oregon
    2010 TRD Sport 4x4
    Mudflaps off, Hose clamps,..
    Someone once told me its not a true dual exhaust, is this true?
    if so whats a good dual exhaust? :confused:
  2. Jul 1, 2010 at 7:14 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    its a cat back system. the muffler is single in, dual out.
  3. Jul 1, 2010 at 7:16 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    If you are thinking about getting the american thunder you may want to consider going with wicked flow instead. the wicked flow is deeper and better sounding in my opinion
  4. Jul 1, 2010 at 7:59 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The American Thunder dual kit is a bolt-on kit. Single muffler, single pipe in, dual pipes out.
    I have the kit on my truck (50 muffler).
    If you want a true dual exhaust setup, you have to go to a shop and have custom pipes bent up.
  5. Jul 14, 2010 at 2:21 PM
    CHRIS Y
    CHRIS Y New Member
    2010 PreRunner SR5 4dr long bed
    cold air, throttle body spacer, daul exhaust
    Pros:
    For the money you pay its not a bad system. It took me about 11/2 hrs to install and knock on wood no leaks.
    Cons:
    I hv a knocking snd from the ext.tip hitting the leaf spring mount, but its not to bad.
    I might hv to weld it. Does anyone hv a btr idea.
  6. Jul 14, 2010 at 4:46 PM
    Janster
    Jandy
    Lancaster, PA
    The knocking sound is probably from clearance issues. It does sit close to the leaf springs, but you can 'bend' things a bit to make more clearance (I had to).
    Mine was spot welded - the system was already installed and its harder to install the entire circumfrance of the tubing.
  7. Jul 14, 2010 at 5:40 PM
    TacomaMtnMan
    TacomaMtnMan those who seek fear shall be followed by fear
    Chuck
    Broomfield
    Fox Shox lifted DC 4x4
    3" lift using Fox Shocks Coilover, Total Chaos UCA's. Running: Duratrac 285/70/17 Rear suspension just a 1" block for now. Will have custom rear springs no block. Fox w/ Resi.
    welcome to the forums, but I have to ask, it is really necessary to abbreviate almost every word? hv = have, btr = better, snd = sound
    not used to a keyboard and only phone texting. :)
    :eek:
  8. Mar 24, 2012 at 9:09 PM
    SpeedBlueTaco0502
    SpeedBlueTaco0502 Well-Known Member
    Nick
    Fresno CA
    TRD Pre Runner
    Hankook Dynapro ATM RF10, Plasti Dip Inner Grille, Plasti Dip lower bumper. Bilstein 5100 1.75
    CHRIS Y never returned! LOL
